#1373 |
Drives:
I picked this GReddy/Trust STD oil cooler up for my FA24 swap. The swapped '19 TRD 86 will be a Greddy NA build.
![]() ![]() ![]() My 14' Monogram is an HKS SC build. An HKS oil cooler is waiting to be installed. My 15' BRZ will be a turbo Blitz build. A Blitz oil cooler is ready to be installed. _______________________________________________ I picked up these used Craft Square mirrors some months back. I'm going to refinish them and replace the decals. The mirror bases won't likely stay polished...I'm not sure what I'll do with them yet. These will be installed on the Monogram. ![]()
#1374 |
Drives:
This is an extra FA20 alternator I purchased last year. It had 31k miles on it at the time of removal.
I'm going to pull the BRZ's engine that has 130k miles and reseal the timing cover. I'll clean up the engine some more once removed and install this lower mileage alternator on it. I still need to polish it. Next up is the RS1's starter... A little crusty. ![]() ![]() ![]() ![]() Ready for polish. ![]() ![]() ![]() ![]()
#1375 |
Rust bucket enthusiast
I really love seeing these before and after. Truly hoping someday you open that service for those of us who lack this effort hahaha
#1376 |
Drives:
RS1's Starter. I still need to polish.
Forgot to take before pics...this is all I have Before: ![]() After: ![]() ![]()
#1377 | |
Drives:
I think that I will switch to sandblasting and powder coating chrome for most of the engine parts. It is just so time consuming getting rid of the texture. Last edited by zeal86; 06-01-2026 at 02:59 PM. |
#1378 |
Drives:
Finally finished prepping all the parts I brought with me!
I will polish all the parts I've posted lately as soon as I get settled in back home. HKS SPEC-L Exhaust. This part completes my Monogram's HKS power delivery. I mainly used red and gray Scotch Brite by hand to get these results. Once polished this exhaust will bling! Before: ![]() ![]() ![]() ![]() After: ![]() ![]()
#1379 |
Drives:
For the FA24 TRD:
I'm a little disappointed that the end tanks didn't have an embossed Greddy logo...not even a vinyl decal. I'll polish it up some more and make it show worthy. Honestly the only indication that this is a Greddy made part is the label on the box. ![]() ![]() ![]() ![]()
#1380 |
Drives:
I'm going to reinforce my own clutch Forks from now on. The pictured (already) reinforced Clutch Fork is the Cusco version...which is just a reinforced OEM part.
![]() Some undercarriage work to weld up. Undercarriage was beat up by the previous owner due to how low the RS1 was. I will be applying some Rustoleum undercoat soon. I was able to source the undercarriage parts from a donor car. Bare metal areas to be welded were sprayed with weld through primer. ![]() ![]() ![]() ![]() Removed from donor car. ![]() Self-etching primer and sealer. ![]() Weld-through Primer. ![]() ![]() ![]() Cuttting down and closing up the rockers for clearance. I just need to weld and seal. ![]() ![]() ![]() I've accomplished more than what I just posted but these pics were definitely the meat and potatoes of what I've been up to. I also was putting in some work on my beater...I needed to give it some love. 209k miles and still getting me 30 to 32 MPGs. |
#1381 |
Drives: 2013 frs base
FYI: The clutch fork usually fails at the pivot.
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 08:27 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 07:09 PM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 07:34 PM |
