Old 09-13-2012, 07:04 PM   #57
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
have these engines proven they need this? I haven't noticed any crank case pressure or blow by problems that would suggest you need this. And my car has as many track miles as anybody else on here. Without boost, I don't see a reason to buy this...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 09-13-2012, 07:09 PM   #58
UncleFester
I'm with you, but supposedly when they took apart a motor with 5k miles they found oil covered piston heads.
UncleFester is offline   Reply With Quote
Old 09-13-2012, 07:12 PM   #59
Crawford
Crawford's Avatar
Drives: 2013 Subaru BRZ
This is from a stock FRS motor with only 5000 miles.
Crawford is offline   Reply With Quote
Old 09-13-2012, 07:58 PM   #60
mashal
DADA
mashal's Avatar
Drives: 2013
Down for one , but 150-200 range anymore I'll just wait till they get cheaper
I-Tapatalk
mashal is offline   Reply With Quote
Old 09-13-2012, 08:03 PM   #61
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by Tim_Asphalt_FRS View Post
I am. I live really close to their shop and was thinking of taking a 15 min drive over there to talk to them, but $319 is a lot for that.
I used to work at the Discount Tire there in Vista, It's worth it in the long run, put in dollar to value 319.00 for a lifetime. of not having your car pistons look like this. And this picture came of a car with less than 6k
Spartan65 is offline   Reply With Quote
Old 09-13-2012, 08:07 PM   #62
Spartan65
Spartan65's Avatar
Originally Posted by gmookher View Post
at $250 I'm a taker too
Yeah @ Crawford
Why weren't we ever offered a group buy? I'd do 275. 00 shipped to 87507
Old 09-13-2012, 08:16 PM   #63
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Spartan65 View Post
Yeah @ Crawford
They just started shipping i suggested the group buy the other night so we can get them cheaper. Vendors usually don't offer group buys unless requested why would they want to sell their products cheaper if they don't have to?
Old 09-13-2012, 08:28 PM   #64
mike2100
mike2100's Avatar
Drives: 23 BRZ
Show us a picture of a piston from an FA20 after 5000 miles WITH an AOS and you might make your case to me.
mike2100 is offline   Reply With Quote
The Following User Says Thank You to mike2100 For This Useful Post:
Grishbok (09-13-2012)
Old 09-13-2012, 09:39 PM   #65
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
This.
you can still read the 2-5 engraving on that piston and see thats not so much buildup as a light dusting from the combustion process. These engines are NOT going to fail in 10k miles from carbon build up. In fact, these will do better than most DI engines as we have dual fuel entry. The gas being port injected helps keep residue off the valves, which is the typical trouble area of direct injected cars. I think carbon buildup isnt going to be a big concern on these motors.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 09-13-2012, 10:56 PM   #66
Spartan65
Spartan65's Avatar
Let me share with you the back deck of the piston I showed you earlier, when carbon builds up so much on the piston crown, that heat transfers to the deck. So in the internal workings of a internal combustion machine a burnt piston deck joins the other side where heat started and creates a hole in your piston.
Old 09-13-2012, 11:02 PM   #67
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by TiTAN Performance View Post
We would be more then will to start up a group buy to get these a bit cheaper for everyone!
Let me know if there is any interest.
-Chris
Yes, extremely interested
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-14-2012, 09:34 AM   #68
arkybrz
Drives: '11 WRX DGM Ltd., '13 BRZ SSM Ltd.
x2
arkybrz is offline   Reply With Quote
Old 09-14-2012, 10:30 AM   #69
Visconti
Drives: 05 STi
I'm sure Crawford could do that for you.
He does have a AOS on his car AND plans on building it
Visconti is offline   Reply With Quote
Old 09-14-2012, 11:55 AM   #70
mike2100
mike2100's Avatar
Drives: 23 BRZ
I'm interested in seeing comparison pics between 2 stock N/A engines - 1 w/ an AOS and 1 without.
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
BRZ Limited Model photos from CES by Crawford Performance NorCalRider BRZ First-Gen (2012+) — General Topics 127 01-15-2012 11:41 AM
Crawford Performance at FRS release event - taps into ECU ! NorCalRider Engine, Exhaust, Transmission 49 12-09-2011 01:13 PM
