Old 09-04-2012, 01:11 PM   #57
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by Roadstercycle View Post
After looking at pix on Google that's a yes and a no. There major claim is oil to and from, which is there big advertised claim. I don't use oil, I'm water cooled. Don@accelerated is remote also and using there oil to and from setup so who the heck knows. I'm not against buying a license but I'm not infringing on the oil patent even remotely just the remote mount maybe. I didn't know about STS until after so it definitely is not deliberate on my part. I just thought it up. Oh well it is what it is. I'm having fun and it works awesome.
I wouldn't worry about it. My system is not remote. Its no more out of the engine bay than an OEM Subaru WRX. Just sits lower.
Don@Accelerated is offline   Reply With Quote
Old 09-04-2012, 03:01 PM   #58
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
I agree, I really love your system Don, a lot of nice engineering. 100% top notch.
Roadstercycle is offline   Reply With Quote
Old 09-04-2012, 03:05 PM   #59
Roadstercycle
I'll be at the Crossroads mall in Torrance this Friday evening if anyone wants to check it out. 1st Friday of the month get together for Japanese sports cars.
Old 09-04-2012, 04:24 PM   #60
wootwoot
Drives: FRS
Any plans to dyno the car? I am curious as to what all that piping will do to the response of the whole system...
Old 09-04-2012, 04:32 PM   #61
Roadstercycle
Just to clear up an issue that may be confusing a few people about the water cooling of the turbo. The turbo I'm running is a Comp-turbo oil-less type. It has very expensive ceramic bearings that are packed in grease and need to be repacked every 30,000 miles. The water cooling only flows around the bearing packs to keep them cool. The water is not lubricating the turbo. It's pretty new technology and I like new technology so I am giving it a whirl, no pun intended. They are being used more and more and the feed back is great. No more oil starved turbos when the return pump dies.
The Following 4 Users Say Thank You to Roadstercycle For This Useful Post:
ftc~brz (01-23-2014), SeattleJeremy (09-21-2012), SkullWorks (09-05-2012), tripjammer (09-04-2012)
Old 09-04-2012, 04:33 PM   #62
Roadstercycle
I am checking into dyno shops now.
The Following 2 Users Say Thank You to Roadstercycle For This Useful Post:
Old 09-04-2012, 06:51 PM   #63
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
And the big plus is you can mount the turbo however you want with the intake side of the turbo facing upward if you wanted cause of the oil less system. No limitation! I read about these turbos a while back but was turned down cause of how much the maintenance for these costs every 30k miles. But I'm in for videos too!!! The sound of spool from rear mount turbo is so addicting :-)
mastertech86 is offline   Reply With Quote
Old 09-05-2012, 07:53 AM   #64
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
there's a lot of ignorance and useless posts regarding patents and the overall performance of rear-mount turbos. Keep it to a minimum and let the Thread starter answer relevant questions and (hopefully) post videos, dyno info, etc.
seven is offline   Reply With Quote
The Following User Says Thank You to seven For This Useful Post:
RAYSSPL (09-07-2012)
Old 09-05-2012, 10:10 AM   #65
FA20Club.com
Drives: 2013 White Out FR-S
Where Don's turbo mounts is where the cat used to be.
only the second is replaced the primary is retained because the factory header is reused. Same as with our soon to be released kit.
FA20Club.com is offline   Reply With Quote
Old 09-05-2012, 10:15 AM   #66
FA20Club.com
We use quite a bit of Comp Turbos here in house and the quality is top not. They are more prone to backpressure issues than Precision but their longevity is amazing even in journal bearing form. The response on the billet wheels is almost instant in comparison to the equivalent sized cast wheel version. We have been following the oil-less series some and they use an industrial grease and require periodic service from a grease gun. But the shear convenience makes it worth while if it within your budget. Some will praise other brands because thats what they know and hear about. But the rest of us who are deep into the industry will always test new products because id rather find something that works by testing it than jump on the new passing wagon.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
mastertech86 (09-05-2012), wcbjr (09-05-2012)
Old 09-07-2012, 07:57 AM   #67
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
This new turbo type interests me too
Toyota 86 test driver
Tradewind is offline   Reply With Quote
The Following User Says Thank You to Tradewind For This Useful Post:
Roadstercycle (09-07-2012)
Old 09-07-2012, 12:20 PM   #68
empower-auto
Kouki-Monster
empower-auto's Avatar
Hey, this car has tons of space for a proper turbo setup ... let's .... say F that! Gross
No reason to ever do this unless there's no room up front.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Boxer-86 (09-07-2012)
Old 09-07-2012, 03:57 PM   #69
Roadstercycle
Sorry about trying something a little different than the other guy's. I had a blast doing it and still am, what a difference in performance.
Old 09-07-2012, 04:00 PM   #70
Roadstercycle
I'll be at Crossroads in Torrance tonight if anyone wants to take a look.
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 04:11 PM
AUS turbo 86. vonreal FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 08-26-2012 08:31 AM
New rear spoiler choice: Carsmo rear spoiler Ray@Carsmo Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2012 03:20 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
