Old 08-30-2012, 07:39 PM   #57
zoomzoomers
zoomzoomers's Avatar
Originally Posted by daiheadjai View Post
Isn't this a fail-safe installed in the wake of the mythical Sudden Unintended Acceleration "problem" that the U.S. gov't found with Toyotas?
I believe someone mentioned that before...
^ that is exactly why they do this on newer cars.
Originally Posted by sho220 View Post
Tell that to these "ladies"...
Old 08-30-2012, 07:50 PM   #58
Sasquachulator
Pavement Grey
Originally Posted by K2wings View Post
Did you actually know that it's not an AT, its a semi-manual. You can shift like a manual, it's the same. Actually, it's better, since you can't miss your gear like in MT.
It's an automatic like in a minivan, or any other car with an automatic transmission that isnt a DSG/SMG/dual clutch system.
It's just set up in a different way than those automatics.
And it all came from the Lexus ISF.
The ISF came out amidst some criticism that it was getting an 8 speed automatic transmission to take on the germans with their dual clutch boxes. And the fear was because its an automatic, its automatically gonna suck when it comes to shifting via paddles or +/- on the shifter (because up until the ISF all paddle shifted automatics have been pretty much garbage in the shifting response/time/feel department)
But Lexus did something clever, it locked up the torque converter in 2nd to 8th gear so that gear changes dont have that delay that all other autos have (or whatever technical mumbo jumbo this involves). this allows the transmission to work very similar to a dual clutch system without being a dual clutch system. i think one drawback to this system is that you still get the typical automatic transmission parasitic drivetrain power loss that is higher than in a clutch based transmission.
they adapted this system into the FRS/BRZ transmission so it functions the same way. Note it is NOT the 8speed lexus transmission with 2 gears lopped off.
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem with Toyotapartsoutlet.com BRZranger User/Vendor/Sponsor Reviews, Feedback, Comments 11 08-09-2012 01:20 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
