Old 09-02-2012, 02:32 PM   #43
baldolera
baldolera's Avatar
Drives: None Yet
I was never good with these models... kudos to the great build thread, looks awesome. Can't wait to see it done! The first, only, and probably last model I did was a C5 Corvette... I was like 10 years old and had no experience with spray paints, I held the nozzle 2cm from the body and the paint ran like it was raining. You're lucky too... you have a booth and spray gun.
Anyways I'm just waiting for Autoart, Kyosho, or any other good die-cast manufacturer to make one so I can buy one! (Looking to get 1:18 scale)
Originally Posted by LexusFman View Post
Nope because I have had Keichii Tsuchiya skills from the womb and I'm a beast at Gran Turismo. Reall cars can't be all different.
baldolera is offline   Reply With Quote
Old 09-02-2012, 03:53 PM   #44
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Last night i finished painting the rad and installed the sticker on the intake manifold.
Silverdub is offline   Reply With Quote
Old 09-02-2012, 04:08 PM   #45
ravenMTgirl
ravenMTgirl's Avatar
Drives: Raven FR-S
It looks great I bought one for my husband so we've been watching your progress!
ravenMTgirl is offline   Reply With Quote
Old 09-02-2012, 04:10 PM   #46
ayau
Drives: Some rust bucket
beautiful work. where did you buy the model?
Old 09-02-2012, 04:15 PM   #47
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Hope you guys have as much fun as i am.... I got the model from my local hobby shop but youcan find it on ebay as well im sure!
Old 09-02-2012, 04:24 PM   #48
ravenMTgirl
Drives: Raven FR-S
They have them on amazon too... but it's kind of expensive!
[ame="http://www.amazon.com/gp/product/B00829T1OC/ref=oh_details_o06_s00_i00"]Amazon.com: Tamiya 1/24 Toyota 86 Model Car Kit: Toys & Games[/ame]
Old 09-02-2012, 04:31 PM   #49
ayau
msrp is $65 according to tamiya's website.
http://www.tamiyausa.com/product/ite...oduct-id=24324
all the sellers on ebay are from either Japan or Hong Kong. you end up paying about the same if you buy it from a domestic store on amazon.
Old 09-02-2012, 04:32 PM   #50
ayau
@Silverdub, which parts do you recommend spray paint and which parts do you recommend for brush/paint?
Old 09-02-2012, 05:25 PM   #51
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i like to spray with my airbrush almost everything and then small details only with a brush. for example, the rad was spray painted but the fans were brushed... in the engine bay, only the oil filter and oil cap were brushed and same goes for the pulleys....all the rest is sprayed, i usually tape everything or use a product called maskol which is rubberish, you simply apply it with a brush on parts were you dont want the spray to stick and then peel it off... in the process you have to determine which colors will be done first...
i like to paint the light colrs first and dark colors last...an exception would be silver... silver sticks and looks so much better when applied on a black surface... when i painted the engine and fender liners, i started by priming everything in white, then i painted the whole part in red. once it was dried out, i taped up whatever was to stay red and then i painted the whole thing in black...once dry i taped up what was to be left black and sprayed the aluminum color for the engine. once dry, i removed all the tape and i brushed the green top plates yellow oil cap, and then mixed some red and white to get a kind of pink for the oil filter to mimick the HKS filters...
another trick is that once everything is painted and dry, i remove the paint where glue is to be applied, if not, parts will eventually fall off..
last note, whenever you are installing glass components, made of clear plastic, use regular white glue, this will prevent the parts from frosting... just use some masking tape to hold the parts in place till they dry and then peel away carefully... more to come if there is any interest!
The Following 2 Users Say Thank You to Silverdub For This Useful Post:
Dadhawk (09-26-2012), GaN-MaN (09-02-2012)
Old 09-02-2012, 05:26 PM   #52
travace
travace's Avatar
Drives: Scion FR-S
im looking to get back into this... got any suggestions on a good beginners air brush kit ?
travace is offline   Reply With Quote
Old 09-02-2012, 05:54 PM   #53
baldolera
baldolera's Avatar
Drives: None Yet
I'm very interested... can't wait to see it done.
Old 09-02-2012, 06:00 PM   #54
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i like badger, they are fairly cheap and pretty good quality but nothing close to an iwata...there is some single action and double action, i prefer double.. the single action airbrush will spray paint as soon as you press on the trigger and you have to change the nozzle to achieve a small or large spray pattern... a double action will only shoot air when you press on the trigger and then will let paint come out as you pull the trigger back towards you.. this allow you to do pretty much everything with a single nozzle
hope this helps!
GaN-MaN (09-02-2012), travace (09-02-2012)
Old 09-02-2012, 06:02 PM   #55
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
link to my airbrush: http://www.badgerairbrush.com/Badger_150.asp
Old 09-02-2012, 06:33 PM   #56
ayau
i just ordered the tamiya brz. the last time i built model cars was when i was probably about 8 years ago.
tamiya
Finally received my rear spoiler today Roadstercycle Cosmetic Modification (Interior/Exterior/Lighting) 6 07-12-2012 07:42 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Anybody in NorthCal? allocation? FRS received? tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 39 05-21-2012 10:40 PM
Just received my Beat-Sonic FR-S Antenna!! VADER Cosmetic Modification (Interior/Exterior/Lighting) 16 05-18-2012 08:08 PM
Received a BRZ brochure today terrypm BRZ First-Gen (2012+) — General Topics 8 03-11-2012 10:32 AM
