#24795 | |
Rust bucket enthusiast
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Th3rdSun (11-14-2025) |
#24796 | |
Drives: 2013 FR-S MT Hot Lava
I did called my local Subaru dealership early on and they said that they wouldn't work on my FR-S,which I thought was very odd,considering that even though it has Scion badges,those badges,and almost every single part is stamped with Fuji Heavy Industries on it. Anyway,been driving it for just under a week now and everything seems like it's back to nomal.It's a daily driver and I don't really push it too hard,so I'm not too worried. |
#24797 | |
Yes, there were a handful that had issues, but for the most part nearly all were done correctly. I had mine done for the same reason you stated, it provided an opportunity to have other labor covered. I had several things done (spark plug replacement, etc) for the cost of parts since they were already doing the work.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Th3rdSun (11-17-2025) |
#24799 |
Drives: Asphalt FR-S
Installed the vland V3 LED headlights, and restored the fog lights that were very oxidated.
![]() ![]() ![]() Sent from my Pixel 10 Pro XL using Tapatalk |
#24800 | |
#24801 |
@apex_blue (IG)
Drives: 2016 FR-S
fixed the leaking banjo bolt mess of a Mishimoto sandwich plate. A friend gave me the cooler and I actually love it unfortunate mess Mishimoto has become.
I used a Mocal oil cooler sandwich plate from 3 car garage and had fun installing that one. The adapter nut is a bitch to install you need a low profile socket 1" which I didn't have so I ugga dugga'd it with a pair of channel lockers. Kinda scratched the bolt but fuck it. It looks sketch cause the OEM oil filter is bigger, but the seal seated perfect. No leaks. For now If it does, I'm swapping the AN/PTFE fitting for another and will have to cut. Mocal Sandwich Plate https://3cgarage.com/collections/san...17070273167449 ![]() ![]() ![]() ![]()
#24802 |
@apex_blue (IG)
Drives: 2016 FR-S
WHAT DID YOU DO TO YOUR FRS TODAY?
Err, uploaded wrong engine bay clip. Finally could put the proper clip back into the windshield fluid due to moving the oil lines
![]() ![]() Also, if your VVT solenoid is leaking, the part is $2 +/- from your local Toyota parts dealer! 2 bolts. Be sure to lubricate w/ some oil before installing. VVT Cam Solenoid Gasket SU003-02191 My oil cap gasket also was wearing out and a major source under load for blow by. Oil Cap Gasket SU003-04083 Now no more leaks ![]() Sent from my iPhone using Tapatalk Last edited by apex_gr; 03-19-2026 at 12:26 PM. |
| The Following User Says Thank You to apex_gr For This Useful Post: | LancePower (03-19-2026) |
#24803 |
Drives: 2017 86
one way the DRL function can be disabled is through the carista app. it's what i've used in the past.
| The Following User Says Thank You to slim blanco For This Useful Post: | apex_gr (03-25-2026) |
#24805 | |
@apex_blue (IG)
Drives: 2016 FR-S
Thanks for the reply! I was going to use the red intake silicone tube as I actually have it but I needed a block off plunger for the firewall and just decided to keep the stock acoustic tube & canister intact. It is a bit finicky if you don't have the hoses tight so make sure you do that. It is a bit louder than stock imo and I actually may run slightly slower than stock airbox because I'm not tuned. Eventually will get flex fuel and will get the car tuned for E50. You can see the knock correction learn value that may be from my fuel quality or actually the intake but without going into the logs and resetting my ecu that's my best guess. I actually did not take off the entire bumper but you do need to unbolt some things to get to it. Overall fairly easy install but you may scratch the tube if you do not have the right angle to clear the front core support. ![]()
| The Following User Says Thank You to apex_gr For This Useful Post: | smackrel (03-27-2026) |
#24806 |
Drives: 17 Asphalt 86
Picked up a GR86 header, OP and front pipe for the stash.
Also crossed over 200,000km |
| The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
#24808 |
Full Throttle!
Drives: 17 CBSP Limited PP
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
