Old 08-27-2012, 05:19 PM   #43
JWA
Drives: BRZ, Exige, Boxster
Boyo makes a couple nice HD cameras that use a single thing cable to go up to the head unit so that you can draw power there. Not cheap, but nice. Those might work well here.
I'm looking forward to a custom kit for this. Picking up my BRZ on Sat.
JWA is offline   Reply With Quote
Old 08-28-2012, 02:20 PM   #44
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by sparks View Post
@Will - The audio amp in the trunk has a 10 pin connector, pin 8, green wire, looks like a remote turn on from the HU.
"AMP+ OUT Amplifier signal"
1 2 - - 3 4
5 6 7 8 9 10
I ended up running the power wire to the radio and tapped pin #3 which was radio ACC wire. I believe it was red but I dont remember for sure. This worked great and now the camera works perfectly with no issues.
Flat Black VW is offline   Reply With Quote
The Following 2 Users Say Thank You to Flat Black VW For This Useful Post:
Floggin Tires (09-01-2012), sparks (08-29-2012)
Old 08-28-2012, 02:31 PM   #45
xjohnx
Grip>Slip
xjohnx's Avatar
HD cameras? Not that our head unit's display is capable of outputting HD resolution anyway, but what sort of medium is this HD video transmitted? Not sure we have component or HDMI inputs
Old 08-28-2012, 02:42 PM   #46
jpit
Drives: Subaru BRZ
I hooked mine up to the remote wire which was going to my subwoofer anyway.
jpit is offline   Reply With Quote
Old 08-28-2012, 04:40 PM   #47
JWA
It's just a single RCA. They output an NTSC 680(H) x 512(V) picture and have a high quality CCD. Most of the cheap backup cameras use very low res cameras with crap contrast.
Old 08-28-2012, 04:41 PM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
Ahhh, gotcha. Companies have been abusing the hell out of the term "HD" lately.
Old 08-28-2012, 04:44 PM   #49
JWA
True, in this case it's relative. They are noticeably nicer cameras though. Good picture at night, lit with the reverse lights on the car.
Old 08-28-2012, 04:48 PM   #50
xjohnx
Grip>Slip
xjohnx's Avatar
I wonder how the "HD" resolution works on the stock display (with it's glorious 480x272 resolution.)
Old 08-29-2012, 12:22 AM   #51
jpit
Drives: Subaru BRZ
Flat Black VW - I got into the settings menu but don't see an option to adjust the lines. What option is it under? Thanks.
Old 08-29-2012, 08:11 AM   #52
sparks
sparks's Avatar
Top of the screen should say Line Diag and lower left should have camera settings.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-29-2012, 12:15 PM   #53
jpit
Drives: Subaru BRZ
I wonder if I have a different software. When I go into the hidden menu I see three choices: Failure Diagnosis, Function Check/Setting and Service Information. None of the sub-menus mention the camera. Under the Function Check it gives an OK for rear camera but that's it.
Old 08-29-2012, 12:25 PM   #54
sparks
sparks's Avatar
That is a different menu. With the HU on, push and hold the top button, then puch and hold the other 2. The menu should come up.
The Following User Says Thank You to sparks For This Useful Post:
BRZranger (10-13-2012)
Old 08-29-2012, 12:58 PM   #55
djdnz
1337
Drives: 2013 BRZ WRB S/C
When someone gets to doing a DIY, can you word it extremely simply and show lots and lots of pictures? I always feel uneasy when tackling electrical projects, because I have very little experience with them.
Lots of pictures would be excellent, and say "plug this pin here, solder this here, cut this exact wire here etc".
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Vlad (10-02-2012)
Old 08-29-2012, 03:10 PM   #56
sparks
sparks's Avatar
This will be one of the easiest DIY's I've done in years. Add 2 pins, run a video cable, power the camera, mount the camera.
I'll try to remember to "keep is simple stupid" when the write up comes
The Following 3 Users Say Thank You to sparks For This Useful Post:
djdnz (08-29-2012), RYU (09-09-2012), zoomzoomers (08-29-2012)
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
