Old 08-23-2012, 04:58 PM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by YoKeutla View Post
He kind of already answered this. You can disconnect from the rear and stow them behind or under the seat. They will still be connected at the lower lap mounts and you can just slip them back into place and connect them to the rear mounts when ready to use again.
Yup, and the stock 3-points are unchanged. When you use the harness, just pull the stock belt behind the seat and plug it into the buckle. Otherwise, just use it normally.
Old 08-23-2012, 06:18 PM   #30
elbachatero1
elbachatero1's Avatar
Drives: 2013 Subaru BRZ 6MT Limited WRB
Originally Posted by Draco-REX View Post
I got mine from SoloRacer.com. Right now they only have black available for the belts. However the pads are available in a number of different colors.
They're also available with or without the patch, and there's a leather version as well.
did you get the 2" or the 3" pads?
elbachatero1 is offline   Reply With Quote
Old 08-23-2012, 06:45 PM   #31
Draco-REX
Corner Junkie
Draco-REX's Avatar
The Rallye 3 and 4 use 2" belts, so the 2" pads. The ones in my pictures are black w/ Schroth patches.
The Following User Says Thank You to Draco-REX For This Useful Post:
elbachatero1 (08-24-2012)
Old 09-02-2012, 11:50 AM   #32
gmookher
website?
Old 09-02-2012, 03:14 PM   #33
Draco-REX
Corner Junkie
Draco-REX's Avatar
Originally Posted by gmookher View Post
website?
Post #29, soloracer.com
Old 11-21-2012, 02:31 PM   #34
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Do they say how big of a waist these things can fit? I'm a big fella and would need it to fit around the keg (because it sure as hell aint a six pack)
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 11-21-2012, 04:54 PM   #35
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
When I was at my heaviest, I was up to a 40 inch waist, and the Schroth harnesses I've had in several of my cars still fit me with room to spare.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 11-26-2012, 05:01 PM   #36
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
I'm quite a bit bigger than a 40 inch waist unforunately. I'll have to get in touch with Schroth I guess.
Old 01-20-2013, 08:45 PM   #37
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Can someone get me one of these to Sydney ??? cant find it in OZ
Surok is offline   Reply With Quote
Old 01-21-2013, 12:15 AM   #38
JWA
Drives: BRZ, Exige, Boxster
FWIW, these are 4-points, but they have Schroth's patented Anit-SubMArine (ASM) device. So they are the only type of four-point that is safe. Without that a four-point is MUCH less safe than a three-point.
JWA is offline   Reply With Quote
Old 01-21-2013, 12:26 PM   #39
xwd
Ugh still need to install mine. Just need to find the time.
@Surok : Have you tried one of the US vendors? I'm sure they would be willing to ship to Aus unless there is some weird law against it...
Soloperformance.com or soloracer.com is where I would look to.
Old 01-21-2013, 07:43 PM   #40
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
whenevr i ring soloracer they have gone home haha ill send an email.
Old 01-26-2013, 04:27 PM   #41
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
@Draco-REX Did you try routing the shoulder straps inside of the vertical headrest bars? I know the seats structure looks like it would inhibit the straps from sliding, but in schroth's diagrams, they recommend routing the straps inside of the bars.
enjoyminutemaid is offline   Reply With Quote
Old 03-01-2013, 12:48 AM   #42
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
we need a volume discount, I'd like one of these too
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
was385 (03-01-2013)
