Old 08-31-2012, 09:12 PM   #29
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
It adds 10+Hp and 7lb torque
who cares about a vid for sound i want before and after dyno results.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
The Following User Says Thank You to DriftEightSix For This Useful Post:
ngabdala (09-01-2012)
Old 08-31-2012, 09:21 PM   #30
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Originally Posted by ngabdala View Post
There's no point in buying an intake without a tune for it.
You can get the same performance by buying an aftermarket air filter and putting it in the stock intake. Believe it or not but the stock intake is good. Change the filter.
I'm sorry, but that is a ridiculous statement.
Symbiont is offline   Reply With Quote
The Following User Says Thank You to Symbiont For This Useful Post:
GenkiElite (08-31-2012)
Old 08-31-2012, 10:44 PM   #31
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Originally Posted by GodSays View Post
Injen dynos with the hood up
Most people do in order to help simulate the cooling effect of driving down the road at X speed as well as having a large fan but usually the fan isn't enough. Why thumbs down?
GenkiElite is offline   Reply With Quote
Old 09-01-2012, 12:21 AM   #32
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I disagree man. These need a proper tune to harness anything better than the stock intake with an aftermarket high flow filter.
You didn't quote everything I wrote so I wonder whether or not you stopped reading at that point.
The rest of it was this " Believe it or not but the stock intake is good. Change the filter.
Buy the tuning kit and wait to see who makes the best intake based on the tuned results. Save your money. Also , do the same with the exhaust and wait. The cost of an intake is 33% the cost of the tuning kit. "
That's why I will be waiting to see the numbers of all the intakes with a proper tune to determine which intake I want.
It's very possible by the time that happens I will be adding a turbo which means the intake was a waste of money as it will have to be removed.
If I stay NA I am waiting it out.
Sorry to tell ya you're not getting the advertised numbers provided for your intake. They will be better down the road when you have the ECUtek Tuning Kit and can get true performance increases from it and an aftermarket exhaust.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-01-2012, 12:24 AM   #33
ngabdala
Did you re-insert the MAF sensor? If you did you may not have a tight enough fit at the throttle body and/or where the box attaches to the front of the engine bay. Disconnect then re-attach.
Do you have an oiled filter or is it a dry one? An oiled filter could throw a CEL but not always.
Originally Posted by Flako View Post
I just installed my injene air intake but now my check engine light is on and the codes won't erase, they say permanent?
Old 09-01-2012, 03:38 AM   #34
Symbiont
Tall guys fit, too.
Symbiont's Avatar
I quoted what I did because it was an inflammatory statement not backed up by numbers. Misinformation is the bane of forums like these, and you're perpetuating it.
I did independent pulls at another tuning house here in the OC and saw exactly what I saw when my car was being used for the research at Injen. You have no idea what you're talking about.
I'm not running an intake at all right now, actually. I'm stock with the tune, but the intake pulls much better numbers, untuned, than any filter does. To say otherwise is a blatant lie. I'm sorry to see you doing that.
Changing the filter is purely a placebo. There hasn't been any dynos that have shown any consistent gains other than normal variance between pulls. Please do your research before spouting tripe.
Personally, I don't care what you do with your car, but don't trumpet your opinion like it's a fact. In the end, you're only hurting your credibility and providing misinformation to those who don't know better.
Old 09-01-2012, 03:59 AM   #35
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Ever see this thread? http://www.ft86club.com/forums/showt...ht=filter+test
sho220 is offline   Reply With Quote
The Following 4 Users Say Thank You to sho220 For This Useful Post:
jamesm (04-02-2013), ngabdala (09-01-2012), Sportsguy83 (09-01-2012), Username (09-04-2012)
Old 09-01-2012, 07:21 AM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
While it is true that the current aftermarket intakes are not EXACTLY the same as adding a drop in filter, I clearly see ngabdala's point. Go and look at Injen/Airaid's Dyno sheets. They are very unimpressive in the sense that yes, there are gains at some points in the curve but in a lot of other places the curve even goes below stock!
I am sure those curves would change to be on the positive side with a tune. His point is, a tune would make anyone of the intakes better and that's true. He also points out the best thing to do right now is to wait and see what comes down the road which is another accurate and positive thing to say, no misinformation whatsoever. Also, please take a look at FT-86 thread on drop in filters, they saw a peak 5 HP on practically every drop in filter, that seems like consistent results.
Like you said, everyone is entitled to do whatever they want to their car, but he does make some good points.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 09-01-2012, 07:40 AM   #37
gmookher
forget sound
seeing power gains?
I'm convinced the stock air box can flow better with a foam filter like perrin, sio i wanna see real gains before I put down coin, sound is unimpressive
Horsies float my boat tho
The Following 2 Users Say Thank You to gmookher For This Useful Post:
ngabdala (09-01-2012), scottman (09-06-2012)
Old 09-01-2012, 09:09 AM   #38
ngabdala
Inflammatory remark? Only the inflammatory would see an opinion that way.
I was aiming to educate others and in the end it is their choice. I question whether or not you are able to see the positive.
If it's not for you it's not for you. You did write it is a "ridiculous statement." Rather than add fuel to your ignorant and inflammatory statement I replied "I disagree dude."
Take a look inside rather than project your negative qualities on others just to feel good about yourself. It doesn't work.
Anyways, I hope you feel better. Let's just agree to disagree and not derail or lessen the quality of the thread.
Best wishes man
The Following User Says Thank You to ngabdala For This Useful Post:
Strife26 (11-16-2016)
Old 09-01-2012, 01:14 PM   #39
tnt
Drives: argento frs at
You all have good points ...
tnt is offline   Reply With Quote
Old 09-01-2012, 09:39 PM   #40
Flako
Drives: Asphalt scion frs
Yea I checked everything the check engine light turned off but its still pulling two codes that say permanent ????? Help?
Flako is offline   Reply With Quote
Old 09-01-2012, 09:53 PM   #41
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Originally Posted by R2RO View Post
Well i really don't believe the manufactures claims, but im thinking it bumps the Hp up 5-9 hp and 4-7lb of torque. But im going to dyno my car, when i find a dyno shop with the OEM Intake and this injen one.
Please tell me where you are purchasing your drugs, I need to get some of whatever it is you are smoking.
No intake is going to be giving you anywhere close to 9HP and 7lb/ft of torque.
Your car might "feel" faster simply due to the sound an intake offer, but I can assure you that 99% of that is completely a figment of your imagination.
knapper is offline   Reply With Quote
The Following User Says Thank You to knapper For This Useful Post:
Old 09-01-2012, 09:56 PM   #42
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
jerk
Sall is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 08:02 PM
Injen Short Ram Air Intakes w/MR Technology in Black/Polished FREE SHIPPING!! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 49 09-05-2013 09:22 AM
MPG: INJEN Short Ram Intake Sale Jeremiah@MPG Engine, Exhaust, Bolt-Ons 6 08-09-2012 12:42 PM
