Old 08-08-2012, 12:35 PM   #15
yoshiharadesign
the hub centric rings main focus is to soley center the wheel to prevent any vibrations that may occur from the wheel being mounted slight off center. Metal or plastic makes no difference as long as the plastic is a high temp grade and rigid with minimal play. Because there is always some play in the lug holes and the wheels, the ring effectively positions the wheel in the prescribed location.
yoshiharadesign is offline   Reply With Quote
The Following User Says Thank You to yoshiharadesign For This Useful Post:
RAYSSPL (11-08-2012)
Old 08-08-2012, 12:45 PM   #16
OrbitalEllipses
Drives: Attitude
Originally Posted by ft86Fan View Post
This is what I mean by the conflicting facts but I guess we all agree that using hubcentric rings can't hurt and its a good idea. You can get a set of plastic ones for $8 anyway.
Depends on the sizing. For instance, I want SSR wheels that have a 79.5 hub bore. Subaru hub bores are 56.1. No one makes a hub ring for that application aside from SSR and they charge around $20/ea.
Old 08-08-2012, 12:53 PM   #17
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you can avoid using rings if you slowly hand tighten your wheel in a star pattern
and by hand tighten and slowly, i do mean hand tighten, and slowly
the conical seat of the lug nuts will center the wheel 5 studs, but only if you do it slowly and evenly (ie, don't tighten just one nut all the way)
so if you have the time, i recommend doing it this way as it will do an even better job at centering your wheel than the centering ring.
The Following User Says Thank You to 7thgear For This Useful Post:
Old 08-08-2012, 12:59 PM   #18
yoshiharadesign
i would not suggest to exclude the ring. If possible always have the ring in place as regardless of how slowly you tighten the lug nuts, slight variances will always produce some vibrations. There is a reason why all oe fitments are hubcentric wheels.
The Following 2 Users Say Thank You to yoshiharadesign For This Useful Post:
OrbitalEllipses (08-08-2012), sho220 (08-08-2012)
Old 08-08-2012, 01:01 PM   #19
xwd
Yes that's what I was getting at. You need to do it in at least two steps of torque, don't just hammer down each nut in the star pattern.
Old 08-08-2012, 01:12 PM   #20
OrbitalEllipses
Drives: Attitude
There's really no reason not to use them...
Old 08-08-2012, 01:13 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by schtebie View Post
A little off topic, but are those McGard Spline Drive lugs? If so, how do you like them?
Gorilla spline drives. I've used Gorilla lug nuts for a while now and have been very happy with their quality and durability.
Old 08-08-2012, 01:23 PM   #22
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i have been hand tightening hub-centric wheels for a decade with zero vibrations
the tolerance of 5 studs canceling each other out will be less than that of a single ring.
Also, OE wheels are OE wheels, they are built to match. Less confidence can be given to aftermarket.
Old 08-08-2012, 02:03 PM   #23
yoshiharadesign
Yes. while that is possible, it is always easier to have a ring and tightening in sequence. As to hub rings on aftermarket vs oe, of course the wheels from oe are going to fit exactly. However, pairing a tight fitting set of rings with minimal tolerance will have the same effect. With rings, it merely simplifies things more.
Old 08-08-2012, 02:37 PM   #24
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Would rings be pointless on our car with certain hub bore diameter wheels? For instance, if a wheel has a bore diameter of 56, would you not need/use rings?
Phaedrus29 is offline   Reply With Quote
Old 08-08-2012, 02:53 PM   #25
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
If a wheel has a bore diameter of 56 it won't have any gap for you to fit a hub centric ring.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 08-08-2012, 03:00 PM   #26
Draco-REX
Corner Junkie
Draco-REX's Avatar
Yup, if the center bore of the wheel matches the hub, then the wheel itself is hubcentric. Same as OEM wheels.
Old 08-08-2012, 03:04 PM   #27
yoshiharadesign
that means that the wheel is drill to fit for the subaru and other application with the center bore of 56. This would not require any hubcentric rings.
Old 08-10-2012, 01:49 PM   #28
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Sorry this is a myth, having been in the industry for 15+ years what you are relaying is a type of preload. That pre load would never have the same tensil strength as a solid hub, you can take the five lugs and multiply each individual SAE rating and it will never come close to the SAE rating of the 56.1 hub.
Spartan65 is offline   Reply With Quote
5mm spacers and hub rings. zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-05-2013 10:57 PM
Buying OZ Superleggera 17x7 - Do I need hub rings? NYC BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-10-2012 03:56 PM
