Old 08-22-2012, 08:13 AM   #15
Foobar
SLO NO MO
Foobar's Avatar
Excellent! Will be doing this over the weekend. I can't really tell from the pic - is that grommet on the trunk used for the trunk release button? Looks like that whole panel screws off?
Finally, I like the look of that Rydeen - any chance you can spread your good deal around to us FT86Club members?
By the way, the lines/text are from the camera itself I believe. At least that's how other cameras have worked for me.
Here - found this on Rydeen's site:
Speaking of the original, the MINy™ retains its Super CMOS III Night Vision camera and waterproof engineered plastic housing. On the inside, it features selectable parking lines that overlay the image, and the view can be reversed for front-mount applications.
Old 08-22-2012, 09:43 AM   #16
sparks
sparks's Avatar
Was the ground on pin 15 required to activate the camera?
What did you use to power the camera? Back-up lighting?
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-22-2012, 11:28 AM   #17
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
The grommet had nothing running through it, seemed like it was basically made for a back up cam/ rear laser diffuser.
The Rydeen camera does have its own lines, I had already disabled them, the ones on the screen are in fact from the Radio, when I first hooked it up it had both sets of lines. Basically I had to connect two green wires in the camera cables to disable those.
I have not tried it without the pin in the harness but I do know when that wire wasn't grounded I did not get the camera to come on, so I would say yes.
And yes I used the reverse light wire to power the camera.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
sparks (08-22-2012)
Old 08-22-2012, 12:01 PM   #18
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Great write up!...quick question..i saw a pic of your interior showing your head unit...how come you have the FR-S climate controls wheels?....i thought all BRZs have the toggle switches??? Am I missing something??
ap5512 is offline   Reply With Quote
Old 08-22-2012, 12:03 PM   #19
ap5512
ap5512's Avatar
nevermind...just figured it out...FACE PALM!!!
Old 08-22-2012, 12:05 PM   #20
sparks
sparks's Avatar
The Preimum BRZ = FRS, the auto air BRZ is the limited.
Old 08-22-2012, 12:26 PM   #21
Foobar
SLO NO MO
Foobar's Avatar
Does the Premium not have a trunk release button on that surface? I wonder if the Rydeen Duo could fit right through that hole:
http://www.rydeenmobile.com/Backup%2...upCameras.html
I hope I can disable the lines on the cheapo camera I bought, I didn't realize the HU had its own.
Old 08-22-2012, 01:22 PM   #22
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Nicely done!
Any suggestion as to where we can get one of those 16 pin plugs and few wire pins?
sure74 is offline   Reply With Quote
The Following User Says Thank You to sure74 For This Useful Post:
GremlinDX (09-06-2012)
Old 08-22-2012, 01:29 PM   #23
Foobar
SLO NO MO
Foobar's Avatar
By the way, what was that gray ground wire plugged into before this mod? Was it already going into the 16 pin harness by itself and you added the three extra to that harness?
Old 08-22-2012, 01:35 PM   #24
sure74
sure74's Avatar
OK, looks like the 16 pin plug is already connected and has 1 wire for the hand brake.
So we just need a few wire pins.
Old 08-22-2012, 01:59 PM   #25
sparks
sparks's Avatar
By the way, what's that gray ground wire plugged into before this mod? Was it already going into the 16 pin harness by itself and you added the three extra to that harness?
The gray wire is the parking brake input
Old 08-22-2012, 02:10 PM   #26
Foobar
SLO NO MO
Foobar's Avatar
Damned English contractions and multiple meanings! I meant what was it plugged into. Sounds like it was in the 16 pin harness all by itself, so all I need to do is get my camera's + and - wires onto that same harness. Are there contact pins already there to solder in to or is it a blank with just one pin for the gray parking brake wire?
Old 08-22-2012, 02:16 PM   #27
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
subaru will be offering some features to its BRZ lineup in the next little while and a backup camera is one of them (at least for the Australian market).
but it's great that someone was able to come up with their own before subaru's release.
azian_advanced is offline   Reply With Quote
Old 08-22-2012, 03:20 PM   #28
sparks
sparks's Avatar
Correct the brake wire is the only wire in the plug. There are no other pins in the plug. VW USED pins from the 12 Impreza kit SVXdc sells, but had to cram them in. I'm working another angle with the Subaru terminal kit to match something up. More to follow, stay tuned.
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
