#57 |
Drives: race cars
I think it depends on your application. For the track, the 2.5 deg we have in the back actually makes the tire temps pretty even on RS3's on the track. If you are managing tires to temps, this is the right range on track...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
#58 | |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
So for everyone I've didn't installed the arm finally. To make a long story short, I've installed them and go to an alignement shop, they claim to be able to align these arm but that was false and they fucked up my arm ( paint and nuts! ) So they "rebuild" them and I'll just sell it. I've align it on an other shop and the guy did a great job with the OEM arm. So I'm at -2.6 -2.7 app on the rear. I've put it on the track and seriously it handle perfectly ! And don't forget I'm still on OEM tires. I can't push it too much because the tires are always at theirs limits but still I can have plenty of fun on the track! I'm really suprise. Plus, the BC's are sooo great! I've put them to F 15 R 15 for the setting and it's perfect, it absorb where it need and it's stiff where it need. On the street, yeah it's a little bit more stiff but nothing crazy still close to OEM ride.
#59 | |
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
http://www.whiteline.com.au/product_..._number=KCA326 From the numbers you posted earlier these would be perfect. |
#60 |
Drives: '13 10 Series FRS #1203
Holy fuck the misinformation in the start of this thread is unreal. If you don't know with a reasonable amount of certainty. Don't talk please.
| The Following User Says Thank You to Shady195 For This Useful Post: | GeorgeJFrick (04-06-2016) |
#61 |
Drives: 2015 CWP BRZ Limited
#62 |
#63 |
Drives: 2013 FR-S Argento
Let's revive shall we - can anyone give a technical explanation why -2.5 degrees of rear camber is such a bad thing when it comes to handling at the track? Especially when you have that much or more front camber to balance things out?
#64 | |
TRACKBREAD
Sent through a series of tubes |
#65 | |
Drives: 2017 BRZ
| The Following 2 Users Say Thank You to cjd For This Useful Post: | strat61caster (04-10-2016), Yoshoobaroo (04-10-2016) |
#66 | |
TRACKBREAD
#67 |
Thanks for the feedback guys - one more question. Does the multi-link geometry in the rear have a consistent camber change rate or is it optimized for factory height? I.E. from stock height to say 2" compression does the rate of camber change remain the same as if you lowered the car 2" (coilovers) and then compress the suspension another 2"?
#68 | |
TRACKBREAD
To directly answer your question, it is optimized for factory ride height. Then again, more camber in the rear is not necessarily a bad thing, as it can be corrected or balanced out from the front. |
#69 | |
Sent from my SM-N920V using Tapatalk |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | Yoshoobaroo (04-11-2016) |
#70 | |
TRACKBREAD
Like this: http://blog.caranddriver.com/a-tale-...-so-different/ Sent through a series of tubes |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | bfrank1972 (04-11-2016) |
| RS*R Sports-i Coilover system installed (pics) | R0ME0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 139 | 02-05-2015 03:38 PM |
| Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 06:51 PM |
| Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 10:09 PM |
| Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 10:30 AM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
