Old 08-29-2012, 11:09 PM   #29
pinoyplaya
Drives: WRB MT-BRZ LMTD
Woot I get mine this friday, its not the II one but its the first one. Both are pretty much the same anyway but one has better operation temperature range and compression. But other than that, meh.
Cant wait for mine to arrive!
I do wanna hotwire it but I dont know how
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-30-2012, 02:22 AM   #30
drifter
Drives: truck and old car
I had my stereo guy wire it to the fuse box. Most auto stereo shops do this, I paid like $30 just because I didnn't wanna mess with it, eventhough i'm told it's easy to do yourself.
drifter is offline   Reply With Quote
Old 08-30-2012, 08:09 AM   #31
pinoyplaya
Did you check out how it was done?
Old 08-30-2012, 09:23 AM   #32
Foobar
SLO NO MO
Foobar's Avatar
J
Just pick up a mini add-a-circuit (aka add-a-fuse) http://www.parts-express.com/pe/show...number=071-585 from your local auto parts store, amazon, ebay, etc.
Pick any existing 10AMP fuse in your fusebox, pull it out, plug in two 10AMP fuses to the add-a-circuit. Plug the add-a-circuit into the now-empty fuse receptacle. Now you have a spare power lead that is protected by its own fuse. Run your camera wire to that, and ground it to any bolt near the fuse box (there's one conveniently right in front of the box towards the firewall).
Old 08-30-2012, 01:03 PM   #33
AJUSA.com
AJUSA.com's Avatar
The things that go on when you are not around. Sure gets a lot of attention!
AJUSA.com is offline   Reply With Quote
Old 08-30-2012, 01:27 PM   #34
drifter
As "FOOBAR" mentioned; I believe they ran the wire on inside the panelling, starting up by the rearview mirror, then down the drivers side to fuse box, so you don't see any wire.
You do know you can also plug it in your lighter for starters, if you don't mind a wire showing.
this is a great video review that explains how to set it up and also a forum that answers tons of questions:
http://forums.redflagdeals.com/merge...hread-1147913/
Old 08-30-2012, 03:06 PM   #35
xjohnx
Grip>Slip
xjohnx's Avatar
You can still do this without the wire showing, just route it around the headliner, down the passenger a pillar and plug it into the cigarette lighter outlet that is in the glovebox.
Old 08-30-2012, 03:18 PM   #36
bakilman
bakilman's Avatar
Drives: White FR-S
Drifter, Is this in Monterey?
bakilman is offline   Reply With Quote
Old 08-30-2012, 04:30 PM   #37
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Mine was 50 bucks on ebay, and works fine. Blackviews are actually worth stealing which kind of defeats the point. Auto on/off and looping recording on the memory stick are all you need.
Khyron686 is offline   Reply With Quote
Old 08-30-2012, 08:10 PM   #38
pinoyplaya
Currently I have mine plugged in to the glove box power and wires are hidden using the headliner and the rubber thingy.
But I would like to use the parking features XD
Ill figure it out. For now, glove box power is temporary solution.
For some reason, the quality isnt as good as I thought it was going to be.
Old 08-30-2012, 10:18 PM   #39
drifter
Yup, that part was Pacific Grove, next to Monterey.
Well, they better make sure they complete the job or they will be on youtube for the world to see. Also, if anyone gets one, make sure you go into the set up menu and disable the "park mode light". Otherwise when parked, you will see a glowing light which could attract unwanted attention.
Old 08-31-2012, 12:48 AM   #40
cgrey
Drives: 2013 Argento Silver FR-S
Should we keep adding to this thread or start an official video thread?
Here's one from this morning:
[ame="http://www.youtube.com/watch?v=4QD-CY4P2_4"]http://www.youtube.com/watch?v=4QD-CY4P2_4[/ame]
cgrey is offline   Reply With Quote
Old 08-31-2012, 02:22 AM   #41
drifter
^ Only problem with that vid is it looks like you may been going a little to fast. I didn't see the MPH in vid.
Old 08-31-2012, 03:08 AM   #42
Maps316
Maps316's Avatar
Drives: Nissan Altima
Do you have a link to it by any chance?
Maps316 is offline   Reply With Quote
Anyone use a dash cam? hansthegerman Electronics | Audio | NAV | Infotainment 54 01-12-2019 01:58 AM
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Dash Kits? KRAZYK Electronics | Audio | NAV | Infotainment 10 03-11-2013 10:49 AM
What do you use to wipe off dash? Memphis Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 08-22-2012 10:40 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
