Old 08-14-2026, 06:23 PM   #841
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Originally Posted by DarkPira7e View Post
I'm going to dig around and see if I happened to take photos. I know I had a couple but I'm not sure they reveal anything. I mostly took them as a comparison to show it really was identical to the fa20 wrx pump
Again very helpful. What size drain line did you use from your turbo? I can't quite tell what size the fitting is in that pump.
RongTurnRacing is offline   Reply With Quote
Old 08-15-2026, 12:11 PM   #842
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
The AVO one is a #4.
Old 08-15-2026, 02:01 PM   #843
RongTurnRacing
Awesome. Thanks.
I've been chatting with Alan at JDL and he's reasonably convinced that the WRX scavenge pump relies on a reservoir but I haven't seen any evidence of that.
I'm using a Garrett GTX2860R GenII and it has what I believe is a 3/8 to 10AN fitting in it (I'm sure of the 10AN side) to 10AN hose to drain to the pan. I'm trying to decide which size hose to use to the scavenge pump. I don't have the pump in hand yet so I haven't seen exactly what I'll be dealing with yet.
Old 08-15-2026, 06:15 PM   #844
Grady
Grady's Avatar
Awesome. Thanks.
Yes you never want to suck oil out of a turbo. You want it to drain out, then suck it out of the tank. I have seen setups where they do not have a tank and I guess it works but in my opinion not correct. You can find turbo drain tanks easily. Turbo drains into the tank, tank is vented to the crankcase, scavenge pump suck the oil out.
Old 08-15-2026, 06:50 PM   #845
RongTurnRacing
Would adding a tee to the PCV line on my catch can line to the PCV work as a good vent?
Old 08-16-2026, 10:27 AM   #846
Grady
Grady's Avatar
Yes on the tank side not the manifold side, What I did was vented mine to the bottom of my Verus AOS so you never have to drain it.
Old 08-16-2026, 10:49 AM   #847
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Awesome. Thanks.
Thanks to Grady for the size, I missed that.
He's right, you should have a reservoir and pull from that. Mine has been fine, but really it's not something perceptible until it's not fine, I'm just being lazy / curious how long the turbo will manage. Look up images of used 2015+ wrx turbos and you'll see the small rectangular reservoir tightly packed underneath it
Old 08-16-2026, 11:02 AM   #848
RongTurnRacing
OK, well, next step is to figure out a reservoir. I wonder if I could use a oil catch can and feed the turbo drain into it and use the bottom drain to feed the scavenge pump? I'm not seeing anything other than $150+ turbo oil tanks otherwise.
Thanks all.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
