Old 06-05-2026, 11:50 AM   #24823
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by DarkPira7e View Post
You mean you don't like the idea of your leaf blower enjoying a moist breeze when you're at 7500rpm?
Well, I've been using K&N filters for decades, so I'm pretty good at not over oiling, but still nice not to have to oil. I need to see if they have new airflow for my other cars. One for cabin air filter would be nice too.
Edit: just found the cabin washable filter on Amazon for $40.
Old 06-05-2026, 02:30 PM   #24824
arpieb
arpieb's Avatar
Drives: 2022 BRZ Premium, Sapphire Blue
Working through my track-prep checklist:
- Brake pads - DYNAMIC FRICTION Active Performance (F/R)
- 5W30 synthetic - Liqui Moly Full Synthetic
- DOT 4+ brake fluid change - RBF 600
- Dropped off spare rims to get RE71RS all around for dry track/autox
2022 Subaru BRZ Premium aka "Maggie" - Sapphire Blue, Stock (for now)
2023 Porsche Macan S - Papaya Orange, Stock
arpieb is offline   Reply With Quote
Old 06-06-2026, 02:28 PM   #24825
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Last piece of my suspension upgrades have been ordered. Super pro 20 mm front sway bar and 16 mm rear bar
Old 06-07-2026, 01:42 PM   #24826
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Will install the new bushings in the Hotchkis bars plus a general suspension once over.
Track day soon.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 06-17-2026, 04:49 PM   #24827
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Left my trunk popped and the light drained my battery. Third time I've done that.
Old 06-18-2026, 10:42 AM   #24828
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Did a full paint refresh over the last 3-4 days.
Washed thoroughly. Used a clay mitt. Mother's cleaner wax to start as a base. Then 3 coats of Meguiar's liquid wax - which is the easiest wax I've ever applied. Did the windows really well too with a claybar and sealant. Re-blacked out all the trim and bumpers with Mothers Back to Black. Even detailed the wheels heavily and sealed those again too. Haven't done the engine bay and that might up next.
Reason for all this is our new autocross site here locally isn't the best. A lot of gravel. Enough the car probably doubled it's amount of rock chips. 200TW tires and gravel don't mix. It even broke my GoPro lens the first time we were there.
Just kinda wanted to get back to basics and clean up the car as best as possible. Really debating doing the 2nd event there this weekend. Sometimes you get so into racing, times, and pushing to the limit you start forgetting about things like detailing, car meets, etc.
cmiovino is offline   Reply With Quote
Old 06-18-2026, 01:05 PM   #24829
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
Ain't that a MFer.
I swapped out all my bulbs for LEDs. I think I would have a chance that it wouldn't kill the battery.
The youngest daughter had a habit of not shutting the door to her truck fully and killed a couple batteries like that. I swapped in LEDs and hasn't happened since. Even when someone rummaged thru her truck overnight and left the door open when they were done.
smackrel is offline   Reply With Quote
Old 06-18-2026, 10:21 PM   #24830
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by smackrel View Post
Ain't that a MFer.
What really sucked is I was on my way to drop my truck off early in the morning for service at the dealer. My wife was going to pick me up in the twin when she called and said it was dead. I had to take the dealer shuttle home, which took an hour. Luckily my battery is fairly new so charged up fine.
Old 06-20-2026, 05:22 PM   #24831
RToyo86
RToyo86's Avatar
Installed a radium PCV side catch can. Realized I'd have to pull battery to twist the canister off, so I ordered a drain kit instead.
Old 06-21-2026, 10:26 AM   #24832
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I took my trunk bulb out. Problem solved.
Old 06-21-2026, 11:31 AM   #24833
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yesterday I was driving my twin and it started to sprinkle. I turned the intermittent dial on the stalk and nothing. I thought, "great, intermittent wipers don't work.". I finally figured it out. It's been YEARS since I've turned the wipers on in that car.
Old 06-22-2026, 12:58 PM   #24834
smackrel
Full Throttle!
Coming from a long line of Hondas before my BRZ, I feel like the delay on the intermittent wipers leaves a lot to be desired here. The shortest interval is not short enough and the longest is waaaaay too long. Like I forget that the wipers are on too long......
Old 06-22-2026, 04:32 PM   #24835
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I always felt like they could never be adequate. I mostly learned to drive in my E36, which didn't have intermittent. So I am forever just manually articulating the stick when I need them to do a swipe if the Rain-X isn't keeping up
Old 07-08-2026, 06:35 AM   #24836
suzyj
Drives: 2018 86 GTS
My little 2018 86 hit 240,000km, so I treated it to new lower control arms, new tie-rod ends, new steering and sway bar bushings, new tyres (Bridgestone Potenza RE005 in 225/45R17), and new pads and rotors all round (DBA ones, to go with my big Brembo 4 pots).
Now it goes _exactly_ where I point it again.
Still on the original spark plugs.
suzyj is offline   Reply With Quote
