Old 09-13-2012, 07:42 PM   #15
_hollywood
Drives: 97 itr sold
Finally got pulled over for no front plate, so i ziptied mine to the mesh but off to the right side, im not crazy about the looks.
If I trimmed my plate say half an inch around the border would i get pulled over? the numbers would still be showing...or drill some holes thru it for airflow?
I just hate the fact that i am blocking 25% of my airflow to the radiator now and imo the grimm speed one just doesnt flow with the car i want mine as low and out of site as possible....
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 09-13-2012, 08:09 PM   #16
mact
Drives: 13 GTI
Anyone know if it's legal to spray the front plate with tint spray to make it blend in a little bit better with the dark grille? Obviously the plate number would have to still be somewhat visible.
mact is offline   Reply With Quote
Old 09-13-2012, 08:22 PM   #17
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
It's illegal to modify your license plate in any way.
Trojan_SC is offline   Reply With Quote
The Following User Says Thank You to Trojan_SC For This Useful Post:
mact (09-13-2012)
Old 09-13-2012, 08:30 PM   #18
_F-R-S_
Drives: 13 whiteout scion frs
i drilled hole threw the dealer.. it worked out for the best
_F-R-S_ is offline   Reply With Quote
Old 09-13-2012, 09:49 PM   #19
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
I am part of the resistance.. Neo Magnets and 3m are on my side!!!!
Norkoastal is offline   Reply With Quote
Old 09-13-2012, 10:28 PM   #20
_hollywood
Drives: 97 itr sold
Pics? Please? Seems interesting
Old 09-13-2012, 11:25 PM   #21
Norkoastal
Norkoastal's Avatar
magnets are still enroute...
Old 09-13-2012, 11:31 PM   #22
travace
travace's Avatar
Drives: Scion FR-S
looks good dude.
i was unlucky and had holes drilled into my bumper.
lucky for me Kinzo makes a nice mount that i was able to use with the already drilled holes to cover not only the holes in my bumper but my grill as well.
http://www.ft86club.com/forums/showthread.php?t=15277
im happy with it but if i didnt already get that i would prolly try your DIY as i like that look as well.
travace is offline   Reply With Quote
Old 11-02-2012, 09:23 AM   #23
E_br4ke
Drives: FRS 6MT
Any updates?
E_br4ke is offline   Reply With Quote
Old 11-02-2012, 02:37 PM   #24
Norkoastal
Norkoastal's Avatar
I have the rubber coated magnets epoxy'd to the frame...Next step would be taking off the bumper to epoxy the attaching magnets to the inside part of the stash.. Once this is done a little 3M tape to the bolt holes should provide a little extra insurance from slipping away.. Whats good about the design of the plate bracket is that it clips to the bumper on the bottom.. My biggest concern is the force of the magnets through the stache.. I'm thinking at least 10-15 pounds on each magnet should be sufficient to hold the plate/bracket...
CO>CA Cartel
Old 11-20-2012, 05:57 PM   #25
FT-86-
FT-86-'s Avatar
Drives: Sexy Whiteout
My dealer surprisingly installed it without drilling
FT-86- is offline   Reply With Quote
Old 11-21-2012, 09:10 AM   #26
Karmelo
Drives: SWP Limited BRZ MT
How? Do you have pictures?
Karmelo is offline   Reply With Quote
Old 03-02-2013, 04:19 PM   #27
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
must have used a lot of superglue then
nos145 is offline   Reply With Quote
Old 04-23-2018, 08:30 PM   #28
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Originally Posted by Neurytic View Post
I am also thinking of making a custom metal bracket that bend at 45 degrees for the tips of the bolt (instead of washer+zipties). IMO, if someone wanted to steal the front plate, they will just unscrew it.
I'm going to try your idea but instead of plastic zipties that get brittle with uv, heat, ozone, etc, I'm going to use metal zip ties. Order these on Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's a 304 stainless steel zip tie that is rust proof, uv proof, heat proof to 538C, and Tensil Strength: 198 lbs each.
pcguru2000 is offline   Reply With Quote
licesnse plate front diy
CA Front License Plate Law? ashtray Southern California 24 09-11-2012 05:14 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 06:25 PM
License plate mounting options (update: photos added) Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 27 04-16-2012 03:21 PM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 11:04 AM
