Old 07-27-2012, 02:09 PM   #43
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
Originally Posted by fmsida View Post
Hey Nate, can you post pictures, name/brand of the sub/amp combo? I am trying find something smaller and not as loud as my current setup. As you can see in the above post, the subwoofer alone almost takes up half the trunk space.
Thanks.
Ill take a picture tonight and post it up of my trunk setup.
Nate219BRZ is offline   Reply With Quote
Old 07-29-2012, 10:07 PM   #44
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
I did an install already. Use the rcas in the back of the deck if possible if not do a line out. Tap the brown wire with a white line for the remote wire, and i used the ground already in the trunk and ran the power through the grommet(sp?) on the drivers side with the wire pack going through it. Very easy install doable easily in an hour.
BigJyoungblood is offline   Reply With Quote
Old 07-30-2012, 12:54 AM   #45
Nate219BRZ
Nate219BRZ's Avatar
i installed this on the passenger side of my BRZ.
Old 08-18-2012, 07:29 PM   #46
killswitch
killswitch's Avatar
Drives: 2013 Subaru BRZ
Just installed my fusion sub/amp combo using the pinouts provided. Thanks! You made this a 1hr install and made life alot easier running the cables.
killswitch is offline   Reply With Quote
Old 08-19-2012, 04:23 PM   #47
killercl0wnfish
Drives: fr-s
I've never seen these before ... How do they sound ?
killercl0wnfish is offline   Reply With Quote
Old 08-19-2012, 11:14 PM   #48
Nate219BRZ
Nate219BRZ's Avatar
i think it adds just enough boom to round out the stock system. I dont want to wake the neighbors stuff. i want something that has good sound with clarity and this delivered that.
Old 10-22-2012, 10:34 AM   #49
send2michael
Dallas Car Enthusiast
Drives: Currently - 2008 Ford Mustang
speaker level or line level?
Originally Posted by cruzinbill View Post
This is the plugs on the back of the Head Unit correct. Wanna make sure its that and not the amp in the back you are talking about. Either way thanks I was tryn to find the amp remote turn on!
Are the wires going into the amplifier in the back, speaker level or line level? I was thinking about getting a 3-way crossover, splitting off the subwoofer level and putting it on it's own amp, while routing the left and right channels back into the factory amp.
Thoughts?
send2michael is offline   Reply With Quote
Old 10-22-2012, 07:53 PM   #50
cruzinbill
Drives: Argento 6spd FR-S
Thoughts?
no clue, probably line level tho. Why would you go through all of that trouble tho? It has RCA's, why not just leave the fronts as is and add a sub?
cruzinbill is offline   Reply With Quote
Old 10-23-2012, 07:15 PM   #51
send2michael
The FR-S has RCA outs, but I don't think the BRZ NAV unit does.
Old 10-24-2012, 03:05 AM   #52
cruzinbill
No, no it does not, sorry thought you had an FR-S
Old 10-25-2012, 04:53 PM   #53
dj petey
dj petey's Avatar
So if i understand the diagram correctly and as verified by Spacewilly, the amp in the back powers the 6" door speakers, presumably with a built in low pass filter on them. This would mean the HU powers the rear 3" and in dash 3" and 1" components, which have high pass filter on them. This setup means the front stage is bi-amped, which also means 6 pairs of wires to tap if i wanted to use the stock speaker wires. Is this correct?
I just picked up a JL XD700/5 and was hoping to steal the speaker leads which i should be able to do by tapping the leads from the trunk mounted amp.
The Pioneer HU has 6 channel pre-outs (F/R/SW) that i will be running into the trunk.
Does anyone know if this wiring diagram is the same for the upgraded Pioneer unit for Canadian FR-S owners? I'm assuming it is.
dj petey is offline   Reply With Quote
Old 10-26-2012, 11:32 PM   #54
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
here's my setup:
installed a universal bass remote in the cubby next to the usb port:
here's a liste of all the stuff i bought:
Pioneer-TS-SWX310
JVC-KS-AX3101D
Raptor-C1.0FM
Belva-BAK42
EFX-RLC-by-Scosche
Xscorpion-BS8R
Kicker-09PWG8-20FT
e2-ERTC4-4-by-Scosche
Xscorpion-RT8R
and some velcro from Lowes.
if you don't care about having room in your trunk and want a really nice sub for a good price, i recommend this pioneer one. has great range and really sounds perfect.
mezdup is offline   Reply With Quote
The Following User Says Thank You to mezdup For This Useful Post:
KGFRS86 (07-23-2013)
Old 11-11-2012, 04:39 PM   #55
zenoran
Here's mine. 2 quick disconnect if I need the space. Thanks for the info on the thread. The brown wire was critical knowledge
zenoran is offline   Reply With Quote
Old 11-12-2012, 11:52 AM   #56
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
How do all of you plan on getting to the spare donut if you ever need to?
speedracer38 is offline   Reply With Quote
Subwoofer prewiring Nate219BRZ Electronics | Audio | NAV | Infotainment 3 09-09-2013 05:56 PM
Adding a sub enclosure yet ? rikdrt1 Electronics | Audio | NAV | Infotainment 10 06-08-2012 09:28 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Does BRZ and FRS come with a Subwoofer? R0ME0 FR-S / BRZ vs.... 6 05-07-2012 02:54 PM
