Old 08-14-2012, 11:22 AM   #141
E92M3Guy
Drives: BMW E92 M3
Originally Posted by mines13 View Post
Oh, it can get even worse. If it is the vacuum pump wide band Dynojet offered for years, even if the sensor is remotely accurate, you are seeing A/F information that may have occurred 1000rpm earlier. Effectively rendering any A/F information unreliable. The only proper way to monitor A/F is to mount the sensor directly in the exhaust stream and bypass the horrible pump.
I'm guessing Dynojet has figured this out because...
We datalog the BMW's at the same time as the dyno. This allows me to correlate the car's wide band to the Dynojet wideband on a per-RPM basis. With a properly working wide band on the Dynojet, we do see very accurate correlation with the car's wide band vs. Dynojet wide band. So I'm guessing Dynojet has figured this out by now.
E92M3Guy is offline
Old 08-14-2012, 11:25 AM   #142
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
I assume you were not using the vacuum pump device? I have had nothing but issues with it. That said, if you just run the sensor in a bung, it can work. YMMV
mines13 is offline
Old 08-14-2012, 02:21 PM   #143
E92M3Guy
Drives: BMW E92 M3
I'm not familiar with the vacuum pump device. The Dynojet shops out here just stick a standard Bosch wide band O2 sensor in the tail pipe; and that plugs into one of the Dynojet stack modules at the other end.
I tried searching my database for examples where I correlated the data. I have two or three examples on my computer, but none that I've published (sorry). The closest I could get you was a Dynapack run where I data logged and correlated. It's identical to what I've done on Dynojet as well, and the correlated data in this graph will match very well what I've done on the Dynojet. But keep in mind, this is from the Dynapack, not Dynojet. If you want an actual Dynojet example, just shoot me a PM and I'll email you the Excel spreadsheets with the correlated data.
Here's the Dynapack example I was talking about.
E92M3Guy is offline
Old 08-14-2012, 02:26 PM   #144
mines13
mines13's Avatar
Understood, they have a later model 0-5v input setup. This is good, this is not the old system.
Two different sample rates or did you apply smoothing to the logged AFR through the external wide-band? Looks good, BTW.
mines13 is offline
Old 08-14-2012, 02:34 PM   #145
Matador
hashiryu
Drives: Mk4 Supra
More updates. Less **** measu...........I mean less arguing about who knows more about dynos.
Thanks in advance.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline
Old 08-14-2012, 03:30 PM   #146
E92M3Guy
Drives: BMW E92 M3
The Dynapack was 1-sample per RPM; so it's very smooth already. I use 400 RPMs per second ramp rate. On this car, it was 2000-8400 in 16-seconds.
The two OBD measurements (left-bank and right-bank of the S65 V8) are sampled at the mercy of the BMW DCAN interface. The sampling rate ends up being approximately 120 Hz. No smoothing applied.
E92M3Guy is offline
The Following User Says Thank You to E92M3Guy For This Useful Post:
mines13 (08-14-2012)
Old 08-14-2012, 04:44 PM   #147
sw20kosh
Drives: 2013 Black FR-S
STOP THE DISCUSSION ABOUT DYNO's IN THIS THREAD. THIS IS NOT A THREAD ABOUT DYNOS. CREATE YOUR OWN THREAD.
THIS IS A THREAD FOR ANY UPDATES ON THE BULLET SUPERCHARGER.
sw20kosh is offline
The Following 10 Users Say Thank You to sw20kosh For This Useful Post:
civicdrivr (08-14-2012), djdnz (08-14-2012), DriftEightSix (08-14-2012), ill86 (08-14-2012), sandman126 (08-14-2012), sirus (08-29-2012), Subaruwrxfan (08-14-2012), Surok (09-25-2012), Swift Racing Technologies (08-16-2012), Touge Monster (09-11-2012)
Old 08-14-2012, 08:40 PM   #148
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
But without dyno talk, how will this thread stay bumped? lmao
Coheed is offline
Old 08-14-2012, 08:49 PM   #149
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Holy hell... I thought there was a dyno regarding this sc kit...
Mods, can we get this topic split?
ill86 is offline
Old 08-14-2012, 08:56 PM   #150
Coheed
Coheed's Avatar
I agree the thread has gotten off topic, but if there was a split there would be like 4 posts.
Coheed is offline
Old 08-14-2012, 09:01 PM   #151
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
^speaking the truth^
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following User Says Thank You to Floggin Tires For This Useful Post:
ill86 (08-14-2012)
Old 08-14-2012, 09:03 PM   #152
Coheed
Coheed's Avatar
Wow, pictures and everything. I get the point hahahaha.
Coheed is offline
The Following 2 Users Say Thank You to Coheed For This Useful Post:
Floggin Tires (08-14-2012), ill86 (08-14-2012)
Old 08-15-2012, 12:11 AM   #153
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Mods need to rip into this thread and clean it up
Toyota 86 test driver
Tradewind is offline
The Following 3 Users Say Thank You to Tradewind For This Useful Post:
Panman (08-15-2012), Swift Racing Technologies (08-15-2012), Unleashed (08-15-2012)
Old 08-15-2012, 12:31 AM   #154
xwd
In for the dyno chart. Think how bad it would have been if there even was a dyno chart.
xwd is offline
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-06-2016 11:57 PM
