Old 08-28-2012, 04:40 PM   #155
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
whos finger was that?
Silverdub is offline   Reply With Quote
Old 08-28-2012, 09:02 PM   #156
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
And so, the balloon gets bigger
The record was 403 now its 429 on the other side of the field.
Who's going to 450+ ? Will it be P&L, AP or who?
Seems like it will only take another week to find out - where the massive first explosion will occur - someones gotta do it lol
Some of these turbochargers will be maxxing out too now, must be time for another retrim to provide yet higher airflows ??
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 08-28-2012, 09:10 PM   #157
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I'm waiting for someone to post. "New record, 600hp!"
The Following User Says Thank You to dem00n For This Useful Post:
enjoi23 (09-23-2012)
Old 08-28-2012, 09:21 PM   #158
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
I want to see more driving videos
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 08-28-2012, 10:07 PM   #159
Synack
Boosted
Synack's Avatar
Drives: Sideways
Did you guys ever test at 4 or 6psi on 93 octane? If so, results?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-28-2012, 10:22 PM   #160
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by Calum View Post
Tilted like that allows the air intake to line up with the pass through in the rad support while also giving a better angle for the exhaust outlet. And it looks cool.
I'm loving that manifold, equal length or close, no oil pump required, easy access to the turbo, the turbo is away from water and debris... VERY nice work guys.
I would rather have the intake give a slight curve in the piping rather than tilt the turbo up, since oil is gravity fed/drained. Interested to see how this performs over time.
These cars are making great power though for sure.
SnapOv3st3r is offline   Reply With Quote
Old 08-28-2012, 10:31 PM   #161
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
230ish @4 psi on 93.
Hawaiian is offline   Reply With Quote
Old 08-29-2012, 12:11 AM   #162
nytfury
Drives: Whiteout FR-s
I am very stoked for this kit guys!!!! Count me in when your ready!,,,,
nytfury is offline   Reply With Quote
Old 08-29-2012, 05:51 AM   #163
Calum
That Guy
Drives: 2013 asphalt FRS MT
I hope we hear from P & L about this, but I highly doubt the oil is gravity fed. It would come off the engines oil system and enter the turbo pressurized. With this turbo location, unlike the others we've seen, this turbo is likely gravity drained back to the oil pan.
The center section, with the bearings and seals, is the only section that is lubricated with oil so the angle shouldn't cause oil to pool in one side vs the other.
Old 08-29-2012, 06:36 AM   #164
SnapOv3st3r
I was only referring to the drain, sorry for any confusion. Unless turbos come with internal oil pumps in recent time, there is nothing inside of the CHRA that releases or forces the oil to drain into the oil pan other than gravity and a clear unrestricted path to the pan. If its tilted I don't see how it is free flowing to the pan. I get the idea that it would pool when the you are done driving and shutting down.
This would be the first time I have ever in my life seen a tilted turbo on any application. So I'm curious to hear thoughts from P&L also.
Old 08-29-2012, 07:30 AM   #165
Tradewind
Some aircraft turbos are tilted crazily - check a few out
Old 08-29-2012, 07:44 AM   #166
SnapOv3st3r
We aren't in aviation though...
Old 08-29-2012, 07:47 AM   #167
SiilvA
Drives: Mitsubishi FTO
but i thought this thing would fly?
SiilvA is offline   Reply With Quote
Old 08-29-2012, 09:27 AM   #168
SnapOv3st3r
Lol...
SRT FR-S/BRZ Full Exhaust System ... Sneak Peak! Swift Racing Technologies Engine, Exhaust, Transmission 1113 11-16-2013 07:11 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 07:27 AM
Sneak peak at first Aussie turbo kit MZ21 AUSTRALIA 133 09-22-2012 03:45 AM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 01:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 11:13 AM
