View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-25-2012, 08:24 PM   #799
zoomzoomers
zoomzoomers's Avatar
Damn. Looks like my motor just started chirping. It comes and goes. Or at least I think so, but it's definitely there. I just past 1,000 miles too.
Old 08-25-2012, 08:25 PM   #800
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by clzzical View Post
It'd be interesting to know if the BRZ owners in Japan are experiencing the same things. Anyone keeping up with the Japanese forums or have updates?
In any case, it's good to hear a TSB is in the works for the fuel injectors. Thanks for the good news!
It seems to be the HP fuel pump rather than the injectors.
"I think the theory on ethanol free makes sense. I searched Yahoo Japan on this chirping issue to see if anyone in Japan is getting it, but apparently no one has even heard of the problem there. This is probably because they only use pure gas over there in Japan."
sierra is offline   Reply With Quote
Old 08-26-2012, 01:26 AM   #801
KevinR
Drives: 1993 Turbo Miata, 2013 Asphalt FR-S
I find it weird that after autocross today in 95 degree hear there was no chirping. Only seems to happen after long leisurely drives. Didn't happen between runs for me.
Sent from my ADR6300 using Tapatalk 2
KevinR is offline   Reply With Quote
Old 08-26-2012, 02:01 AM   #802
sierra
Maybe when the engine's working harder at higher rpm, with the direct injection operating, the fuel flow through the HPFP keeps it cooler?
Then when you're cruising at lower rpm, with just the port injectors operating, the HPFP heats up with no fuel flow and engine heat soak?
Old 08-26-2012, 04:42 AM   #803
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
you would be correct sir, the TSB will supposedly change the fuel pump, this is just hearsay for now, we shall see what they change when the time comes. I have faith that Toyota knows the problem and are doing their best to fix it
thatWESguy is offline   Reply With Quote
The Following User Says Thank You to thatWESguy For This Useful Post:
alrashwa (08-26-2012)
Old 08-26-2012, 05:43 AM   #804
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
Toyota definitely knows the problem. I took my car in to get other issues addressed and also mentioned the chirp. Dealer called Toyota and were told that they are aware of it and working on a fix.
Trojan_SC is offline   Reply With Quote
Old 08-26-2012, 07:14 AM   #805
sierra
The feedback from the stealers seems to have changed from 'it's absolutely normal' to 'it's a known problem that will be fixed ASAP'
Good news and hopefully my GTS86 will be modified when it eventually gets built.
Was September build, then October, currently November.
Old 08-26-2012, 08:11 AM   #806
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I found the source of the chirping...
its the Belt tensioner .. you can visibly see the the tensioner fluctuate with the chirp...didn't notice it before when I was looking for it...noticed it yesterday after checking my new LW Kartboy pulley to make sure it was good..so I was directly starring at the belt.. Heard the Chirp and noticed the tensioner would oscillate and coincided with the Chirp... Some one can confirm this...but that was my Observation.. if you still have your Sound Generator tube connected...you wouldn't notice it..because its amplified and appears to come from the DI pump... I will take a video..
Bill
Scooby South is offline   Reply With Quote
Old 08-26-2012, 08:39 AM   #807
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Bill
It's the HPFP and not the tensioner, it's been discussed many times in previous posts.
Hanzo is offline   Reply With Quote
The Following 2 Users Say Thank You to Hanzo For This Useful Post:
ATL BRZ (08-26-2012), Smokinbuffalo (08-26-2012)
Old 08-26-2012, 08:50 AM   #808
Scooby South
Conedancer
ok.. ..sorry to have been over- zealous..but thats not what I observed...and....I don't agree..
Bill
Old 08-26-2012, 12:58 PM   #809
Brimford
Drives: Whiteout / MT FR-S
Best way to reproduce the chirp, put the AC on and drive for a few miles...thats how it's been for me. I've actively been avoiding the ac for short drives just to avoid the noise...Obviously it still happens during spirited drives, or just long highway drives, but i find i can reproduce the chirp extremely fast just by using AC with just casual short distance driving.
Brimford is offline   Reply With Quote
Old 08-26-2012, 04:50 PM   #810
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
Yep, I have the cricket sound too. Just over 400 miles I was backing into my parking spot in my garage with both windows down.
Looks like I'm calling the dealer on Monday...:/
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 08-26-2012, 05:22 PM   #811
travace
travace's Avatar
Drives: Scion FR-S
well im glad to hear that there should be a tsb out soon. Tuesday im taking my FRS in to talk about the S-SB0009-12 and get the new ECU. I took the car in once for the chirp but i will mention it again and see what they tell me and report back.
travace is offline   Reply With Quote
Old 08-26-2012, 08:39 PM   #812
Mr. Sociable
Hombabe
Mr. Sociable's Avatar
Drives: 2014 BRZ
Bill
Tensioner wobble is normal per my service tech.
In my car, the chirp is coming from the diver's side of the engine bay, near where all the fueling stuff is. All signs point to the HPFP or similar.
Mr. Sociable is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
