#2157 |
Drives: brz 2017 hksv2
you are supposed to use e85 and no less of that. and to make power with it you need to make lean and more timing
#2158 |
Drives: 2019 Subaru BRZ
Hi, I have a log post request: could someone on K00G (or anything derived from it) capture a datazap log of five minutes of driving with typical log values (at least STFT, LTFT, MAF, Throttle) and add in what I believe is the learned LTFT target values table below?
Code:
; for use with K00G which has LTFT @ fff8d874, MAF @ fff89470 paramname = LTFT_bucket paramid = 0xFFF8aae0 ; K00G databits = 8 paramname = LTFT_target paramid = 0xFFF8aac8 ; K00G isfloat = 1 ; _xL stores LTFT learning progress, higher values stabilize for 'done learning' ;; databits = 8 seems to be 193+ when learning is done; ;; databits = 16 would be .. 49152+, i think? ;; databits = 32 for 3221225472+, i think? ;; puzzling out the meaning of the learning progress bits is my next long-term project ; _x is the base LTFT for that zone ; 5..8 are the 'normal' zones, corresponding to the MAF thresholds in AF Learning 1 Airflow A/B ; 4 seems to be the 'popped the throttle to zero' / 'tip-out' compensation / zero throttle zone? ; 0 .. maybe .. seems to be the 'braking' zone, except sometimes it uses B1 rather than A0's learned LTFT? paramname = LTFT_0L paramid = 0xFFF80f60 ; K00G databits = 32 paramname = LTFT_0 paramid = 0xFFF80f64 ; K00G isfloat = 1 paramname = LTFT_4L paramid = 0xFFF80f80 ; K00G databits = 32 paramname = LTFT_4 paramid = 0xFFF80f84 ; K00G isfloat = 1 paramname = LTFT_5L paramid = 0xFFF80f88 ; K00G databits = 32 paramname = LTFT_5 paramid = 0xFFF80f8c ; K00G isfloat = 1 paramname = LTFT_6L paramid = 0xFFF80f90 ; K00G databits = 32 paramname = LTFT_6 paramid = 0xFFF80f94 ; K00G isfloat = 1 paramname = LTFT_7L paramid = 0xFFF80f98 ; K00G databits = 32 paramname = LTFT_7 paramid = 0xFFF80f9c ; K00G isfloat = 1 paramname = LTFT_8L paramid = 0xFFF80fa0 ; K00G databits = 32 paramname = LTFT_8 paramid = 0xFFF80fa4 ; V00C isfloat = 1 Last edited by callisto; 08-02-2025 at 10:23 AM. Reason: add missing LTFT_target |
#2159 |
Hi all,
https://datazap.me/u/jm22/2025tommv0...&mark=53-69-66 Here is my log. NA with Power Blocks installed. I hope you can give me some feedback and help me fine tunning a bit. I understand that:
Is that correct? Should I just take MAF sensor scaling table and multiply every value by 1.02, for example? And increase timing a bit, since flkc is 0 thanks in advance Last edited by J95; 08-04-2025 at 01:57 PM. |
#2160 |
wrote you an MP
#2161 |
#2162 |
https://datazap.me/u/darksunrise/122...?log=0&data=15
Data log from a gen 2 BRZ. Tuner sent me a base e85 tune which I was testing out. A little concerning to see IAM drop to 0.61. Even more confusing b/c I barely see any knock correction and there doesn't seem to be any negative FLKC. Car is stock other than a catback and GR intake. Tested at ~3000 ft elevation. Any thoughts? TIA! (Note I was part throttle in that log due to IAM but here's another log where I was going full throttle https://datazap.me/u/darksunrise/122...og=1&data=4-14 )
2022 BRZ Build 2013 FR-S Build |
#2163 |
Hi,
I think I finally nailed my OL, after 4 scalings using the MAF scale app: https://datazap.me/u/jm22/20260214to...-7-12&solo=3-6 I will make the >4V just a tiny leaner Timing goes up to 27, I wonder If If there is room for more or if I should leave it like that. My car is NA, RON98 Regarding CL: https://datazap.me/u/jm22/20260214to...=0&data=1-9-10 I plotted the LTFT, see attached. I adapted the curve accordingly, now it looks like this (see Scale4 curve). I wonder if I should smooth out the transition (~2.9V), or if it is fine like that any help welcome
#2164 |
it looks good
you can keep it the maf scaling like that About ign advance, the values depends on many things, included afr and pi% so we can t judge absolute values what you can do is try raise them until knock appears |
#2165 |
Rust bucket enthusiast
Throwing this here since I'm also going to post in my build thread. I found Vital log viewer recently, it's super fast and reads CSVs. Just wanted to share in case anyone wanted to try something that actually is pleasant to use. It does cost $$$ for a license but I took the dive since I'm sick of megalog viewer and other crap.
vitalengineered.com
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
