Old 09-02-2012, 11:10 PM   #43
Mild2Wild
Drives: Firestorm FR-S
Having a special use is one thing. Making it a habit is another. I can't think of a time when I want to be in 1st at high speed on the street when 2nd wouldn't do...
Mild2Wild is offline   Reply With Quote
Old 09-03-2012, 01:15 AM   #44
hybrid35
Drives: dd
We're just implying that there is more than one "proper" way to rev match, depending on your situation. I know OP asked for 4th to 3rd, but it really doesn't hurt to know for the other gears for different situations as well, as they are also "proper" in those situations.
Understanding clutchless and doubleshifting also helps you understand rev matching.
hybrid35 is offline   Reply With Quote
Old 09-03-2012, 08:32 AM   #45
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
*shrug* Every downshift I double-clutch. It's just plain better for the transmission.
Old 09-04-2012, 05:57 PM   #46
Ben_G
Drives: Blue BRZ
I'm actually a horrible rev matcher....if I don't double clutch. But for some reason, double clutching makes it easier for me. I'm sure its partly because I can get into gear easier, but partly I think its because the mid shift clutch forces my brain into analyzing the shift more, so I pay better attention to everything I do.
Ben_G is offline   Reply With Quote
Old 09-05-2012, 01:09 PM   #47
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
My old car had an extremely slow 2nd gear synchro. I double clutch rev matched every 2nd gear downshift.
Oddly I found it worked best when I was driving fast. The timing was easier and it was easier to make everything one seamless combination of movements when it all happened in a split second.
Nathan
SubieNate is offline   Reply With Quote
Match wheel weights to this list for me... DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-15-2012 01:58 AM
A proper test of the FR-S Vanguard Scion FR-S / Toyota 86 GT86 General Forum 2 03-19-2012 10:58 PM
Predictions on next REAL exciting Boxing match? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 1 09-28-2011 03:31 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 03:51 PM
