Old 08-28-2012, 03:03 PM   #57
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Originally Posted by E92M3Guy View Post
From the "Torque-bhp" forum FAQ:
How do I make the displays update faster?
This is mainly down to the speed at which the ECU operates and provides data to Torque, but there are a couple of things you can do that will improve the speed of the readings:
  • Try to use the ‘Faster communication’ setting – Some adapters can use the ‘faster communication’ setting to reduce timeouts and retrieve data slightly faster from the ECU. Not all adapters support this option but it will improve things if yours does.
  • Have fewer displays on screen – Torque will only ask the ECU for the information that it needs, so if you want the fastest update possible for a particular display then only have that display on the screen
  • Only use logging when required – Web uploads and file based logging ask the ECU for PIDs, only use logging when required.
This tells me a lot. The utility is using DCAN messages, not PT-CAN. PT-CAN is much faster than DCAN, but DCAN is universal and PT-CAN is vehicle-specific. DCAN is a polled interface -- meaning you must poll the ECU for data. Due to the design of DCAN, the more PIDS you request, the slower the sampling rate. Typically, DCAN supplies data around 5-6 Hz with 8 PIDS or less. Sample more PIDS and sampling rate goes down. But regardless, you're still limited by the sampling rate of the sensors themselves. GPS in cars is still about 1Hz sampling rate at best.
Guy says his app is better than GPS alone. Not sure why he says that. vBox is a GPS and acceleromter combo -- maybe he's doing the same thing and that's what he means. But vBox is 10Hz, 20Hz, or 100Hz sampling rate depending on the model. It's basically the gold standard for this type of testing.
I just did some 0-60 launches just to show you guys how must fast the speeds pick up. Im not sure how accurate the torque app is but i do know that the car cannot be moving and once your car starts moving it starts the countdown. I only use the app as a reference and i still give the app 5stars because while it might not be 100% accurate it still comes pretty close but i think its better than ppl tryingto calculate based on a video and using the seconds on the video.
For those that want more videos i will be doing more most likely next week and i will be shooting for a quarter mile run this time. I just got my oil changed today so next week ill try some runs for you guys and post.
brichard0625 is offline   Reply With Quote
The Following User Says Thank You to brichard0625 For This Useful Post:
tripjammer (08-29-2012)
Old 08-28-2012, 03:08 PM   #58
brichard0625
Originally Posted by *KID* View Post
did you get any track times?
No track times yet. I havent had a chance to hit one up yet.
Old 08-28-2012, 03:10 PM   #59
brichard0625
Originally Posted by xAgentzero13 View Post
the guys with the tune getting 0 to 60 in less than 6 secs what other mods do you have?
I only have hks drop in filter like someone else stated but i also had to release air in the tires and find the perfect launch rpm on the type of pavement i was on. For this run i believe tire pressure was 33psi for each tire, and i launched at about 4200 rpm which was enough to launch without any violent wheelspin
Old 08-28-2012, 06:17 PM   #60
xAgentzero13
Drives: genesis coupe
I want to see what an intake and full exhaust and this tune can do!
xAgentzero13 is offline   Reply With Quote
Old 08-28-2012, 06:35 PM   #61
brichard0625
me too lol...today i bumped into a mustang v6 that wanted to play. it was a 2010 mustang v6(MT) and didnt realize that they were slow. I thought they ran the same engine as the 2011 and 2012 v6. it wasnt even close, we did two little runs from 10mph to about 75mph rolls and everytime i just jumped on him and kept going..wish i had my go-pro gonna have to start leaving it in the car.
Old 08-28-2012, 06:50 PM   #62
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by Synack View Post
Lol, well apparently they don't know anything about drift setups. A proper drift car always runs more negative camber in the front than the rear.
The negative rear camber is to help slow rotation..
Oem alignment settings are simply oem alignment settings.. They are what they are.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 08-28-2012, 10:16 PM   #63
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I may have to try a 0-60 run sometime this week. I just got tuned so it would be interesting to see. I dug out my MSD Daskhawk and plugged it in. Seems to work and read the sensors on the car. I can set it up for 0-60 when I have time. One of the questions it asks in setup is the front facial area in square feet. What would you guys say our car is?
JimmyMac is offline   Reply With Quote
Old 09-05-2012, 01:45 AM   #64
DSTL
Drives: 2013 BRZ Limited 6MT
Visconti Stage1 E85 tune 0-60. Posted this in another thread, but figured it makes sense to put it here. Also, would recommend using a video editor to check your elapsed times. Checked the times posted here using NetVideo Hunter and a video editor and they're off by quite a bit. Guessing the time that Torque kicked out was used? Anyow.. Car is 100% stock aside from the Visconti E85 tune. Not a great launch, but just made one run and prob won't do anymore 0-60s, not my thing but was curious.
[ame="http://www.youtube.com/watch?v=-CRhtWqzfsw"]BRZ 0 60 - YouTube[/ame]
Verified 6.14 seconds via frame by frame of original video. Think with a good launch it would easily be under 6. I'll leave that for someone else!
DSTL is offline   Reply With Quote
Old 09-05-2012, 12:51 PM   #65
brichard0625
Yea i used what torque kicked out and never thought of doing it that way..just did frame by frame on mine and ur right i got it starting at 30.309 and reach 60mph at 36.241 which is 5.932secs which still isnt bad. And nice run i cant wait to try e85
Now that i tried to really time this run i started at 30.309 but ended at 36.300 which is really 5.991sec
Last edited by brichard0625; 09-05-2012 at 06:32 PM. Reason: Did more digging on the time for my video.
Old 09-05-2012, 01:08 PM   #66
brichard0625
just downloaded ur video and i have u starting at 2.505 and ending at 8.642 which gives me 6.137 so u were dead on
Old 09-05-2012, 01:51 PM   #67
jesperswe
Drives: GT86
How come you are running 93 Octance? :o
My Toyota dealer here told me to put nothing but 98 Octane in my car
But i live in sweden so not sure if the Octane is the same world wide?
jesperswe is offline   Reply With Quote
Old 09-05-2012, 01:54 PM   #68
mungewell
Drives: Knackered Forester
0-60, 1/4 mile via GPS?
Hi,
Obviously a 'stock' GPS with 1Hz output wouldn't be much use... but I have access to cheap 20Hz units (or expensive 100Hz units if I beg with my boss).
Does anyone have links to a 'processing' spread sheet or the like?
I'd just be interested if this could be made to work.
Simon
mungewell is offline   Reply With Quote
Old 09-05-2012, 01:54 PM   #69
brichard0625
i think ur 98 ron which is 93 over here
Old 09-05-2012, 01:57 PM   #70
CBR600RR
Drives: Raven Black
figured I would post this link here; it is relevant.
http://www.ft86club.com/forums/showt...ht=Pocket+dyno
Visconti Calum User/Vendor/Sponsor Reviews, Feedback, Comments 7 03-11-2013 06:02 PM
Visconti stg 1 Hawaiian Great Lakes 18 08-23-2012 02:11 PM
FR-S vs. Tuned WRX and Tuned B8 S4 Snozzberries FR-S / BRZ vs.... 2 07-29-2012 09:35 PM
Used tuned 86! STJ Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2012 10:42 PM
Official 86 GT Modded/Tuned track times. GT5 PAImportTuner FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-26-2011 01:30 AM
