Old 09-01-2012, 02:12 AM   #1
fiveoneoh
Drives: none
Did the issue with the air vents blowing hot ever get resolved?
I've read complaints about it on this forum for the brz/frs.
Does any one know what causes this? I do not remember my older cars (pre-2000) having this issue. The outside air always blew in cool, but my newer cars (post 2005) are warm/hot air.
Did something change in car design? Seems to affect all the various makes I've had experience with. Why won't they change it back!!
Apologies in advance if this has been resolved in a previous thread. I did do a search although admittedly, not a very thorough one.
fiveoneoh is offline   Reply With Quote
Old 09-01-2012, 04:42 AM   #2
fistpoint
Drives: Supercharged Golf Cart
I believe that is something you would see on the next model year or later, if ever.
fistpoint is offline   Reply With Quote
Old 09-01-2012, 04:58 AM   #3
TuxedoCartman
Drives: '13 86
It has been resolved! Turns out there's a button in the middle of the right-most knob that makes it blow cold air.
I kid, I kid. Smart-ass answer aside... no, there's no fix for this. Since I've started driving back in the early 90's,I've been in cars where the cold setting is almost as good as AC, and others where it's only marginally warmer than outside air... but none have been as bad as the 86/ BRZ. I'm guessing it's just a quirk of design. Personally, I haven't noticed it getting better or worse over the years; I guess we just drew a bad hand with this design. Maybe the only way they could work out how to get power to the rear wheels was by routing the exhaust through the air-ducts... who knows.
TuxedoCartman is offline   Reply With Quote
The Following User Says Thank You to TuxedoCartman For This Useful Post:
ragingSPAM (09-01-2012)
Old 09-01-2012, 05:46 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
It isn't an issue, its an intensional design, you can change it by the a/c controls.
Old 09-01-2012, 08:05 AM   #5
cgrey
Drives: 2013 Argento Silver FR-S
For this the Miata is infamous.
Here's the Miata cause and solution. It may or may not be related to our problem:
http://www.miata.net/garage/heater_cable.html
cgrey is offline   Reply With Quote
Old 09-01-2012, 11:07 AM   #6
RWD-boxer
RWD-boxer's Avatar
Drives: Black
When I beat on my car it smells like nail polish not sure why
RWD-boxer is offline   Reply With Quote
Old 09-01-2012, 12:27 PM   #7
4U-GSE
Drives: 2013 Scion FR-S MT Ultra Marine
All you have to do is hit the recirculate air button on the left knob.
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE
4U-GSE is offline   Reply With Quote
The Following 3 Users Say Thank You to 4U-GSE For This Useful Post:
CrazyWookiee (09-04-2012), dori. (09-01-2012), Splat (09-01-2012)
Old 09-01-2012, 01:23 PM   #8
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
+1 the guy above me ^^
recirculate instant fix.
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
The Following User Says Thank You to Carban For This Useful Post:
dori. (09-01-2012)
Old 09-01-2012, 03:25 PM   #9
chitownwrx
Drives: WRX
Subaru thing
I don't know if this is related, but there is a known gremlin with some WRX's (and other Impreza variants) that is similar. The driver side foot vents always blows hot, unless the AC is on. I have not heard of a TSB or a real fix. Lots of Subaru DNA in the FR-S / BRZ twins, I guess.
chitownwrx is offline   Reply With Quote
Old 09-01-2012, 03:27 PM   #10
_F-R-S_
Drives: 13 whiteout scion frs
pftt u think thats bad i got smoke coming outta my vents when turning air on.
_F-R-S_ is offline   Reply With Quote
The Following User Says Thank You to _F-R-S_ For This Useful Post:
Carban (09-09-2012)
Old 09-01-2012, 03:30 PM   #11
jarviz
jarviz's Avatar
Drives: Raven FRS MT
I used to notice it a lot more. I think the more I broke in the car the better it got. Now it shoots out warmish-cool air, but it's also 90 degrees here everyday.
jarviz is offline   Reply With Quote
Old 09-01-2012, 05:07 PM   #12
elenien
elenien's Avatar
Drives: Raven Scion FR-S MT
Hm.... I found the air coming from the vents was much warmer with the recirculate air ON (which was on from the dealer). My problem with the air from the vents improved when I turned it OFF.
2013 Scion FR-S, Raven
1995 Honda Prelude
1991 Nissan 240sx Fastback
elenien is offline   Reply With Quote
Old 09-01-2012, 06:04 PM   #13
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
with the air controls off I turned the temperature control all the way to the left (cold, far right knob) and the warm air stopped.. I don't know if something is still activated when ALL of the buttons are off but it mysteriously worked..sorry if that sounds stupid.
CoRi J is offline   Reply With Quote
Old 09-01-2012, 07:08 PM   #14
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I've had 105+ degree weather here and the A/C works great. Set it on recirc first. I think if the car sits in the heat for awhile the vents get warm. Once the A/C is going they cool off. This has happened with several of my cars.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 11:58 AM
changing the side vents? Tylub Cosmetic Modification (Interior/Exterior/Lighting) 1 08-31-2012 08:20 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
a thought about the warm air coming from the vents... pr086 Scion FR-S / Toyota 86 GT86 General Forum 32 08-02-2012 10:06 AM
Does anyone know Part Number for side Vents?? stevo_12v Cosmetic Modification (Interior/Exterior/Lighting) 2 05-16-2012 10:30 AM
