Old 09-14-2012, 10:03 PM   #1
bitcloud
Drives: soon to be brz limited
Gramlight 57 pro
Hello,
I have these staggered set of wheels from my old 300zx which has a 5x114.3 bolt pattern. How can i fit this? I have seen spacers with the bolt pattern conversion with 15mm. Any thoughts about running spacers and any other ways to fit this?
Also will this fit on the BRZ by running the 15mm spacers? thoughts about the looks and fitment?
fronts are
18x8 +20 and falken tires 225/40/18
rears are
18x9 +27 and bridgestone potenza 275/35/18
I will be replacing the fronts with bridgestone potenzas if the rears work out. any recommendations on sizes?
If the rears won't work then i will end up replacing all tires. Any recommendations for tires and sizes?
Lastly is there away to fix curb rashes? i had curb rashes throughout the 5 years with these rims.
I will also repaint the rims and i don't know what color rims to chose the BRZ is galaxy blue silica and i think black or a dark gun metal color would go well with the color of the car. any reconciliations for color?
bitcloud is offline   Reply With Quote
Old 09-14-2012, 10:50 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I don't think they will fit, they would be pretty aggressive as is but with adapters way too much poke in my opinion. Sell them and buy something that fits better i hate to say it because those are sweet wheels.
Old 09-14-2012, 10:58 PM   #3
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
put it this way, aside from the bolt pattern issue, lets say yo DO get the 15mm spacer adapters.
18x9 +27 is super aggressive on this car. add the 15mm spacer and you basically got +12
which will most certainly NOT fit without going widebody
as suggested, if you can sell them, do so. or ask for trades, I would try on NASIOC since those can fit the STi's 05 and up and you can easily get nice 5x100 wheels in a less aggressive fitment for the Zx6 in exchange
dori. is offline   Reply With Quote
Old 09-15-2012, 12:21 AM   #4
bitcloud
Is there a recommended wheel size and staggered or all the same on 4 corners for the brz? is running 18 inches messing with anything? How about running staggered?
Old 09-15-2012, 12:23 AM   #5
JoeBoxer
JoeBoxer's Avatar
Check the wheel gallery thread it shows every size imaginable pretty much.
Old 09-15-2012, 12:25 AM   #6
bitcloud
thank you very much. sorry for being a newb on these forums
Old 09-15-2012, 12:33 AM   #7
JoeBoxer
JoeBoxer's Avatar
No problem consider your bank account depleted due to this forum!
Old 09-15-2012, 02:35 AM   #8
bitcloud
I have another question, will there be performance advantages if I use a wider wheel (17x8) compared to the stock wheel dimensions (17x7)? Also will increasing my diameter to 18 effect performance probably 18x8 all around. I am thinking about running xxr 530 17x7 for summer and use the stock wheels with winter tires for winter. Lastly could I run a larger tire width then the stock 225? Will it make a difference? Thank you very much
Old 09-15-2012, 02:41 AM   #9
JoeBoxer
JoeBoxer's Avatar
Sent you a pm
Old 09-15-2012, 07:16 AM   #10
dori.
Señor Member
dori.'s Avatar
Joe probably has a better answer for you but:
that will depend on tire sizing/width. if you put a wider tire on there to go along with the wider wheel you'll likely get more grip on whatever end of the car gets the wider tire because of increased contact patch
(note having more grip doesn't necessarily equate better handling)
again, depends on what tire you run and the design and weight of that 18" wheel. that's not really an easy question to answer.
IN GENERAL a larger wheel would be heavier and would affect acceleration/fuel economy compared to a 17 or 16 inch rim
stock is 215, but you could run 225s on a 7 inch rim for sure
but you gotta check the tire manufacturer since not all tires of the same width are created equal. one company's tire can be wider/narrower and have the same numbered width as another company
btw that wasn't another question, that was THREE more questions
The Following User Says Thank You to dori. For This Useful Post:
JoeBoxer (09-15-2012)
Rays Gramlight 57Xtreme Koe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-09-2012 07:04 PM
