Old 08-16-2012, 09:02 AM   #15
mroczeK
Drives: Toyota 86
wow that is impressive, (im an MT noob, been driving an auto most my life until i got my 86) but does using this feature potentially damage the clutch/gearbox?
does it wear the clutch out quicker?
mroczeK is offline
Old 08-16-2012, 09:07 AM   #16
fenton
Originally Posted by Rawdog View Post
so does it do that only during WOT or I'm I going to be getting some weird looks everytime I shift driving around town?
If you are WOT and your clutch pedal gets pressed in there is a secondary rev limited activated (say 5500 rpm). This way when load is taken off the car(clutch in) the car doesnt rev to 7500 rpm and bounce of the limiter. Instead the car naturally comes down from 7500 rpm and will sit and bang off 5500rpm until you let off the clutch. Once the clutch is out again the 7500rpm limit is active again.
He was short shifting in the video so he was actually reving up between shifts which would not feel good to do on the road. Typically you set it at 5000 this way when you shift at redline it is seamless between gears and you wont get TOO much of a jerk. Someone correct me if i am wrong but this is how it worked in my11 sti
fenton is offline
Old 08-16-2012, 09:09 AM   #17
fenton
It is very hard on the clutch and the gear box. It is akin to dumping the clutch between gears.... meaning when they clutch is being connected back to the flywheel there is already load from the engine on it.
If it is synced up perfect and you get really use to it the damage will be much less but you are still trying to connect something that is loaded and spinning at a higher rpm to something that is freely spinning at a lower rpm.
fenton is offline
Old 08-16-2012, 09:23 AM   #18
fenton
One more thing....the reason most do this in a boosted application is the ability to maintain some amount of boost between gears so you don't have to spool out of vacuum every shift.
My sti would hold about 9psi between shifts saving me about half a second of spool at wot shifts
Sent from my Galaxy Nexus using Tapatalk 2
fenton is offline
Old 08-16-2012, 09:35 AM   #19
Visconti
Drives: 05 STi
Not like Cobb ....
The secondary rev limiter is 100rpms higher then the point you push the clutch in.
So let's say you no lift @ 4000 rpms, no lift activates at 4100.
Now let's say you no lift @ 3500, no lift activates at 3600..
In the world of rally the static 5500rpm no lift shift is junk.
Visconti is offline
Old 08-16-2012, 09:38 AM   #20
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
What an awesome way to start the day.
MannyO is offline
Old 08-16-2012, 09:40 AM   #21
Visconti
Drives: 05 STi
This no lift shift also adjusts timing and fueling...
That's why it's called RaceRom Flat-foot!
What do you get when you spell RaceRom backwards... Anyone anyone ?
Visconti is offline
Old 08-16-2012, 09:46 AM   #22
fenton
Not like Cobb ....
makes sense. what happens when you no lift at 7600? that would be a violent shift at redline or 7700 rpm?
Engine spinning at 7600 and trying to engage a gear at 5000 doesn't sound like a fun time.
fenton is offline
Old 08-16-2012, 09:50 AM   #23
Visconti
Drives: 05 STi
Hrmm that's a interesting idea that I never thought about....
That could be a problem.
I'll talk to ecutek about this and most likely have a additional table added so above let's say 7000 rpm it flatfoots an adjustable amount of rpm below instead of above.
Thanks for pointing that out !!
Visconti is offline
Old 08-16-2012, 09:55 AM   #24
chuy21
Drives: 2009 Cobalt SS 373 FWHP 431 Lb-Ft
I like how this lets you flat foot at pretty much any rpm. My cobalt only lets me no lift when near red line or I risk getting knocks =/
chuy21 is offline
Old 08-16-2012, 09:55 AM   #25
fenton
No worries. What you said makes sense and seeing how the car knows what gear it is in it should be easy to match the next gear +500 rpm. I would have thought they would have done that for all rpms as over revving by 100rpm and engaging the next gear is always going to be pretty rough. Should be good for chirping the tires between gears though....poor drive train
fenton is offline
Old 08-16-2012, 09:56 AM   #26
Visconti
Drives: 05 STi
Ya I gotta check.. It might engage 100 rpms below instead of above..
Visconti is offline
Old 08-16-2012, 09:57 AM   #27
fenton
Same with the STI. Had to shift it at redline as there was only one RPM possible in COBB FFS. I like this idea better but seeing how much that car is moving and jerking on the dyno it would be interesting to see it on the road.
fenton is offline
Old 08-16-2012, 11:19 AM   #28
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Jelly. Like real jelly...and just... jelly.
Memphis is offline
Foot Well Mood Lighting BigJyoungblood Cosmetic Modification (Interior/Exterior/Lighting) 189 06-01-2017 11:21 AM
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 08:33 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
