| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 | |
:happy0180:
| The Following User Says Thank You to yoshiharadesign For This Useful Post: | Spartan65 (08-10-2012) |
#30 | |
i'm sorry, what?
Drives: Canada
plus how will the hub prevent shearing when the clamping force is overloaded, maybe in a vertical direction but not the rotational. so how about dem plastic rings?
#31 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
As for plastic, it depends on the plastic. If it's a simple plastic it won't do much. BUt if it's a high impact composite like what Rhino ramps are made of, they can do quite a bit. In a hubcentric ring application, you're not dealing with shearing or breaking the ring, but crushing it. Composites can have very high crush strengths. Also, keep in mind that the material of the ring has almost nowhere to go, which increases its ability to resist compression. |
#32 |
You can buy a set of Volk Racing hubcentric rings, they are aluminum. You can deform them pretty easily. How much force do you think those are really engineered to take?
I'm trying to find the old thread from honda-tech but once you torque 5 lugnuts down to around 75 ft-lbs, the force required to overcome the static friction between the wheel and the hub is over 40,000lbs. So again, the lugnuts and the ring do absolutely nothing in transferring force anywhere. The ring is there so your wheel isn't sitting oblong compared to the hub and you don't get vibration. I would definitely recommend running them for that reason, but to say they are helping with vertical loads is incorrect. |
| The Following 2 Users Say Thank You to xwd For This Useful Post: | Ryephile (11-12-2012), Sportsguy83 (06-09-2016) |
#33 |
Drives: Whiteout FR-S
Where is the best place to get hubrings? Should i pay $25 from wheeldude or just $10 for ebay ones?
#34 |
Drives: 2013 Subaru BRZ
I bought some Gorilla ones from amazon for like $6 per set. I got two different sized sets because I'm not 100% sure what size I need. I think the ones I ordered are "poly carbon plastic". Maybe next time I'll do aluminum, once I know what size I need, but I've heard the plastic ones are fine.
http://gorilla-auto.com/hub-centric-rings |
#35 | |
#36 |
Oh well, I got the Gorilla rings in 66mm and 67mm outer diameter and they are both too big for my wheels. I think I need 65mm and Gorilla doesn't make those. I broke one of the clips on the 66mm trying to squeeze it in there.
It looks like justforwheels.com has the size I need but they are $46 for an aluminum set. |
#37 |
Nissan Fan
Drives: Sector 9 Longboard
This thread clarified soo many things for me. Thanks!
2007 Nissan 350Z Enthusiast (Carbon Silver) **SOLD**
2013 Nissan GT-R Black Edition (Jet Black) 2013 Subaru BRZ Limited (World Rally Blue) **VON received/Pending Arrival** |
#38 | |
Drives: 4 wheels
Going with the calculator at http://www.engineersedge.com/calcula...orque_calc.htm 89 ft-lbs = 1068 in-lbs 12mm major diameter = 0.472441in (google conversion) Axial clamp force (website calculation) = 11302.99868131682 lbs...I'll call it 11303 lbs. 5 lugs, so total axial clamping force is ~56515 lbs. Coefficient of friction between Aluminum and mild steel = .61 (don't know the exact material for the rotor, so I'll go with that) .61 * 56515 lbs =34474.15 lbs The real world results will vary and actual clamping force for an applied torque on a bolt seems to be a tricky calculation with a lot of variables in the mix to get an accurate model, but that's like 12x the weight of the car holding up each corner by static friction...there is a pretty good margin of safety there. |
| The Following User Says Thank You to bucket For This Useful Post: | Ryephile (11-12-2012) |
#39 | |
When you say "tight fitting" hubcentric rings, I'm wondering how tight they are supposed to fit. As I mentioned above, I tried 67mm and 66mm Gorilla rings, and they were both too large. Today I tried some 65.1mm aluminum rings. The rings wouldn't slip right into the wheels and I had to hammer on them for a while to get them to fit. I eventually was able to get them into the wheels (and they are in enough that they don't stick out of the back of the wheel). But they are very tightly jammed/squeezed into the wheel. Is this something I should worry about? The place where I ordered these rings also has 64.1mm ones, so I'm not sure if that was really the proper size. Thoughts? Thanks. |
#40 | |
Drives: 2013 Subaru BRZ MT Limited
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#41 |
Drives: 2012 Scion FR-S Asphalt 6 sp M/T
Work emotion CR Kai center bore?
Does anyone know the center bore of the WORK Emotion CR kai? i have 18x9.5 +38 on all 4.
#42 |
| 5mm spacers and hub rings. | zooki | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 04-05-2013 10:57 PM |
| Buying OZ Superleggera 17x7 - Do I need hub rings? | NYC BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-10-2012 03:56 PM |
