| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Nevermorange FRS
I think I'm going to do an install of this nature but instead of a radar detector I'm going to mount front and rear DVR cameras.
#30 | |
Drives: 2013 FR-S, 6MT, Ultramarine
Otherwise, if black is connected to black, and red to white, then you could have blown a fuse trying to install it.
#31 |
Drives: MT WRB BRZ Limited, 2007 911s
Turns out in my rush to finish (and the dark, I'm an idiot) I went black and blue, not white. Realized this morning, hooked up my detector to the cig lighter and it's not working. Hopefully all I did was fry the radar detector. This installation is not going to go down as my finest hour, but oh well, life goes on.
#32 | |
#33 |
It's a beltronics v940, can't find a small enough screw driver to get it open right now, but I've tried it in two cars and it is definitely the detector that's wrong.
#34 |
Took the detector apart, don't see any fuse, but the pins attaching the plug to the board, and the screen to the board have a brown liquid around them. I think I just chalk it up to stupidity and move on to just doing it in the glove box outlet and through the pillar like some others have.
#35 |
AutoX-10/10ths every run
My Install
Followed the directions here to tap into the existing wiring behind the light. I have a Beltronics 955: http://www.beltronics.com/store/vector-955.html and got the direct wire kit: http://www.beltronics.com/store/dire...tplug-red.html.
Snipped the + and - off the ends of the direct wire kit, and used vampire taps to connect them to the corresponding + and - on the factory harness. The direct wire kit comes with an inline fuse, make SURE if you wire your detector you put a fuse inline on the + lead to avoid having to buy a new detector if you screw up the wiring. I've already replaced the factory deck with a Pioneer P4400BH, so I wasn't using the factory bluetooth mic any more. Decided that I'd get out the dremmel tool and a zip tie to mount the direct wire kit onto the faceplate of the factory bluetooth mic. Here's some photos: ![]() ![]()
#36 |
Drives: Raven
Thanks for posting!
Just hooked up my Valentine. I didnt have a white wire, it was grey (see photo). Also, the vampire tap that comes with the V1 kit is too big for these wires so I used posi taps to hook it up. |
#37 |
Drives: 2013 JRSC Firestorm FR-S
Thanks for all the useful info! i just finished hardwiring my radar detector for my FR-S. VERY easy to do because of all the postings. Bought red the T-Tap connectors (telephone-tap connectors) for 18-22 gauge wiring from Radio Shack and used the t-taps to connect to the wires of the extra harness found above the map-light. Black was ground and White (looked more like grey) for +. Used the hard wire kit with built-in fuse I had ordered from my radar detector's web site. Threaded the wiring between the headliner and windshield with my fingers and connected to the radar connector. I found the hardest part was finding the extra harness itself (Found it reaching past the bluetooth mic secured with blue tape enveloped in grey foam). Disconnecting the map-light made it less cumbersome. It only took 5-10 minutes to complete. Thanks again to everyone for posting how to do this!
update: It's been over 2 years since the install and no problems with the t-tap connectors whatsoever. Last edited by Germanjap; 03-08-2015 at 05:44 PM. |
#38 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Just a heads up as I didn't see any info about this. T-Taps are not recommended by most people with electrical knowledge as they are unreliable and can fail in the long run (google it for more info). I was originally planning to T-tap it but I figured it wouldn't be too difficult to strip and solder the wire on directly and just electrical tape it for piece of mind.
#39 | |
Drives: Scion FR-S
After checking all vacant spots in the fuse box for a possible missing fuse for the harness I consulted with Lil Abner and he raised the possibility that I might have blown a fuse testing the connector for power. ... and that's where the problem was! I blew a fuse testing the connector . This is the same fuse that controls"Main body ECU and outside rear view mirrors". It slipped under the radar (no pun intended) because I almost never have to check the side mirrors.The fuse is in the box under the dash. Be prepared to do some yoga to get there. In any case is a 10Amp fuse (no. 1 on page 279 in the manual) |
#40 | |
Drives: White 2015 Series Blue BRZ SC
#41 |
Drives: 2017 86
Thanks for the write up, anyone know the part number of the mount that goes on the windshield for the mirror mount to connect to (lower left of this picture)
eBay seller sent me everything but the mount & screws. Found it here, had to buy it all but it's only 12 bucks. Last edited by e30cabrio; 06-11-2020 at 04:37 PM. |
| Direct wire radar detector | Kieranz | Electronics | Audio | NAV | Infotainment | 25 | 11-02-2015 01:01 AM |
| What will you hang from your rear view mirror? | Dillano609 | Scion FR-S / Toyota 86 GT86 General Forum | 148 | 11-15-2013 03:52 PM |
| Radar Detector? | Longhorn248 | Other Vehicles & General Automotive Discussions | 68 | 07-14-2012 05:31 PM |
| Mounting radar detector video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 06-07-2012 12:29 PM |
| Rear view Mirror pic | nixeighty6 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 45 | 01-27-2012 06:10 PM |
