Old 09-12-2012, 08:43 PM   #1
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
DIY - Flip Key Fob conversion with pics
Essentially you're taking the guts out of your spare key and putting them into an empty fob. There's 2 ways I am going to show you how to go about it. The first is getting your blank cut and the other is taking your spare key, cutting it down to fit, then replacing the blank. The reason for the second option is because home depot messed up the blank when they cut it. More on that later.
You can get the blank key fob by searching on ebay for "Rav4 flip key fob". I paid $20ish shipped.
before
after
on the blank fob there are 2 small phillips head screws
inside of the key fob. when opening, be careful because the key is wound up on a spring.
with a flat head screwdriver pop up the donor fob
guts taken apart
the transponder "chip" is the little rectangle piece on the lower right hand side of the fob
heat up the donor fob with a heat gun until the plastic becomes "movable" and with a pair of small needle nose, pull it out.
take a toothpick and dip it in some super glue. then place a drop or 2 in the new fob.
place transponder in glue. set that aside to dry.
Story about the blank. I took it to home depot to get cut. After explaining to them "yes I know a chip is required and its already transferred. All I need is it "cut". We agreed that if something with wrong it would be on me not them since I am bringing them the blank key and they were not charging me. Well their machine screwed up.
the og key is on the left and the one they cut is on the right. for whatever reason the machine took way more off towards the tip then it was supposed to.
This is actually the 2nd time I'm doing this. The first time I didnt get pics and it came out a little loose.
theres a 1/16'' pin that you have to take out. i used a drill bit and hammer. in the first pic its the hole on the left
once you get a little bit out, you can grab it with a pair of pliers and take it the rest of the way out. its a little tough but it'll come out.
the blank and the donor
what i used to do the trimming
donor and blank for comparison
a little tip. when trimming use the high speed to cut it down to the basic shape. then use the low speed to grind it down to the exact shape and size. this is what takes the longest but take your time and get it right the first time.
then comes the slit. line up the spare and mark it off. make it just big enough to where the pin fits inside the slit.
place the trimmed key in the slot. line up the pin and lightly with a hammer tap it into place. once its about 2/3 of the way, use a pair of pliers to force it the rest of the way.
take your buttons from the donor and place them in the flip fob
theres a rubber piece that goes between the buttons and module that needs trimmed down to fit.
before
after
i did a test fit and the buttons felt a little loose. so i folded up some small pieces of paper and placed them inside the fob for a firm fit
the spring has a small piece that comes out and the fob has a notch in it where the spring goes. place the spring in said notch like so
the button and key have notches as well. place button in key
place button on spring like so except place it in the "2 o'clock" position then wined 2 1/2 rotations counter clockwise and hold.
now comes the tricky part. putting the 2 halfs together. its a lot easier with 4 hands but not impossible with 2 hands. screw in the back 2 screws and enjoy.
overall review:
Feels great. The key springs right up. In the car it doesnt have a cheap feel or feels like its going to brake.
draggin_az is offline   Reply With Quote
Old 09-12-2012, 08:57 PM   #2
mach330
Drives: Ultramarine frs
Wow great work man.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 09-13-2012, 02:49 AM   #3
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
soo much work.. Can we just buy a kit pre made lol
Furtive is offline   Reply With Quote
Old 09-13-2012, 11:10 AM   #4
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Great DIY! Very creative. I don't think I would have the patience or skill to do it. But, if I get my hands on an extra key I might just try it.
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
Old 09-13-2012, 12:02 PM   #5
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
yea....glad I got a limited, lol. Good job with the work though... shows a lot more dedication that I have...
sbxjap is offline   Reply With Quote
Old 09-13-2012, 12:16 PM   #6
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Holy epic DIY batman!
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 09-13-2012, 12:28 PM   #7
gmookher
we must find you a hobby..
and an audi...
Old 09-13-2012, 12:33 PM   #8
diirk
diirk's Avatar
Drives: 4Runner
Great idea. Detailed writeup and excellent pics.
I think you get the DIY Member of the Month.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 09-13-2012, 12:45 PM   #9
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
well you know the car DID come with 2 keys and a valet... so I wouldnt mind disfiguring my spare key to do this... Thanks for the inspiration and the helpful photos.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 09-13-2012, 01:36 PM   #10
themadpants
Drives: .
No finished pics? Also, a picture of it in the ignition too would be cool.
Thanks!
themadpants is offline   Reply With Quote
Old 09-13-2012, 05:02 PM   #11
draggin_az
draggin_az's Avatar
thanks everyone
and an audi...
I'm 27 and have drove lowered trucks my whole life. this is the first car ive ever owned so modding is my hobby lol.
and no Audis. the only other car I would own besides this and the avenador, would be the zenvo st1.
Thanks!
pic #3 is the finished product. I'll try to get a pic of it in the iginition in a day or 2.
Old 09-14-2012, 05:58 PM   #12
draggin_az
draggin_az's Avatar
as promised
Old 09-14-2012, 07:13 PM   #13
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by draggin_az View Post
as promised
Looks great! Just to be perfectly clear, this blank can be cut and used without having to use the method you did?
post_break is offline   Reply With Quote
Old 09-14-2012, 07:14 PM   #14
themadpants
Drives: .
as promised
Nice work! :happy0180:
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
BRZ HIDs vs FR-S HID Conversion DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 37 06-28-2012 05:20 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
