Old 08-19-2012, 05:04 PM   #15
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by pinoyplaya View Post
Is it bad to go from 5th gear, slow down to approach a freeway entrance, then switch to 3rd gear without going to 4th?
Or should I go to 4th from 5th then to 3rd a few seconds later?
Do I have to press on the gas when downshifting from 5th to 4th to 3rd or can I just shift to all those without hitting the gas pedal?
Pretty sure not hitting the gas pedal is really bad, you'd be using the clutch to speed your engine up. Hard to get the rpm right though
Old 08-19-2012, 05:15 PM   #16
fatoni
i dont think its really bad but its probably not too good either. its something i would avoid. modern cars with all their synchros do wonders
The Following User Says Thank You to fatoni For This Useful Post:
ill86 (08-19-2012)
Old 08-19-2012, 06:04 PM   #17
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Heel toe, that is the answer
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 08-19-2012, 06:09 PM   #18
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Yes, you can go from 5 to 3.
No, you should practice rev matching. Synchros or no synchros, i wouldn't recommend "just shifting without hitting the gas pedal".
ill86 is offline   Reply With Quote
Old 08-19-2012, 06:10 PM   #19
ill86
ill86's Avatar
Drives: iG FR-S
Fatoni, go ahead lol... I'm not touching this one...
Please just describe rev matching and h/t as two different things.. :happy0180:
Old 08-19-2012, 06:12 PM   #20
ill86
ill86's Avatar
Drives: iG FR-S
Practice makes perfect... It's something anyone can easily master.
Old 08-19-2012, 06:51 PM   #21
pinoyplaya
Drives: WRB MT-BRZ LMTD
Rev matching is when you rev the engine after downshifting before releasing the clutch at the lower gear right?
Cuz I know before when I was going too fast, down shift and BOOM! the car just rocks back and forth. Maybe cuz I didnt match the revs.
But I mean in general.
Say I was cruishing at 2k RPM in 5th gear. Then decide that I want to accelerate, can I go back to 3rd gear then accelerate, then to 4th then 5th gear when I get to my desired speed?
Or should I drop down to 4th first, accelerate then drop to 3rd to accelerate even more? That just doesnt make any sense.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-19-2012, 07:17 PM   #22
Sythellri
Drives: Subaru BRZ Limited
Man, I was practicing in CCSF's parking lot. BIG EMPTY AREA but there is a police station like three blocks from it haha, they came instantly and pulled me over. I told them that I was trying to learn how to drive stick and the officer just laughed while telling me to leave because it was private property >.>
I've been practicing down near the beach in the sunset district. The great highway is a good long stretch to sorta "chill" after trying all those flats/stop signs and stuff.
For clarification, everyone tells me to get the car moving using ONLY the clutch...How?
Here's what I've been doing from full stop:
1. Push in clutch all the way and shift to 1st.
2. Slowly let off clutch until about 1-2cm before the friction point.
3. Tiny bit of gas.
4. Slow release of clutch balanced with slow pressure on gas.
How do I get faster at this if it is the right technique?
My friends aren't very helpful...
"Alex, it is best if you watch me drive and just learn from that."
*ten minutes later while going around lake merced at 80 mph*
"WOWWWW, THIS THING IS PLANTED! NO BODY ROLL! HOLY CRAP! DUDE THIS SHIT GRIPS!!!!"
....yeah hahahah
Sythellri is offline   Reply With Quote
The Following User Says Thank You to Sythellri For This Useful Post:
neutral (08-22-2012)
Old 08-19-2012, 10:59 PM   #23
Chauntalei
Drives: Non-BRZ
Push in the clutch, shift into 1st. Then, without giving it any gas, very slowly let the clutch out until you feel it start to grab. Right around that point, the car will actually start to move forward even though you aren't giving it gas. That helps you learn exactly where the engagement point is on the clutch.
Chauntalei is offline   Reply With Quote
Old 08-19-2012, 11:05 PM   #24
ill86
ill86's Avatar
Drives: iG FR-S
Rev matching is carefully matching engine speed while up or downshifting. It should be done smoothly and practiced until you are perfect.
Yes you can go to 3rd from 5th as you described.
Old 08-19-2012, 11:53 PM   #25
carbonBLUE
Reverse Burnouts
Actually they both tie into eachother, being able to heal toe will teach you the gear ratio differences between gears at any given speed, an exhaust will also help you listen to the car better, with in a year you should be able to tell what gear you are in and how fast you are going based off engine speed and chassis movement alone
(wont forget you)
2011 Infiniti G37x
Old 08-20-2012, 12:31 AM   #26
cgrey
Drives: 2013 Argento Silver FR-S
3. Tiny bit of gas.
....yeah hahahah
You get faster by practising.
The smoother you are the faster it will be. Feel rushed and you'll begin to screw up, like anything else. Try to be smooth.
For a normal start you'll let the clutch out until you feel it engage and then add the right amount of gas for the speed you desire. For the most part you will select a fixed amount of gas pedal, modulate with the clutch until it's fully engaged, and then use the gas pedal to drive as normal.
You will need to develop the proper muscle memory for the task, after a while you won't be thinking about what to do.
cgrey is offline   Reply With Quote
Old 08-20-2012, 01:42 AM   #27
ill86
ill86's Avatar
Drives: iG FR-S
I know, kind sir - as this is my profession.. It was an inside joke referring to another thread here.. not directed at you.
:happy0180:
Old 08-20-2012, 01:45 AM   #28
ill86
ill86's Avatar
Drives: iG FR-S
Very well said.
Suspension tuning 101 (Making it Stick) taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-04-2012 05:43 PM
Completely new driver. Need advice PoRco Scion FR-S / Toyota 86 GT86 General Forum 104 06-30-2012 08:38 PM
To Drive a stick or cruise an Auto? MrFRsLa Scion FR-S / Toyota 86 GT86 General Forum 54 04-30-2012 07:50 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 12:52 PM
