Old 04-21-2011, 04:46 PM   #85
dominican
Lude Dude
Drives: 1998 Honda Prelude
The only things I'll be doing is debadging it, add some larger, tasteful rims, preferably with some lip (maybe some LMs), removing cruise control (if that's possible), making the exhaust as big, light, and without restrictions as possible (no inspections in FL, FTMFW), maybe an intake, and most importantly, dropping it like it's hot.
dominican is offline   Reply With Quote
Old 04-21-2011, 04:58 PM   #86
#87
I usually post drunk
#87's Avatar
I'm not going to agree disagree with the people in this thread, but I think it is HILARIOUS that some of you care SOOO much what other people put on their cars.
To me, if it looks bad then it will just make my car look even better.
If it's not functional, who cares it isn't your money.
If it is useless or whatever, you should be happy people are buying parts and expanding the market for after market parts.
IMO you can say it looks bad, call it rice, or whatever but I don't think it is worth the time to argue about it beyond that. It's just like complaining about other people's driving, it is lose lose all the time every time.
#87 is offline   Reply With Quote
Old 04-21-2011, 04:58 PM   #87
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It won't be. With a drive-by-wire throttle the cruise control is handled by software. Other than a few buttons near the steering wheel there's nothing to remove.
old greg is offline   Reply With Quote
Old 04-21-2011, 05:01 PM   #88
JohnnyR
Drives: 04 Evo 8
Probably go JDM badges to get rid of the Scion stuff. Intake/Exhaust/Flash for some tone and performance bump. Maybe a nice set of wheels. Long shot, if I got it in white, I'd get the roof, pillars, and rear decklid done in gloss black.
It's my DD, so I'm not too concerned with it, but I'm sure eventually I won't be able to help myself. Probably put more money into the suspension than anything though.
To each their own though with that crazy stuff. I did it at one time with my celica, and I loved it's look. People thought it was stock like that because it meshed so well together, outside of the paintjob I had on it which obviously stood out being a real Kandy 3-stage finish.
JohnnyR is offline   Reply With Quote
Old 04-21-2011, 06:39 PM   #89
fatoni
Originally Posted by BoostJunkie View Post
Ok, but your missing the point, it helps with cooling, your right so does a/m radiators, Elec water pumps, dual Elec fans...ect. But what I'm saying is that even with all that, the hood can still help a great deal, in the persuit of a cooler running engine every little bit helps.
But your entitled to your own opinion, so what ever floats your boat
if heat is that much of an issue i bet that large sum of money could be better used for bigger injectors a better tune or running e85. thats all im saying.
if i actually get one of these, ill probably drive for a while to see what it needs. ill probalby just end up with wheels tires and suspension components maybe brakes too
Old 04-22-2011, 01:02 AM   #90
Dimman
Kuruma Otaku
Dimman's Avatar
Main purpose of the undertray is to smoothly connect the under car air (normally high pressure) to the rear low pressure area to balance them out. With the help of a diffuser of course. A smooth, flat floor with a raked ride height can have a similar but not quite as effective effect.
Airdam's job is to reduce the amount of air getting under the car. And the often-attached splitter's job is to take advantage of the frontal high pressure zone by giving it something that it can push down against.
Is it just me, or (given the understanding that Scion Corporate admitted to be reading the forums) does the ridiculous Mk3 diffuser seem like it's a joke on us, and everyone that was asking to see a diffuser-delete 'chop on the Mk2 Concept?
Because titanium.
Old 04-22-2011, 10:43 AM   #91
midenginebias
Drives: 2001 Mr2 Spyder
Are you sure about that? Downforce is proportional to velocity squared. Most vehicles won't see any real downforce until 70+. And if you want anything worthwhile below that you need to go to some pretty extreme lengths. Take a look at a few winged FSAE or SCCA A-mod cars and you'll see what I mean.
Exactly. Usually for road cars, minimizing lift and adding minute downforce is enough, but not adding extreme amounts. It's unnecessary to decrease mpg due to aero drag and increase tire wear for the masses.
midenginebias is offline   Reply With Quote
Old 04-22-2011, 12:23 PM   #92
Allch Chcar
Drives: N/A
Originally Posted by old greg View Post
Nope. Pressure exerts force equally in all directions, so the downforce you gain by pushing down on the undertray is cancelled out by the lift caused by pushing up on the hood. You would need to lower the pressure under the undertray. The much easier alternative is to just run a splitter, and let that high pressure region in front of the radiator do the work for you.
