Old 07-07-2012, 01:23 PM   #57
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by Flat Black VW View Post
So im thinking about trying to mess with this after work today.
Heres what im planning:
Cut the grey wire on its own plug and ground that to pin 7 on the 10 pin plug.
this should get me around the ebrake, now I need to get around the VSS
For this I will grab pin 17 on the 28 pin plug and run it to a rocker switch, with this I will be able to cut the VSS signal, allowing me to type in an address/use my phone, then flip the switch back allowing my gps to continue to be accurate.
From what I gathered this sounds like the only way to do it until someone finds a pin allowing us to get around this a different way.
Any other input? other things I should try while im back there?
Sounds like a plan.
xcelir8brz is offline   Reply With Quote
Old 07-10-2012, 09:40 AM   #58
OMNOM
OM NOM NOM NOM
OMNOM's Avatar
Drives: 2013 Infiniti G37xS Sedan
Any updates on this?
OMNOM is offline   Reply With Quote
Old 07-10-2012, 10:37 PM   #59
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
havent done it yet, too hot last week, may try on thursday but im also doing speakers so we will see if I have time.
Flat Black VW is offline   Reply With Quote
Old 07-13-2012, 12:01 PM   #60
fmsida
Drives: 2013 DGM BRZ
Any one have any new updates with this little project?
I have two kids that are eager to watch "We bought A Zoo" on my Nav. screen as I drive them jiu-jitsu class...
I plan on finishing adding a subwoofer this weekend, hopefully I will have time to play around some more with this issue. I will try disconnecting the VSS, then I will try grounding the VSS from the HU end and see what the results are.
I do have a busy weekend, so please no one hold me to finishing this.. lol
I will remember to take pictures for future reference.
fmsida is offline   Reply With Quote
Old 07-13-2012, 03:05 PM   #61
Flat Black VW
been very busy lately, but hopefully I will get to this today or tomorrow after work
Old 07-19-2012, 12:54 AM   #62
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Rudely,
bumping for results.
Floggin Tires is offline   Reply With Quote
Old 07-19-2012, 04:25 PM   #63
Flat Black VW
been too hot out and I spend all day at work with little-no ac, Ill try it eventually.....
Old 07-20-2012, 03:32 PM   #64
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Non Brz owner chiming in here..
I do recall some manufacturers using timed switches that trigger a switch for say 30 seconds to a minute to allow input on older Infiniti models and whatnot.. This may make the switch mod noted above a little easier as you dont need to toggle the switch the second time as it automatically reverts to the default "off" connection.
Good luck guys.
Norkoastal is offline   Reply With Quote
Old 07-22-2012, 11:54 PM   #65
nquillen
Drives: SWP BRZ
Does anyone know how the SWC pins of the 28-pin connector work?
Is SWC common a logic level high, and you pull the other 2 SWC pins to either common or ground?
Do the connectors have dummy pins in the SWC locations, or does anyone have a source for connectors or crimpable pins?
Was thinking of making a small switch panel with the volume controls and a toggle switch to disable parking brake switch.
nquillen is offline   Reply With Quote
Old 08-11-2012, 05:25 PM   #66
Floggin Tires
# 1. Always know where your towel is.
ZC6-CBS, is home
Old 08-21-2012, 06:37 PM   #67
Flat Black VW
http://www.ft86club.com/forums/showt...896#post393896
solution^^^
The Following User Says Thank You to Flat Black VW For This Useful Post:
Floggin Tires (08-21-2012)
Old 09-30-2012, 06:45 PM   #68
Jun_
Drives: Satin White Pearl BRZ Limited
Could anyone make a DIY for the Nav bypass? I'm still pretty new to these kinds of things and I don't want to mess everything up. ): Thanks in advance.
Jun_ is offline   Reply With Quote
Old 09-30-2012, 09:18 PM   #69
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
+1
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 10-02-2012, 10:47 PM   #70
Flat Black VW
Originally Posted by mr_m View Post
+1
It is shown in this thread, first post:
