Old 08-06-2012, 10:23 PM   #1
Coastermikey
Drives: BRZ DGM
Which camber plates are you running?
Those who are running kw's, which camber plates are you using?
Coastermikey is offline   Reply With Quote
Old 08-08-2012, 04:23 PM   #2
Coastermikey
Drives: BRZ DGM
guess everyone is using stock stuff idk
Old 08-08-2012, 04:32 PM   #3
xwd
Vorschlag has camber plates available. Others are using the Whiteline Com-C mounts instead of camber plates. The plates uses on the older Imprezas are compatible with the car so take your pick.
Old 08-08-2012, 10:18 PM   #4
Coastermikey
Drives: BRZ DGM
Which year imprezas?
Old 08-09-2012, 12:06 AM   #5
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
The front plates from the 93-07 Imprezas should fit the front of the BRZ without an issue. We just installed the Whiteline Comp C upper mounts and set them to give max caster and camber, and we are loving it so far. Really seems to help with steering input and feel, and the added camber is always nice as well
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 08-09-2012, 09:02 AM   #6
Arnie_1
Drives: Peugeot 106 XSi
Thanks,
Rick
are you sure about 93-2001 (GC/GF) Imprezas? The bolt holes on the strut tower are placed in a different "clock" orientation to 2002-07(GD/GG). So a camber plate designed for a GC, though it physically fits, will have the camber "slot" oriented differently if used on a GD/GG.
Arnie_1 is offline   Reply With Quote
Old 08-09-2012, 09:57 AM   #7
Racecomp Engineering
Yeah....stick with GD to make life easier.
- Andrew
Old 08-09-2012, 10:06 AM   #8
Arnie_1
Andrew - so the holes are oriented like in a "GD/GG", not GC?
Old 08-09-2012, 10:25 AM   #9
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Im using vorschlag they make a sweet product.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-09-2012, 11:34 AM   #10
Arnie_1
Nice! I like that they are already positioned for max caster. They also look thick enough that the plate doesn't bend over time. I don't know how many Cusco, TEIN and HKS camber plates I've seen that are no longer adjustable because the plate has bent over time and you can no longer move the strut back and forth.
Old 08-09-2012, 06:10 PM   #11
Coastermikey
Drives: BRZ DGM
I was looking for these, u get them direct from vorschlag? They aren't listed on their website
Old 08-10-2012, 12:20 AM   #12
RallySport Direct
yeah sorry, I should have been more specific. With the Whiteline mounts you would change the orientation to get the camber/caster gains/loss, but on normal slotted camber plates, the 02-07 plates would be the ones to go with.
Thanks,
Rick
Old 08-10-2012, 08:53 PM   #13
vividracing
vividracing's Avatar
We carry the Vorshlag's. I got Pcasso his set as well as a few others on here so far.
They currently have fitment for the KW V3 (60mm), as well as 2.25" and 2.5"
vividracing is offline   Reply With Quote
Old 08-10-2012, 09:34 PM   #14
schtebie
Drives: CBS BRZ Limited
I got the Vorshlags from vivid racing as well.
schtebie is offline   Reply With Quote
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
CUSTOM PLATES OR REGUALR PLATES? Koomoo Scion FR-S / Toyota 86 GT86 General Forum 13 05-21-2012 09:38 PM