You'd need to increase the surface area of the wings to get more downforce at slow speeds. Hence why small spoilers/wings are laughable, they don't make that many lbs of downforce until high speeds.
E85 wouldn't solve a heating problem. It does burn cooler but that isn't quite what we're talking about. The number one issue for overheating is usually with the radiator or coolant not the fuel or anything else. If you make enough HP that the cooling system can't keep up you'll need a larger capacity radiator.
Cool, but I mispoke about flowing air into the engine bay what I ment to say is to block the air flow into the engine bay except what is necessary for cooling, the rest just becomes stagnant hot air. What you're saying is eliminate the pressure on the hood/windshield and move the pressure to the belly pan. If the pressure on the hood is greater than the pressure in the bay and the air under the pan than it will exert downforce but probably not as much as what you are saying. So I do kind of understand what you're saying now.
Exactly like high speed cars should be. Minute amounts of downforce for stability and as slippery as possible.
Most of my understanding of aerodynamics is from being interested in decreasing drag from aerodynamics for the most efficiency and MPG. So I don't have much info on the various downforce methods other than knowing what they are eg. canards, airdams, wings, spoilers, etc. Thanks for being kind to me .
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 04-22-2011, 02:59 PM   #93
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
you say: "that car is so rice"
I say: "man that car looks shitty"
not directed at anyone, but lets just get rid of that stupid term.. a car either looks good or it doesnt
VenomRush is offline   Reply With Quote
Old 04-22-2011, 04:34 PM   #94
aliphian
Dreamer
aliphian's Avatar
Drives: Nutless Grocery Getter
I usually say "Damn that car looks SICK. I wonder how fast it doesn't go..."
"Reality is merely an illusion, albeit a very persistent one."
aliphian is offline   Reply With Quote
Old 04-22-2011, 04:35 PM   #95
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yes and no. More surface area will make more downforce given an equal coefficient of lift. However, the longer the chord of your airfoils the lower their Reynolds number will be at any given speed, and the lower your Reynold's number is the harder it is to generate downforce. The larger your airfoil is the faster it needs to go to be efficient. On top of that, it will tolerate less angle of attack before stalling for any given speed, and angle of attack is where the vast majority of the downforce comes from. So pure size is a pretty poor investment for low speed downforce.
What you need for low speeds is a wing that can operate at a very high angle of attack, like 20+ degrees (45+ if you're really serious). Any single element wing is just going to be a parachute at that sort of angle, you'll get some downforce along with massive amounts of drag. The trick is to use a multi-element wing, like the two element in F1 but more-so. The second, third etc. airfoils act exactly like the flaps on an airplane, they allow the wing to operate at slower speeds and higher angles of attack without stalling. That's why you'll occasionally see crazy stuff like 4-element wings with leading edge extensions on autocross or hillclimb cars. They look a bit ridiculous, but they will make a couple hundred pounds of downforce at 30 mph.
But yeah small wings are silly. Go big or go home.
Unfortunately, big wings are for race cars and ricers, so wingless it is.
Old 04-22-2011, 06:52 PM   #96
enc0re
enc0re's Avatar
Drives: BMW 325i (E46)
RICE = Race Inspired Cosmetic Enhancements
All the bits that look racy but actually make you slower.
enc0re is offline   Reply With Quote
Old 04-22-2011, 07:27 PM   #97
Giccin
Giccin's Avatar
Mine.. will probably look somewhat ricy.. but I plan on getting it tuned once I get a better feel. Lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 04-22-2011, 08:21 PM   #98
Allch Chcar
Drives: N/A
Hey that's crazy about the multi-wings. I didn't know that.
Some cars look out of place without at least a spoiler. A small duckbill spoiler is nice touch though, not too big or anything just as an accent .
-Allch Chcar
Heritage....inside? Maxim Scion FR-S / Toyota 86 GT86 General Forum 10 01-03-2011 08:17 PM
FT86 concept with a guy inside 4agze Scion FR-S / Toyota 86 GT86 General Forum 2 11-12-2010 03:16 PM
Autocar: Toyota plans new sports saloon ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 2 09-15-2010 09:44 AM
Edmunds Inside Line talks future Vehicles e10rice Scion FR-S / Toyota 86 GT86 General Forum 7 06-10-2010 01:22 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
