Old 08-27-2012, 08:19 PM   #57
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
those are some really good 60fts. Im getting 60fts of 2.3 and trapping speeds of 94mph, and my best time out of the two runs was 15.1.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 08-28-2012, 02:17 AM   #58
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Thanks for the update but this isn't correct.
After ecu reset the car does not run max advance..
The ignition logic is 100% what subarus have been using for over 10 years.
John
Dyno says otherwise. So do our. 1/4 mile times (best time we ran were 2 and 3 pulls after an ECU reset).
I see zero evidence of any claims to the contrary. Again - the long and short term ignition trims are right there in the stock data list to be viewed with a Toyota Techstream scan tool. I think I'm going to believe that and the actual evidence until someone proves different.
Boosted2.0 is offline   Reply With Quote
Old 08-28-2012, 02:19 AM   #59
Boosted2.0
Boosted2.0's Avatar
Thanks!
Old 08-28-2012, 08:55 AM   #60
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Is there a chance the ignition tables are set at a pre-determined level from the factory, but that level not at 100% advance?
I would be a bit concerned if a car came factory with full-advance, because a lot of dealers don't fill with 91 octane straight off the lot.
I'm thinking the default values are higher than what the computer whittles it down to, but not at maximal values.
Coheed is offline   Reply With Quote
Old 08-28-2012, 09:05 AM   #61
Visconti
Drives: 05 STi
This is how it works :
http://www.romraider.com/forum/topic1840.html
Visconti is offline   Reply With Quote
Old 09-01-2012, 09:43 PM   #62
artizhay
artizhay's Avatar
Drives: Scion FR-S Firestorm MT
Send a message via AIM to artizhay Send a message via MSN to artizhay Send a message via Yahoo to artizhay
Good to see you in the FR-S market, Boosted. I remember you from New Celica. Sort of off-topic I guess, but are you guys making an exhaust manifold for the FR-S? Been following the FR-S section of your store daily to no avail. :p Will be sending you a PM about some other things as well.
artizhay is offline   Reply With Quote
Old 09-01-2012, 10:57 PM   #63
xwd
People like Visconti are looking at the actual maps...Have heard from multiple sources as well it's a Subaru Denso ECU and works just like all of the others for most of its operation.
Old 09-02-2012, 12:09 AM   #64
Illusive
Drives: 2005 Subaru STi
Just to be clear, the toyota tech stream data IS the OEM datalist and not an interpretation of the datalist.
Illusive is offline   Reply With Quote
Old 09-02-2012, 09:57 AM   #65
Visconti
Drives: 05 STi
The EcuTek software has the OEM datalist , it's not a interpretation.
How do you think EcuTek is able to launch their product and on day one fully supports all ECUs in all regions? Where do you think EcuTek gets all the stock roms from lol?
They also have other datalist items that the tech stream or other dealer tools do not have.
John
Old 09-02-2012, 01:13 PM   #66
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Thanks!
[ame="http://www.youtube.com/watch?v=Hd85z8DPhas"]2ZZ DD Performance Research Prototype Intake Manifold Dyno Pull - YouTube[/ame]
we need this!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 09-03-2012, 03:04 PM   #67
Boosted2.0
Boosted2.0's Avatar
I am aware. But those ignition trim values on the Toyota scantool should read 0 if they did not exist. And the car should have LOST power after the ECU reset.
So far this car behaves EXACTLY like Toyota ignition logic by any measurable test you can perform. I can't tell you why that is, but seeing as how ECU TEK doesn't seem to know either - I challenge you to come up with a better explanation for its behavior.
And yes, this is a Denso ECU with a Subaru P/N
Old 09-03-2012, 03:06 PM   #68
Boosted2.0
Boosted2.0's Avatar
Originally Posted by carbonBLUE View Post
we need this!
Working on something better
The Following User Says Thank You to Boosted2.0 For This Useful Post:
carbonBLUE (09-03-2012)
Old 09-03-2012, 03:09 PM   #69
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Do tell! That intake manifold was/is a great product for the 2zz.
Hope that you will be supporting NA mods for this platform.
uspspro is offline   Reply With Quote
Old 09-03-2012, 03:54 PM   #70
Visconti
Drives: 05 STi
Ecutek doesn't seem to know?
I do a lot with these car but I'm certainly not giving away everything I know or do.
I don't even know why you continue to argue with me. I see what's happening your GUESSING..
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
When will magazines start testing the performance? swift996 BRZ First-Gen (2012+) — General Topics 10 03-23-2012 02:10 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
