Old 08-29-2012, 04:30 PM   #1
motofan
Drives: 10 VW GTI
Jamming Key?
Hello, My friend who's got an FR-S told me he for several times couldn't remove the key after the car was switched off. He thinks he shifts to park and did push the key in and turns before trying to remove it. But he couldn't repeat the problem when we met.
Just wondering if anyone has similar experience?
motofan is offline   Reply With Quote
Old 09-01-2012, 06:20 PM   #2
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I have had similar instances myself. Couldn't really explain when it happened because it was pretty random, and was a CND (could not duplicate) after the fact.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 09-01-2012, 08:53 PM   #3
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
its just the car getting emotionally attached and does not want you to leave.
njccmd2002 is offline   Reply With Quote
The Following 2 Users Say Thank You to njccmd2002 For This Useful Post:
Sportsguy83 (09-11-2012), travace (09-01-2012)
Old 09-01-2012, 09:22 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'm assuming its only an AT thing because my MT doesn't have this
Old 09-11-2012, 06:08 AM   #5
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
wheel lock?
gdi2290 is offline   Reply With Quote
Old 09-11-2012, 05:13 PM   #6
jduffy
jduffy's Avatar
My key was hard to get in the ignition and the salesman told me that it would get easier as the sharp edges on the key would get softer from repeated insertions. It can also be hard to get out at times as well.
No I do not write pornography.
jduffy is offline   Reply With Quote
Old 09-11-2012, 07:06 PM   #7
egraphic
Drives: Blue Scion FR-S
I think it's wheel lock - I had exactly the same situation. When I turned the steering wheel to reposition the wheels, I was able to remove the key.
egraphic is offline   Reply With Quote
Old 09-11-2012, 07:12 PM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Happens to many cars...like said above; most likely the wheel lock. Just turn the wheel a little bit to either side and the key then should be able to turn back to the off position and release.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 09-11-2012, 11:21 PM   #9
michael317
michael317's Avatar
Drives: BRZ Limited
was the steering wheel locked? if so it may cause the key hard to turn in the igniton. try turning the steering wheel while turining the ignition and see if it helps if not then the ignition lock cylinder may be faulty
michael317 is offline   Reply With Quote
Old 09-12-2012, 06:38 AM   #10
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
this happens to me esp when other people drive it. its almost like your have to slightly push in and turn the key at the same time all in one swift motion.
draggin_az is offline   Reply With Quote
Old 09-12-2012, 11:09 PM   #11
motofan
Drives: 10 VW GTI
Never though about that. I thought the lock only prevents you from turning the key on after you insert the key. In my friend's case, the car wants to be driven and doesn't want to release the key. I'll let my friend try anyway.
