Old 08-20-2012, 09:16 PM   #1
hotaka
Drives: na
Why are expensive brakes better?
Seems like an obvious question, but I can't find the answer. Even if you have a very nice braking system, your car's stopping ability is limited by traction, right (tires, downforce, car weight, and weight distribution, suspension)?
If your brakes are too good for the rest of your car, I feel that all it's doing is making wheel lock easier (and activate ABS).
How do they improve stopping distance?
Thanks
hotaka is offline   Reply With Quote
Old 08-20-2012, 10:01 PM   #2
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
It depends on how you would like to drive your car. If your doing daily driving on normal roads a new brake kit won't be too much better. If you are on the track you ride the brakes alot and the brake rotor heats up and essentially fails to perform so you will see loss in braking power. The better brakes will have larger surface area so that temperatures don't get as hot and better materials that withstand more heat before breaking down.
You can always adjust the braking power if the kit ends up locking up too much.
Xanatos is offline   Reply With Quote
The Following User Says Thank You to Xanatos For This Useful Post:
hotaka (08-20-2012)
Old 08-20-2012, 10:22 PM   #3
CSG Mike
CSG Mike's Avatar
They don't improve stopping distance.
What they do is allow you to brake over and over and over, without overheating the system. Larger rotors offer more surface area for cooling, as well as more mass in the rotor itself to sink heat away from the pads. Larger opposed calipers offer more mass to sink heat away from the pads, and promote more even pad wear as opposed to the stock floating caliper.
Unless you're FI, the stock system with upgraded pads is generally "good enough". At least, in our experience it has been.
Here's a video of our BRZ braking over and over on sticky street tires; we suffered no fade, even running 5 laps back to back in 105+ ambient temps with race pads:
Turn 3: 129 to ~40
Turn 5: ~87 to ~45
Turn 8: ~100 to ~35
Turn 11: ~104 to ~45
[ame="http://www.youtube.com/watch?v=waCr19ZM640"]BRZ at Auto Club Speedway - YouTube[/ame]
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
AJUSA.com (08-21-2012), hotaka (08-20-2012), MiguelAE86 (08-21-2012), wheelhaus (08-21-2012)
Old 08-20-2012, 11:19 PM   #4
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Ummm, larger brakes can also can also improve stopping distance. More surface area = more friction.
Old 08-21-2012, 12:05 AM   #5
CSG Mike
CSG Mike's Avatar
Stopping distance is dictated by tires, not brakes (unless your brake bias is severely off). Can the stock brake calipers, rotors, and pads lock up the tires? Yes. That means that you have more braking power, than your tires have grip. Increasing braking power still doesn't address the lack of tire grip; the tire grip is the limiting factor in this case.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
AJUSA.com (08-21-2012), Asphalt (08-22-2012), Dave-ROR (08-27-2012), Justin.b (08-21-2012), kndonlee (08-29-2012), RandomHero (08-21-2012)
Old 08-21-2012, 12:17 AM   #6
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
CSG Mike and Xanatos nailed it. Also, it comes down to driver preference. Usually when getting into aggressive street pads/ race pads you may find that a pad that is very expensive is the one that feels best to you, however you may also find that a very inexpensive pad is the right one for you, as it comes down to how you like the car set up and how you like it to feel.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-21-2012, 12:39 AM   #7
BlaineWasHere
Grip>Drift
Drives: FRS
What happens when tire grip exceeds brake force?
Old 08-21-2012, 12:52 AM   #8
wheelhaus
wheelhaus's Avatar
Quick replies with dead-nuts correct info, nice!
You simply run out of usable brake power and are required to apply excessive force, "standing on the pedal" comes to mind. This causes pads to overheat, glaze, break down and chunk off, uneven wear, fluid to overheat, boil, etc. Seals get damaged, too. Friction alone generates heat, but higher pressure allows that heat to transfer more quickly into the pistons and caliper body. Heat from the rotor can bleed into the steering knuckle and overheat the wheel bearings. Excessive heat is not good.
In addition to the benefits of hardcore track use mentioned above, another benefit of big brakes is lighter foot pressure and easier modulation.
edit- With extremely grippy tires and high power brakes, you eventually rreach a point of diminishing returns, where extra brake power doesn't really help, or the extra grip can't be utilized beyond a certain point. This is where aerodynamics come into play (read- downforce!) This changes everything and is really a topic for another discussion.
The Following User Says Thank You to wheelhaus For This Useful Post:
djdnz (08-21-2012)
Old 08-21-2012, 01:37 AM   #9
BlaineWasHere
Grip>Drift
Drives: FRS
So, if you have more tire grip than brake power larger brakes don't equal more stopping power to take advantage of tire grip? I understand the larger surface areas do better with the heat. I'm just trying to understand, and as you can see I'm struggling.
Old 08-21-2012, 01:50 AM   #10
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Surface area has nothing to do with 'more friction'...mu is mu... Now thermal capacity/ability - that's already been mentioned.
You want as small a brake system as possible for the application you need it to do reliably. The stock system is very good on track with sticky tires - all it really needs is a better pad compound. If not running more power than stock, then there is no need to 'upgrade' to a 'Big Brake Kit' for track duty (HPDE) - all you will be doing is adding a noticeable amount of unsprung weight with a very minimal increase in braking performance... degrading your performance when not on the brakes in other words.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 08-21-2012, 01:54 AM   #11
fatoni
You want as small a brake system as possible for the application you need it to do reliably. The stock system is very good on track with sticky tires - all it really needs is better pad. If not running more power than stock, then there is no need to 'upgrade' to a 'Big Brake Kit' for track duty (HPDE) - all you will be doing is adding a noticeable amount of unsprung weight with a very minimal increase in braking performance... degrading your performance when not on the brakes in other words.
im not sure surface area has nothing to do with it. mu is a coeffecient
Old 08-21-2012, 02:18 AM   #12
CSG Mike
CSG Mike's Avatar
I should add that a BBK can contribute to a more consistent pedal feel... but at a rather high price.
In that unlikely scenario, getting a higher friction (mu) pad will get you the additional stopping power you need. However, if the tires really overpower the brakes, you'll likely overheat your braking system VERY quickly.
Old 08-21-2012, 02:22 AM   #13
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
The formula for friction is: Ff = u * Fn
Ff = Friction force
u = Coefficient of friction
Fn = Normal force
There is no term for area. When the surface area is larger, the normal force is spread out over said larger area. Thus, each unit of area receives less force applied and the total force remains the same.
FrX is offline   Reply With Quote
Old 08-21-2012, 09:48 AM   #14
camelflage
Drives: pinto power
this is what you commonly find in the street scene with modified cars running fat grippy tires on 19 inch wheels and stock honda brakes.. the weight and grip of the wheels/tires will overheat the stock brakes and then you get super dorifto oh god cant stop rear-end a school bus kids on fire... so a BBK will help give the added pressure and heat management capabilities to slow down that extra rolling mass...
camelflage is offline   Reply With Quote
Is the brz/frs too expensive? huma BRZ First-Gen (2012+) — General Topics 74 05-12-2015 12:28 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
Engagement... so expensive. merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 43 08-02-2012 09:55 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
2014 Cars slightly more expensive? Buggy51 Other Vehicles & General Automotive Discussions 10 02-29-2012 09:24 PM
