Old 08-10-2012, 10:58 PM   #1
Dustin@Dynosty
Dynosty Pushing the Limits... Fuel Pump and Clutch
Well I know our thread about where our current project car stands was a little unclear, we wanted to have a separate thread that is easily searchable down the road for owners searching to find out more information about the limitations of the stock motor/drive train. The first couple limitations we have found are the factory fuel pump and the stock clutch.
Our testing was performed on our Dyno Dynamics 2wd dyno. Our dyno normally reads roughly 10% lower than a standard DynoJet dyno.
The fuel pump we first started to notice fuel pressure dropping off around 230whp on E85 on a dyno dynamics dyno. It has been proven to be fine so far at that point and then some on 93 octane but if you are wanting to make power on E85, then we are recommending to upgrade your fuel pump. We will be pulling that out very shortly to confirm fuel pump options.
The stock clutch is the main reason we stopped pushing the car at 9lbs making 324whp, we started seeing the clutch slip on the dyno at 7200RPM. It would slip then grab then slip then grab. Our current recommendation is to upgrade your clutch if you plan to make over 300whp on a dyno dynamics dyno. We will update this thread with our take on the clutch options available to the market.
Dustin@Dynosty is offline   Reply With Quote
Old 08-10-2012, 10:59 PM   #2
Dustin@Dynosty
reserved for pictures and more details
Old 08-10-2012, 11:08 PM   #3
nix
nix's Avatar
Drives: AVO BRZ
The clutch slip is unsurprising, not sure what type of replacement I'll go with on this car, probably a heavy single plate, organic or hybrid disk.
nix is offline   Reply With Quote
Old 08-10-2012, 11:16 PM   #4
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
hmmm...interesting info about the fuel pump. We're talking about the in-tank pump and not the HPFP right?
MannyO is offline   Reply With Quote
Old 08-10-2012, 11:24 PM   #5
Dustin@Dynosty
correct the in tank pump, the pressure at the high pressure rail was steady. But flow would not stay at a steady, we will test again post fuel pump install to confirm our prediction.
Old 08-10-2012, 11:49 PM   #6
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Interesting to hear fuel pressure dropping. Fuel pump install should be relatively easy? Drop the tank?
Clutch is surprising it even held 300whp at all, and even if it does, it's probably not going to hold for long with a turbo. Clutch feels weak from factory, if anything an upgraded clutch will improve feel.
Coheed is offline   Reply With Quote
Old 08-11-2012, 12:33 AM   #7
Dustin@Dynosty
According to the manual no, can be accessed from top, we will post more details next week.
Clutch is very soft feeling and probably will not hold up to a lot of abuse under 300whp but we could be wrong.
Old 08-11-2012, 01:09 AM   #8
Visconti
Drives: 05 STi
Interesting - we had rock solid fuel pressure on 10PSI .. but on pumpgas
Guess e85 is too much.
I wonder what the fuel pump looks like
Visconti is offline   Reply With Quote
Old 08-11-2012, 01:20 AM   #9
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Could the 850cc injectors be part of the reason the pump isn't holding up?
Old 08-11-2012, 02:37 AM   #10
Allch Chcar
Drives: N/A
The genuine Walbro 255lph fuel pump is the option I hear the most for E85 builds, but options are good.
Interestingly somehow I missed the first thread. Or forgot.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 08-11-2012, 02:44 AM   #11
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
This.????
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 08-11-2012, 02:45 AM   #12
whataboutbob
AutoX-10/10ths every run
Here it is:
http://www.ft86club.com/forums/showthread.php?t=14313
Old 08-11-2012, 09:02 AM   #13
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
In
TouchMyHonda is offline   Reply With Quote
Old 08-11-2012, 10:16 AM   #14
Don@Accelerated
Don@Accelerated's Avatar
No. They are using 40%+ more fuel
Don@Accelerated is offline   Reply With Quote
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-21-2012 11:39 PM
