Old 05-17-2026, 11:50 AM   #1
tcarnes08
Drives: frs
Valve shim clearances
Hey guys, I just need some help. I just got a quick question so I’m in the process of setting the clearances on the valve shims right that sit right under the rockers at the tip of the valves. So I set all my clearances to the right specs and then I set the timing on the motor and then cranked it about 2 to 3 times went back to check the clearances and then they were all off. Anybody else have this issue and then how to resolve this?
tcarnes08 is offline   Reply With Quote
Understanding Subaru Valve Lash "Shim" Numbering? hotrod1442 Engine, Exhaust, Transmission 3 01-29-2026 05:44 PM
Valve clearances on built block jrhudson Engine, Exhaust, Transmission 11 08-12-2021 02:36 PM
BRZ Lip Kit Clearances FRZ Cosmetic Modification (Interior/Exterior/Lighting) 1 01-09-2017 01:07 AM
Does anyone have a complete valve shim kit that I can rent or borrow? D K Engine, Exhaust, Transmission 0 04-13-2015 02:42 PM
Valve shim confusion.. Hempo Engine, Exhaust, Transmission 0 02-16-2015 04:45 AM
