| View the official forum sponsors list |
#15 |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
What type of installation instructions do these come with?
#16 | |
The HID kits are 100% plug and play, so its mostly self-explanatory. However, we will be happy to provide instructions for you with whichever product you order. We can also tell you the easiest/best way to remove anything on your vehicle prior to install to help make this an easy and smooth experience.
#17 |
Drives: 2023 WRB BRZ (MT)
about the switchbacks...
1. for my FR-S a set with resistors is $26, correct? 2. does setup look lik this? bulb-->resistor-->plug/wire |
#18 |
Drives: 13 Argento FR-S, 06 F-350, 97 240sx
#19 |
Drives: WRB MT-BRZ LMTD
Damn thats awesome. It turns yellow/red for the turn signals and brakes and etc?
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#20 |
Enthusiast
Drives: 2013 Scion FR-S (37J)
Got the DRL LEDs, great quality, fast shipping, and fantastic to work with thank you Lisa!
![]() Last edited by BigJyoungblood; 08-27-2012 at 04:22 PM. Reason: Added Photo |
#21 |
Drives: White Lancer Evolution X
I see that you have a diagram for the rear turn signal LED's but I didn't see any pricing/description. How much are these?
And regarding the resistor; do we need to cut wires for this? The warning seems to warn against mounting the resistor in the harness. Any other options to get normal blinking speed? |
#22 | |
The rear turn signal L.E.D.'s are $12 each. I thought those were in the original post, i guess they got left out somehow. we will update it. Thank you for noticing that. For the resistor wiring, no wires need to be cut. the resistors come with "splice crimps" for easy reversible installation. The resistor housing has holes for mounting them on the vehicle body. The reason behind the warning of not mounting them on plastic is because they do run warm since power is transferring through them and different thicknesses and types of plastic may melt, so in order to make sure that doesn't happen we recommend not mounting them on plastic. As far as other options to obtain a "normal" blinking speed, there are replacement flasher relays that we are trying to obtain to supply to you all. More info on those will be available one we have them in hand. |
#23 |
Drives: 2013 FRS Whiteout
Sorry for souding like a total newbie but after all the work i put into cars, i have never switched a bulb on one. I wanted to replace the DRL, it seems your LED is like a regular bulb? So when i bolt this in there the DRL will be brighter and white, how about the high beam, or this had nothing to do with the high beam?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#24 | |
OH HEY NOW!!!!
Drives: 2013 Scion Fr-s Asphalt
#25 |
Non member
Drives: Red fr-s
Pm sent
Project Baby supra in progress....
#26 | |
All PM's replied! |
#27 | |
#28 |
Drives: 2013 86 white
I want the DRL but make sure it at about 6000k color to match my current lowbeam with 6000k hid kit.
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 01:19 AM |
| Automation Lighting offers LED interior/exterior kits | jjdrivesajazz | Interior Parts (Incl. Lighting) | 393 | 10-11-2013 10:49 AM |
| HID PnP Kits | engee | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 02-05-2013 04:29 PM |
| HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ | KI_ZN6 | CANADA | 2 | 07-27-2012 05:13 PM |
| NA engine kits? | Levi | Engine, Exhaust, Transmission | 36 | 11-17-2011 11:45 PM |
