Old 09-04-2012, 03:18 PM   #1
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
225/50/17?
On 17x7.5 TE37s. I searched. I see everyone picking 45 over 50. is 50 really too big? I don't plan on doing springs any time soon, so I wanted to fill that wheel gap a bit.
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 09-05-2012, 08:30 AM   #2
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
My first thou is, Idk y ud want a thicker tire that way. I would think it'd throw off the calibration for the speedometer
karma003 is offline   Reply With Quote
Old 09-05-2012, 09:43 AM   #3
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
Well looking at Michelin Primacy HP tires the revs per mile of the stock tire is 844, and for the 224/45 it is 833, but the 225/50 is 803. So the 225/45 will be 1.3% taller and the 225/50 will be 5.1% taller than stock. The 1.3% difference is not that significant; but, I think making all your gears 5.1% taller and having your real speed be 5.1% higher than the speedometer reads is too big a difference for most owners.
DSPographer is offline   Reply With Quote
Old 09-05-2012, 10:09 AM   #4
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Best movie ever, Mr. Burton.
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 09-05-2012, 10:09 AM   #5
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
It will most likely rub at full lock on the front. I have some old 225/45 19s on the car now, which are similarly sized, and they rub. Not a good way to fill it out.
TheRipler is offline   Reply With Quote
Old 09-05-2012, 10:47 AM   #6
JACK 8URT0N
Thanks guys, I'll stick with 45. I appreciate the input.
Old 09-05-2012, 12:30 PM   #7
Kurenai
Drives: 2013 Scion FR-S Hot Lava 6AT
There have also been reports of abs/traction control/stability control issues when rolling diameter differs by more than ~3% of stock
Kurenai is offline   Reply With Quote
Old 09-05-2012, 01:55 PM   #8
TheRipler
Reap the BReeZe
If all the tires are the same size, how would it know?
Old 09-06-2012, 02:34 AM   #9
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
what? how would you know if it would rub or not without knowing the offset?
dori. is offline   Reply With Quote
Old 09-06-2012, 04:25 AM   #10
TheRipler
Reap the BReeZe
I'm not sure what you read.
*most likely* = probable = better chance it will than not
Feel free to give it a shot, if that's what you want to do.
Old 09-06-2012, 08:43 AM   #11
dori.
Señor Member
dori.'s Avatar
Sure, if you answer my question first.
