Old 09-14-2012, 02:57 AM   #5433
serialk11r
Drives: '06 AM V8V Coupe
Toluene. Weapon of choice during the retarded psi turbo F1 days. 1000 hp/L in qualifying trim...
You're forgetting the restrictor With an equal size restrictor, methanol is the best choice. They've taken that into account though, you're allowed to use a 100 octane straight gasoline, or E85 but with a 19mm restrictor rather than 20mm.
FSAE is called Formula for a reason you know
EDIT: Random thought: just nicknamed my car "spyda" (for now), after the random kid who walked past my car and went "[whistle] woo! SPYDA!"
serialk11r is offline
Old 09-14-2012, 09:07 AM   #5434
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by jstans84 View Post
Dude how can you watch that when Dinosaurs is on Netflix now?!?
got that in my queue, watching it after i finish JCA
wrxgoose is offline
Old 09-14-2012, 12:05 PM   #5435
Dimman
Kuruma Otaku
Dimman's Avatar
20mm? That's tiny. What are some of the power numbers they're getting out of them?
Because titanium.
Dimman is offline
Old 09-14-2012, 12:23 PM   #5436
shadoquad
a quote out of context
shadoquad's Avatar
Drives: '20 BRZ, '17 Silverado, '17 S1000R
Oh
my
God
You, sir, have just stolen next weekend from me.
shadoquad is offline
Old 09-14-2012, 01:46 PM   #5437
Calum
That Guy
Drives: 2013 asphalt FRS MT
Well, I'm not an engine nerd in the sense that I have the education that you guys do, but I'm still very interested and follow along with most of the conversions, asking questions when I don't know something. I did a small amount of reading and found a guy on honda tech talking about making almost 90 hp with a similar sized engine and restrictor. FUCKING CRAZY
Then I got to thinking about just how small a 20mm restrictor is so I measured the inlet to my chainsaws carburetor and it's 1.84 cuin engine. Yup, 19.6 mm.
@serialk11r have they done anything to move peak power down? I know you said the cams are OEM, but there's also intake manifold tuning and cam phasing..?
Calum is offline
Old 09-14-2012, 03:42 PM   #5438
M-17
Ninja Cat Mod
M-17's Avatar
So far I've had a successful trip here Chicago. Must say IMTS is pretty sick too.
M-17 is offline
Old 09-14-2012, 04:29 PM   #5439
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Not feeling good at all... & stuck at freezing cold work isn't helping
ichitaka05 is offline
Old 09-14-2012, 04:58 PM   #5440
serialk11r
Our school is getting a bit under 90hp I think but they haven't bothered to change cams, which is sorta hurting them. They say that the 20mm restrictor gives a practical limit of about 100hp.
@Calum there's no cam phasing on bikes lol. One of the ideas one of the guys had was to retard the intake cam one tooth to see if the reduced overlap would help. They ended up not doing that since they had no time to test it.
Old 09-14-2012, 06:45 PM   #5441
Dimman
Kuruma Otaku
Dimman's Avatar
I think Calum meant manually phasing the cams with adjustable sprockets.
Dropping a whole tooth? They don't have machine shop time or access to make or slot sprockets or make offset keys?
Because titanium.
Dimman is offline
Old 09-14-2012, 06:56 PM   #5442
serialk11r
They didn't have time to drop a whole tooth and test it, much less time to make an adjustable sprocket.
While a whole tooth is quite a bit these bike cams have a lot of overlap so a whole tooth (being like, what, 10-20 degrees timing?) might actually be just what it needs, iono.
http://fsae.com/eve/forums/a/tpc/f/1.../m/34920486151
While no one knows what those specs actually mean, 20 degrees BTDC is a lot! If effective valve opening is right at TDC, that would cut overlap down and work much better with a restrictor. Not to mention, the reduced VE would slightly improve thermal efficiency, which is what counts the most when you're oxygen limited.
Old 09-14-2012, 07:27 PM   #5443
Dimman
Kuruma Otaku
Dimman's Avatar
What is the timeframe? One school year?
Because titanium.
Dimman is offline
Old 09-14-2012, 07:47 PM   #5444
Calum
That Guy
67!!! degrees of overlap, wow, now I understand wanting to a full tooth.
Yeah, as Dimman said, I was thinking of manually phasing the cams, grinding the keyway for a few degrees, or re drilling/slotting the locator pin hole that sort of thing.
With those conditions, I'm actually surprised they didn't just drop the intake back the full tooth and run it anyway. But I'm way out of my league so I'll go back to lurking.
Calum is offline
Old 09-14-2012, 09:18 PM   #5445
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
Are internet memes becoming too popular and overused?
boucher is offline
Old 09-14-2012, 10:12 PM   #5446
wrxgoose
WUB WUB
some of them. we need more Zoidberg though.
(V) (;,, (V)
wrxgoose is offline
