Old 09-09-2012, 04:50 PM   #29
gmookher
I had to return the 14mm whiteline bolts, the think and say they work and fit but there is way too much slop and the lobe is too small.
Old 09-09-2012, 05:04 PM   #30
xwd
You put them in the lower hole right?
Old 09-09-2012, 05:12 PM   #31
gmookher
shit no, was that my mistake? I just followed instructions which said upper hold- I still have the box let me run to garage and see if they like the lower hole better...
Old 09-09-2012, 05:25 PM   #32
jamal
jamal's Avatar
Drives: Legacy GT
Read my posts in this thread all the way through.
jamal is offline   Reply With Quote
Old 09-10-2012, 07:11 AM   #33
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I'm wondering how much adjustment I'll be able to get with the Whiteline bolts (which I have).
Also wondering if a combo of OEM crash bolts in the top strut mounting holes PLUS Whiteline camber bolts in the lower holes might be a viable solution for even more negative camber.
Of course you'd lose spring/tire clearance by going that route and the geometry wouldn't be as ideal but it could be an alternative to running adjustable top hats.
We probably only need around minus 2 degrees up front on our cars unless more is needed for some extreme track/drift setup on a lowered car.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-10-2012, 10:29 AM   #34
gmookher
nah...wouldnt swap out both bolts..
I was just being a dumass, the whitelines fit fine in the lower bolts
The bolts are a nice solution if you for some reason arent gonna run coil overs or plates
I was able to get both sides to an even -1 degree without any fuss. I fyou want to squeeze out another quarter degree it can be done, but a 2nd person is needed to 'hold' the bolt at torque to get that last bit out. I dont buy the advertised 1.75degs.
The Following User Says Thank You to gmookher For This Useful Post:
ultra (09-10-2012)
Old 09-10-2012, 01:31 PM   #35
ultra
Curious cat.
ultra's Avatar
Good info.
Old 09-10-2012, 02:48 PM   #36
jamal
jamal's Avatar
Drives: Legacy GT
It actually would be more ideal to add camber with bolts than tops from a geometry standpoint because you are not increasing the SAI. SAI causes camber loss with steering angle so you don't want to add any more than necessary (you need some to provide good steering feel and self-centering force).
Old 09-10-2012, 06:18 PM   #37
ultra
Curious cat.
ultra's Avatar
OK, now you've got me curious about my ghetto double camber bolt idea.
Old 09-11-2012, 02:47 AM   #38
jamal
jamal's Avatar
Drives: Legacy GT
At that point you're better off just taking a grinder or dremel to the holes in the strut to slot them out. You could even go so far as to weld washers back onto the flanges once you have the holes in the right place so there wasn't a big elongated hole but it's not really necessary.
Old 09-11-2012, 07:30 PM   #39
getbent
Drives: 2013 FR-S Blue MT
Do you already have lowering springs? Is it possible to just use the OEM crash bolts or whiteline camber bolts to bring a moderately (1 inch or less) lowered car back into proper camber specification?
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 09-11-2012, 08:31 PM   #40
86drift
86drift's Avatar
Drives: Toyota 86 GT
Just to clear up some info on the whiteline parts (since I have them installed in my car).
The Group N spec strut tops are in fact hard rubber. Gives a little camber and castor.
The camber bolts are 16mm and not 14mm. They go in the TOP hole. Part number is KCA416 and are +/-1.5deg. They're easy to adjust and will not slip.
Whiteline Camber Bolts
86drift is offline   Reply With Quote
Old 09-11-2012, 08:51 PM   #41
gmookher
KCA416 that makes alot more sense, and would explain why they belong in the top hole
where does one get these stateside?
Old 09-11-2012, 08:51 PM   #42
jamal
jamal's Avatar
Drives: Legacy GT
Yes, KCA416 would work in the top hole. KCA414, which is what the OP is about, will not.
should be available from anyone that carries whiteline. I'll have to check and see if WL US has any in stock. Actually Eibach/SPC/ingalls should have one that size for much less. Try 81280
The Following User Says Thank You to jamal For This Useful Post:
gmookher (12-27-2012)
Installed coilover; Too much camber in the back. trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 04-11-2016 07:00 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
