Old 09-10-2012, 03:30 AM   #1
Zadkiel
Drives: CBS BRZ Limited 6MT
Damage to built up area of sidewall/stock tire.
Long story short, biffed a curb in Lemoyne, PA and caused this
Dealer looked at it and said both the rim and the tire should be fine. Been driving on it for almost a week, did a 100mph blast on it, and no issues so far. The worst damage on the tire is to the built up area just on the lip. No cord showing and tire pressure is holding fine. I was planning on putting them on a set of 17x7.5 rims. Just wanted to get the second opinion if they're ok and if putting them on the new, slightly stretched rims would be fine.
I'd rather not have to spring for a new tire this early, as I also plan on getting a set of winters to put on the oem rims. Thanks
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 09-10-2012, 10:35 AM   #2
subatoy
subatoy's Avatar
Drives: subatoy
ouch it's really hard to tell from pictures but I wouldn't feel safe going too fast on that. I'd say it would be better to change it, I would pay $100 any day for pieace of mind specially if you are having too much fun on the car.
lets just say that side wall won't like going sideways for long!
subatoy is offline   Reply With Quote
The Following 2 Users Say Thank You to subatoy For This Useful Post:
dori. (09-11-2012), Wes B. (09-10-2012)
Old 09-10-2012, 11:03 AM   #3
Wes B.
Automotive Enthusiast
Wes B.'s Avatar
Yeah, I'd just invest in a new tire. They aren't that expensive...
Wes B. is offline   Reply With Quote
Old 09-10-2012, 02:30 PM   #4
Zadkiel
Well, ran into a snag. Absolutely no tire shops in the area have the Primacy HP's. The dealer, when I went initially, also said they don't deal in Michelins. Tire Rack has them, but they're almost $200 for 1 tire. While I know tires aren't insanely expensive, they still cost quite a bit.
It's too early to spring for putting winters on the car, and I should be getting my new DR-34s soon. I've also taken a bunch of sharp turns on backroads at 60+ mph. Any advice? Also, anyone recommend a tire for a 17x7.5 rim? Will a 225/45R17 tire work on a 17x7.5?
Old 09-10-2012, 07:28 PM   #5
Zadkiel
Just went to a tire shop in Camp Hill. For them to install just 1 tire would be $230 after balancing, e.t.c. Brought the guy out to look at the damage, he said it should be perfectly fine. The damage is to the built up "curb guard"(see how well that worked) area and no real damage to the actual sidewall. The integrity of the actual sidewall isn't compromised as the built up rubber on the tire is there to actually get scrubbed to prevent damage to the wheel.
The best way to imagine it is if you pull in next to a curb, the built up area will scrape before the wheels and actual sidewall will.
Old 09-10-2012, 10:26 PM   #6
D1cker
Drives: B9 S4/ND2
If you can't see any cords or deep tears then it should be fine!
D1cker is offline   Reply With Quote
Old 09-10-2012, 11:03 PM   #7
Foobar
SLO NO MO
Foobar's Avatar
Yeah, in theory it protects the rims. In practice, it doesn't do squat. I've already curbed one of my ribs and it's not like I tore into the curb with force - just rubbed up against it. If you think about it, there's not really alot that can protect the curb from hitting the rim as long as the rim is lower than the curb. All the weight of the car will just push any curb protection scheme in place until you have rim on concrete.
Anyway, yeah I wouldn't worry about that tire, you're fine. Just replace it when you get winters.
Old 09-11-2012, 12:39 AM   #8
michael317
michael317's Avatar
Drives: BRZ Limited
as long as you dont see the steel belt from the cut on the sidewall the tire is fine. look like its just cosmetic damage. but with the look of the rim, you might tweaked your alignment a bit.
michael317 is offline   Reply With Quote
Old 09-11-2012, 01:05 AM   #9
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
It will probably be fine, but hitting triple digits to test it out seems...a bit darwin'ish...
sho220 is offline   Reply With Quote
Old 09-11-2012, 02:49 AM   #10
Zadkiel
Didn't do it to test it out at the time. It was a straight section of 322 between Harrisburg and Hershey, just after the last light just East of the Wal-Mar, if anyone is familiar with the PA area. Straight downhill section at 2 a.m. with high-beams on.
When it initially happened, I didn't see cord so I thought it might be ok, wasn't 100% certain at the time.
Old 09-11-2012, 06:14 AM   #11
master345
Drives: jag xjs
You drove 100mph on a suspected bad tire to see if it might blow? And if the tire had blown, then you would have known the tire was bad. What could happen in a tire blow out at 100mph? Youtube link:
[ame="http://www.youtube.com/watch?v=FeTjXRbBHeA&feature=related"]Car goes airborne 100 mph crash hits bridge caught on dash cam Firebird in Ohio with SlowMo replays - YouTube[/ame]
master345 is offline   Reply With Quote
Old 09-11-2012, 06:38 AM   #12
onthemove
Drives: ...
Did a burnout on my motorcycle till the chords were showing all around it, then went 150mph and didnt die....
Id say your safe!
onthemove is offline   Reply With Quote
Old 09-11-2012, 01:36 PM   #13
damian_mb
Drives: 07 si
Id say your safe!
Idiot, giving out idiot advices......
Not sure how anyone can rash their rims that bad but since you replaced them stay away from crubs. It's not that hard to park. Sorry not trying to sound like a huge D-bag, but I've had many, many cars and have never curbed any rims/steelies on them
damian_mb is offline   Reply With Quote
Old 09-11-2012, 04:50 PM   #14
Zadkiel
Read please, I wasn't parking. I went around a turn, the curb for the turn sticks out a more inches so you almost have to Semi-style swing it around the turn.
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
Need Help: Looking for built-in nav for FR-S! carlo1912 Electronics | Audio | NAV | Infotainment 1 09-06-2012 09:34 AM
Tire Sidewall Question applekash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-26-2012 08:42 PM
Minor paint damage Double4Free Great Lakes 8 07-23-2012 07:35 PM
Road Trip Damage Mitigation Mitch Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 06-15-2012 07:15 PM
