#29 |
Official Cobb beer knurd
Drives: 2013 BRZ-L MT SWP
My BRZ does this, and to my ear it's front-end located, possibly more on the left than right. I only notice it when I get up to speed, but found it hits heavily in 6th cruising in the 50's. My car's at the detailer for two days getting Opti-guarded and window tint installed, but I'll do so more evaluation and post back what I find. It's not wheel bearings, those are constant, more of a whine, and increase in pitch and intensity with speed. This is definitely something harmonic going on that relates to the speed of the vehicle.
#30 |
Re-member
Drives: Toyota camry
A wheel thats out of balance will do something similar what you are describing with the harmonic at multiples of a set speed. Usually you feel the tire bouncing but perhaps the suspension is soaking it up. Only the wheels, tires, and bearings, are speed dependent, everything else is rpm dependent. The differential rpm dependent.
Nothing decays like progress, and nothing preserves like neglect.
#31 | |
#32 | |
Señor Member
Drives: 2013 SSM DZE BRZ
I've scheduled another appointment with my dealer for next week, but it may get pushed out if SoA & my dealer jointly decide to wait for the district rep. to come before reevaluation my car. I'll keep you all posted on any new developments, and those that I asked to contact SoA, please do so if you haven't already. |
#33 |
Drives: WRB MT-BRZ LMTD
Mine smells like rubber. Not sure if that's normal for a brand new engine. But it seems like something was burning for sure.
Havent notice any chirping yet.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#34 |
Drives: DAT Rally Blue BRZ
#35 |
Drives: SSM BRZ-L 6MT (gone)
I was just reading this thread for the first time (because I don't have the noise). I couldn't help but think it was tire, or wheel & tire balance related. If there is an imperfection in the tire or it is out of round, or the balance is off, it could cause what you are experiencing. Sometimes if that type of problem is on a rear wheel you don't feel the vibration.
I know the dealer SHOULD be the one to diagnose it, but I often find myself (more patient, more concerned) doing their work for them. Here is my suggestion to the OP: switch your wheels front to back. This will eliminate wheels and tires as a possibility if the problem remains in the rear. It is a very easy thing to do yourself, consider it quality bonding time. And, who knows, if the noise moves, you found the problem. HTH. |
| The Following User Says Thank You to nibor33 For This Useful Post: | Bristecom (08-16-2012) |
#36 | |
i liek turtles
Drives: 2002 Honda S2000
2005 Subaru Impreza WRX STi - Aspen White - Since 2008
#37 |
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Could it be something under the car like a splash shield that has a designed hole in it and when the vehicle reaches a certain speed it makes a noise like blowing over the top of an empty beer bottle. Actually, that's kinda what it sounds like but you can feel it in your feet through the pedals.
Btw, didn't get a chance to call SoA yet. Will do so tomorrow. I just can't have any warranty work done until I get flashed back to stock. Currently testing for Visconti's stg1 tune. |
#38 | |
Señor Member
#39 |
Drives: premium silver
#40 |
Señor Member
#41 |
#42 |
Señor Member
| Intake resonance pipe? | tranzformer | Engine, Exhaust, Transmission | 20 | 12-05-2011 05:09 AM |
