Old 08-23-2012, 12:50 PM   #701
TeamSweet86
TeamSweet86's Avatar
Drives: Subaru BRZ
Originally Posted by White64Goat View Post
Another one goes down for the cam sprocket problem (tied to the idle dip it appears). 'primo' posted in another thread in this forum that his car has also suffered the same fate as Hammer's car (above), which I believe were purchased from the same dealer. primo's VIN is in the 27xx range and mine which hasn't arrived yet, is 2594, which I would have to assume was built before primo's so I'm a little confused as to how a car with a higher VIN number is here already and is the CSB color, which mine will be.
Hammer, what is the last 4 of your VIN?
Good luck WhiteGoat. Definitely have your car thoroughly tested/scanned/prodded before you buy. That sucks to hear, but I don't think you want to be in our situation. The time my car was running before the light actually came on was about an hour I believe. Hammer and I will keep everyone informed about what happens with our cars...
TeamSweet86 is offline   Reply With Quote
The Following User Says Thank You to TeamSweet86 For This Useful Post:
Marrk (08-23-2012)
Old 08-23-2012, 01:04 PM   #702
White64Goat
bonburner-actually the last 6 are the serial number. For the BRZ the first serial number (as listed in the service manual) is 600001 so unless they build 99,999 cars I'd assume that all the BRZ's for this year will start with 60-. All the serial number and ID info can be found in the "2013 Subaru BRZ Factory Service/Shop Manual" thread which is posted in the 'Mechanical Maintenance' section in the forums. It is in the 'ID' section in the first PDF file listed.
Digits / Code / Meaning / Details
1-3 /JF1/ Manufacturer body area/ JF1: passenger car, FHI made
4 /Z/ Car Line/ Z:BRZ
5 /C/ Body Type/ C:Coupe
6 /A/ Displacement/ A:2.0 Non-Turbo
7 /B/ Grade/ B:R C:S (Premium/Limited?) not defined in manual
8 /1/ Restraint/ 1:Manual belts, dual airbag, side airbag for seatback, curtain airbag for roof
9 /X/ Check Digit/ 0-9 & X
10 /D/ Model Year/ D:2013MY
11 /1/ Transmission Type/ 1:FR 6 speed MT 2:FR 6 speed AT
12-17 /600001/ Serial Number 600001-
Anyone know what Toyota 86 or Scion FR-S serial numbers begin with (60?) or is the 4th digit the only difference?
Old 08-23-2012, 02:22 PM   #703
anteater86
Bo Ding!!
Drives: 2013 FR-S/Asphalt AT
You didn't go to UCI by any chance did you?
Yep! I guess the "anteater" gave it away...
anteater86 is offline   Reply With Quote
The Following User Says Thank You to anteater86 For This Useful Post:
Lonewolf (08-23-2012)
Old 08-23-2012, 07:53 PM   #704
azburnin
azburnin's Avatar
Drives: 2013 Raven FR-S
[ame="http://m.youtube.com/watch?v=RNkLs9q4ibg"]YouTube - 2013 FRS IDLE ISSUE[/ame]
This is my car, I finally caught it happening. Excuse me for my lack video etiquette, it's not a bad one just sloppy. But it does the job.
azburnin is offline   Reply With Quote
Old 08-23-2012, 10:23 PM   #705
eurospeed
How many here would like to see a list of FR-S/BRZ owners who have experienced the CEL/SL/idle issue? I'd like to try to document the number of owners, their mileage, location, and status of their cars. I was planning on doing this privately in Excel, but would rather keep a running list in a separate thread. I feel it would be a good snapshot to help understand the severity and broad reach of this problem.
eurospeed is offline   Reply With Quote
Old 08-23-2012, 10:24 PM   #706
goincarcrazy
Future FR-S Owner
goincarcrazy's Avatar
Drives: '05 Scion tC
As a hopefully soon to be buyer of this car, I would LOVE to see the stats. I'd also like to see the ratio of MT to AT that this happens in.
goincarcrazy is offline   Reply With Quote
Old 08-23-2012, 11:12 PM   #707
Tricky1980
Drives: 2013 Raven Fr-s
last 6 of my vin - 707712... no prod run because i dont have my car... but i was "told" it was on the boat 1.5 weeks ago and then it showed up last wednesday... so... recent? haha!
no new news... other then "parts" are ordered... with "critical" status but no eta...
recap - 91 miles, MT, raven, just got it... happend with under 20 miles the first time... check engine light at 76 miles.
Tricky1980 is offline   Reply With Quote
Old 08-23-2012, 11:35 PM   #708
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Would be interesting to have a definitive range of VINs experiencing this issue, as well as other issues, separated by issue.
Mine is 701177, 5k miles and had the idle dip twice over that distance, but hasn't been a violent shaking idle dip like some of these have.
Pscylo is offline   Reply With Quote
Old 08-24-2012, 01:14 AM   #709
Marrk
Drives: Honda Fit
Good idea. That info plus VIN and manufacture date.
Marrk is offline   Reply With Quote
Old 08-24-2012, 01:20 AM   #710
Marrk
Drives: Honda Fit
az, this was a serviceable video and included all the salient info.
As I watched the entire thing, I never saw your RPMs go below 500. With, and even without, the a/c on, this doesn't seem like a crisis to me. However, maybe it is different if you are sitting in the car when it happens. You didn't say anything about shudder, shake or stalling, so I don't know what the problem is. The guys with stalling, engines dying and cel codes — they got problems.
Please, tell me what I am not seeing.
Old 08-24-2012, 01:23 AM   #711
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Just an FYI for anyone talking about a so called "range" of VIN's, VIN's are not sequential and do not indicate the order of being built.
Demandred7 is offline   Reply With Quote
Old 08-24-2012, 01:29 AM   #712
Marrk
Drives: Honda Fit
Can you support this statement with evidence?
TSBs use VINs to establish which cars need the required service.
Old 08-24-2012, 01:36 AM   #713
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
I think what has people concerned is that this idle dip may lead to worse things. Mine ('13 FRS MT) does the same thing as the OP's. Idles around 800, occasionally drops to 400-500 (usually with a very slight shudder) and pops back up to 800. That doesn't bother me. What will bother me is if it gets any worse...it won't be a crisis until it starts stalling or throwing a CEL...
sho220 is offline   Reply With Quote
The Following User Says Thank You to sho220 For This Useful Post:
FRSjeff (08-24-2012)
Old 08-24-2012, 01:51 AM   #714
Shimmyshake
Shimmyshake's Avatar
Drives: Whiteout FR-S
Agreed.
Shimmyshake is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
