Old 08-13-2012, 12:30 PM   #281
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by sportsguy83 View Post
This is what I thought happened at a minimum for cars that were not specifically designed for e85....
Someone please educate me why this would not happen to the BRZ (or any car that is not designed specifically to run e85).
Unless Subaru built the BRZ differently than any of their previous cars... The BRZ will be fine. I was running 100% e85 for probably 10000 miles on my 04 STi and never had a problem, and their are many others who have been running the same with 0 problems with the fuel eating through the lines on a turbo Subaru.
I have no way to guarantee the FR-S/BRZ would be safe on e85.. but Subaru's prior history leads me to believe it will be fine.
Ranatsu is offline
The Following User Says Thank You to Ranatsu For This Useful Post:
Sportsguy83 (08-13-2012)
Old 08-13-2012, 12:41 PM   #282
fenton
Originally Posted by EvoXDD View Post
On a 2010 Mitsubishi evolution e85 will eat right through fuel lines, and requires a different fuel pump and bigger injectors
Was this your car that it happened to? A modern year 2000+ car should not have a problem with "eating" fuel lines.
However the fuel pump and bigger injectors being required of course! E85 only has 75% the potential energy of gasoline so at least 30 percent more fuel is required and most stock systems are not meant to handle that increase.
fenton is offline
Old 08-13-2012, 12:54 PM   #283
Visconti
Drives: 05 STi
I've tuned so many EvoXs with just larger injectors on e85 and have had zero problems.
I stay away from fuel pump replacements on those lol
Visconti is offline
Old 08-13-2012, 01:01 PM   #284
UncleFester
I ran E85 through my 98 Eclipse GSX for about 15k miles. Upgraded the pump and injectors only, and not specifically for E85 use.
I feel much safer/comfortable using ethanol for racing.
UncleFester is offline
Old 08-13-2012, 01:19 PM   #285
Visconti
Drives: 05 STi
On route to the dyno!
Visconti is offline
The Following 8 Users Say Thank You to Visconti For This Useful Post:
dabocx (08-13-2012), JoeBoxer (08-13-2012), kwood9000 (08-13-2012), Sargy (08-13-2012), SkAsphalt (08-13-2012), Sportsguy83 (08-13-2012), Symbiont (08-13-2012), Yruyur (08-13-2012)
Old 08-13-2012, 03:59 PM   #286
Synack
Boosted
Synack's Avatar
Drives: Sideways
QUESTION!
I'm dropping my car off to get turbo'd here in a few mins and we are being forced to use the OLD ECU because the new ECU is on a major backorder at Toyota. Will we be able to flash an EcuTek tune onto the new ECU once it is installed WITHOUT having to buy new licenses etc? It will be the same VIN ECU it's just that the TSB that was called for this car physically replaces the ECU.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline
Old 08-13-2012, 04:01 PM   #287
Visconti
Drives: 05 STi
Originally Posted by Synack View Post
QUESTION!
Yeah I'll take care of you.
Visconti is offline
Old 08-13-2012, 04:03 PM   #288
Synack
Boosted
Synack's Avatar
Drives: Sideways
Thanks John.
Synack is offline
Old 08-13-2012, 04:06 PM   #289
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
QUESTION!
Better keep us H-town guys/gals updated on your turbo build!
cobrabyte is offline
Old 08-13-2012, 04:17 PM   #290
Synack
Boosted
Synack's Avatar
Drives: Sideways
I will!
You can find most/all info here:
http://www.ft86club.com/forums/showthread.php?t=11866
Synack is offline
Old 08-13-2012, 09:19 PM   #291
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
i will give you your props on subies but i have to disagree on the evo X's you must change a good amount of your fuel system or eventually you will no none left. i don't want to have a pissing match but i am sure you have wwaaaaaaaaaaaaayyyyy more subies under your belt but evos X's i would safely say i have tuned more and i see the lines turn yellow and even leak sometimes. maybe these guys just had bad luck? but the pump and injectors are a must for sure
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline
Old 08-14-2012, 12:08 PM   #292
Visconti
Drives: 05 STi
Ummm I would like to introduce EcuTek RaceRom Launch Control!
http://m.youtube.com/#/watch?desktop...LCIqINqA&gl=US
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
cobrabyte (08-14-2012), jehu (08-15-2012)
Old 08-14-2012, 12:15 PM   #293
TSLRich
Drives: FJ Cruiser
sick...
TSLRich is offline
Old 08-14-2012, 12:18 PM   #294
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
WOWY I cannot wait to play with this!!
SkAsphalt is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
