Old 08-19-2012, 09:23 AM   #1
encity5
encity5's Avatar
Static audio with radio reception? FRS stock stereo
Has anyone experienced this? Or know what might be the issue here?
On the stock pioneer headunit, when i am listening to FM or AM radio, i hear the audio through that radio station but extremely static-y / distorted.
I figure its NOT the speakers, because when i switch to AUX or USB, and listen through another device, (iphone, android unit), audio is perfectly fine as its always been.
It hasnt always been like this, about 2 month ago, i turned on the headunit, and heard the radio very distorted, which worried me. I drove around turned the car off, and when i started it back up again, radio reception was back to normal.
Since then it happened once in a bit, and it would eventually work again.
But this time around it seems like the FM or AM radio is staying with that distorted static-y sound.
I know its not the location, since it is now happening in front of my house and in places where i know i always got great reception. I also never touched the antenna before this. This is like the first full week it stayed like this, and i tried unscrewing and re-tightening the antenna to no avail.
Any help or insight is appreciated, otherwise it might be time to take it to the dealer. My feeling is that its a problem with the antenna.
encity5 is offline   Reply With Quote
Old 08-19-2012, 10:15 AM   #2
so26
Drives: Raven FR-S 6MT
Try disabling the HD radio. I've had some issues with it.
so26 is offline   Reply With Quote
Old 08-19-2012, 10:26 AM   #3
encity5
encity5's Avatar
yea, ive tried that, i tried going through the settings and such, with no fix.
thanks though.
Old 08-19-2012, 12:39 PM   #4
colHolm
Default User Title
colHolm's Avatar
I've noticed that local radio stations don't seem to come through as clear in this car versus others... Maybe it just has a poor antenna?
colHolm is offline   Reply With Quote
Old 08-19-2012, 02:18 PM   #5
encity5
encity5's Avatar
well just before last week, all my radio stations were working great. So i dont think the reception would have all of a sudden changed?
Old 08-19-2012, 02:31 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Do you still have the stock antenna?
Ive noticed my radio reception declining over the past few weeks as well. HD tends to go in and out on certain stations, and others are just static-y.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-19-2012, 02:42 PM   #7
colHolm
Default User Title
colHolm's Avatar
Oh, well mine had just been crap from day one...
From Tapatalk on my Android
The Following User Says Thank You to colHolm For This Useful Post:
Burrcold (10-02-2013)
Old 08-19-2012, 03:15 PM   #8
encity5
encity5's Avatar
I do still have the stock antenna (although i should have my VG sharkfin this week...)
Mine is the same static distortion across all stations. And i just tried some troubleshooting, and it sounds exactly the same with or without the antenna screwed on. so this leads me to believe that the headunit doesnt have a connection to the antenna anymore or that the antenna has just completely stopped functioning.
I am going to try to find some time to take the head unit out and make sure the antenna is connected... or try connecting the new sharkfin antenna and see if that works.
Otherwise, i dont know. dealership time.
Otherwise i mig
Old 08-20-2012, 11:12 PM   #9
encity5
encity5's Avatar
Well i tried attaching a new antenna to the base, no luck,
and i checked the back of the headunit and all connections seem to be connected..
Any other ideas for me to try?
Old 08-21-2012, 01:05 AM   #10
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Theres another connection for the antenna, but its behind the headliner. At this point, Id just go to the dealer.
Parting out HERE
Old 08-21-2012, 07:48 AM   #11
encity5
encity5's Avatar
Thanks, didnt think of that.
At this point you're right, i'll probably just go to the dealer.
Would you or anyone happen to know how to remove the headliner?
Old 08-23-2012, 10:54 PM   #12
encity5
encity5's Avatar
Well just an update, took it to the dealer, turns out it was a faulty headunit, switched it with a new one and now all fine.
Thanks for all the suggestions and help!
The Following User Says Thank You to encity5 For This Useful Post:
Jambi5150 (08-19-2013)
Old 08-19-2013, 06:36 PM   #13
Jambi5150
Drives: FRS Firestorm 6spd Manual
Thanks! I've been pretty concerned about the poor reception I've been having. Very few channels come in clearly and some of the channels seem to fade in and out a little bit (like turning the HD radio on and off, although I've got the HD feature turned off). I'll just try taking it into the dealer and see if the head unit has a problem.
Jambi5150 is offline   Reply With Quote
Old 10-02-2013, 09:36 PM   #14
brad fischer
Drives: 2013 BRZ Premium Blue Manual
BRZ poor FM and zero AM reception
Just got our base model BRZ Monday. FM reception is poor, and can't get any station on AM. Makes little to no difference if I unscrew the antenna. The most I get is 1 bar on the signal strength icon even that is weak as the stereo lite goes on and off and get some static. Suggestions.?
brad fischer is offline   Reply With Quote
BRZ's very poor reception theredtape Electronics | Audio | NAV | Infotainment 3 10-05-2013 12:23 PM
USB on the stock radio Dadhawk Electronics | Audio | NAV | Infotainment 70 02-25-2013 05:48 PM
Stock Stereo Head Unit Languages Bonburner Electronics | Audio | NAV | Infotainment 12 08-18-2012 08:41 PM
static/interference w/ USB to iPhone4 Bobasaur Electronics | Audio | NAV | Infotainment 3 08-17-2012 07:59 PM
Any problems with voice recognition and sat phone reception? WMS Electronics | Audio | NAV | Infotainment 1 06-25-2012 05:45 PM
