Old 03-11-2026, 11:37 AM   #1
Snoopysvet
Snoopysvet's Avatar
Drives: 2023 Wr Blue Pearl BRZ manual
Rim & Tire selection
I have a stock 2023 BRZ and am looking at these wheels and tires.
Questions
Will the 35 mm offset bring the wheels out or in more?
Any issues with fitting?
2023 BRZ
Snoopysvet is offline   Reply With Quote
Old 03-11-2026, 01:18 PM   #2
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
https://www.willtheyfit.com/
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Snoopysvet (03-11-2026)
Old 03-11-2026, 06:59 PM   #3
Snoopysvet
Snoopysvet's Avatar
Thanks BT
Originally Posted by B T View Post
2023 BRZ
Old 03-11-2026, 07:10 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Lower number offset = wheel pushed out
Higher offset = wheel more sunken in.
+35 will push face farther out. Rim width also plays a factor in fitment.
Old 03-11-2026, 09:03 PM   #5
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Questions
Another great site: https://www.wheel-size.com/calc/
RT-BRZ is offline   Reply With Quote
Old 03-12-2026, 07:13 PM   #6
Snoopysvet
Snoopysvet's Avatar
Do you think I could go with...
245 40R 18
instead of...
235 40R 18
with 18 X 8.5 +35mm rims
without issues?
2023 BRZ
Old 03-12-2026, 08:15 PM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
245 40R 18
instead of...
235 40R 18
without issues?
If you're not on coilovers, 245s are going to be reaaaaly close to your spring perches
Old 03-13-2026, 04:51 AM   #8
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
245 with 35 profile.
ACT86 is offline   Reply With Quote
Old 03-13-2026, 07:21 AM   #9
whataboutbob
AutoX-10/10ths every run
https://www.ft86club.com/forums/showthread.php?t=7535
Build thread:Here
&&&&&&&&&&& zpeed Exterior Parts (Aero, Lighting, Etc.) 3 02-07-2016 12:15 PM
RATIONAL Wheel & Tire Selection? FlamingRectumSyndrome Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 04-11-2014 12:34 PM
225/45/17 on 8" rim vs 245/40/17 on 9" rim bfrank1972 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-22-2013 04:40 PM
QUESTION: Rim & Tire Size at NJ & NY Figo NY / NJ / CT / PA 6 07-17-2013 02:21 PM
