Old 08-05-2012, 03:17 PM   #43
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
It's not the size of your rotors & calipers that matter, it's all about the colour of the pad transfer and the condition of the disc surface.
Nothing says 'waste' like huge expensive brake kits and virgin rotors.
It's the folks with an amazingly thick and even layer of pad material transfer on their rotors that get the nod of respect.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-05-2012, 07:59 PM   #44
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by pcasso87 View Post
So you are planning on coughing up 2.5k grand on a set of brakes just for looks? By asking people what are the pros and cons of a bigger set of brakes it just shows your ignorance in the ability to not be able to judge why a car needs brakes. Have you felt brake fade? Do you have very sticky tires? Why are you wanting to upgrade something you have no clue over why it needs upgrading in the first place. A bigger set of brakes will not make the car stop any faster in the street , a good set of tires will. You will prob never experience brake fade in the street nor do you need the huge braking force since your street tires prob will limit your ability to stop before your brakes do.
But if you want to throw your money away on something you dont need for the street go ahead, its your cash not ours.
Hey i powdered coated my 300zx brake upgrade and my stock s14 brakes and i dont think it looked cheesy!! Its not cheesy if you do it right. Which involves taking the calipers apart.
Pics of my coated calipers on my ex s14.5
Powder coated and spray painted are two different things. I would agree your S14 brakes look great. Nothing cheesy there.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
track_warrior (08-05-2012)
Old 08-05-2012, 08:46 PM   #45
OrbitalEllipses
Drives: Attitude
For those wondering....those ZX brakes are actually the same units as the Subaru (FHI) units, except for the mounting ears. You can find adapters if you try hard enough, though the Subaru units are really easy to source albeit a bit pricey (for no real upgrade aside from looks).
Old 08-05-2012, 09:15 PM   #46
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Originally Posted by STi88 View Post
As much as I want the cosmetics improvement
Better brakes are a performance improvement. If the goal is purely enhanced cosmetics, just stop right there...
Start with pads that have better stopping power and get up to temp quickly so you can use them for a DD.
SS brake lines will also improve braking feel. No need to invest in a bigger set of calipers just yet.
Jordo! is offline   Reply With Quote
Old 08-06-2012, 03:51 AM   #47
dirk_diggler
Drives: 2011 BMW 328i Coupe M-Sport 6MT
Originally Posted by ZDan View Post
Adding 40%(!) more piston area will KILL the bias (WAY too much front bias) and give you longer pedal travel for a given level of braking. Seems like an exceedingly bad idea to me...
Researching this, I noticed that the highlander rear piston diameter is 41mm and the Camry was 38mm, which is not a huge difference. This is why I thought that if I were to do this poor man's bbk, I would leave the rears alone. This assumes everything else being equal, which may not be the case.
Also, maybe someone with actual experience in doing this can chime in, but I figured that even IF there was a bias change, stopping in DD scenarios will be largely unaffected.
dirk_diggler is offline   Reply With Quote
Old 08-06-2012, 04:03 AM   #48
der_rainman
Drives: Subaru BRZ
One problem with measuring pistons is where you are actually measuring. You can't just take a caliper to the exposed face of the "piston" underneath the pad. Oftentimes the actual piston diameter is different (within the actual bore) than what you see up top/exposed. Best way to measure is to actually remove the piston from the caliper. Especially if you are trying to accurately calculate brake bias.
der_rainman is offline   Reply With Quote
Old 08-06-2012, 04:35 AM   #49
dirk_diggler
Good point. I have no clue how the diameters were measured. These were the diameters shown in catalogs for rebuilt calipers.
Several people have done this upgrade with good results if I were to believe them. Since none of those people were on the standard issue 17" SE wheels, I didn't want to take the risk to find out. The Brembo rotors eliminated the shimmy when hot (and only when hot), so problem was solved half way. The other half was to pass the Camry down to the wifey.
Old 08-06-2012, 08:03 AM   #50
ZDan
ZDan's Avatar
Drives: '23 BRZ
The Highlander has a *different* braking system. Probably has different master cylinder, different proportioning valve and different rotor diameters. You shouldn't change *anything* without knowing what the front/rear bias ramifications are.
If you put front calipers with significantly more piston area up front, you will TREMENDOUSLY affect stopping distances for the worse. At the point where ABS engages to reign in the overbiased fronts, the rears won't be contributing anything like as much braking as they would be with proper bias. In most instances, people won't continue to apply more and more brake pressure once they feel the ABS pulsing.
This mod sounds like a BAD idea to me. Basically, you'll engage ABS at much lower braking g's, and have to "push through" a fair amount more to fully utilize the rear brakes. Stock should already be a bit front-biased. Adding a ton more front bias? Bad idea...
dirk_diggler (08-06-2012)
Old 08-06-2012, 02:50 PM   #51
der_rainman
Drives: Subaru BRZ
And to continue what Dan is saying, the big problem is this type of "upgrade" feels great! You get serious nose dive from an overly front biased "upgrade" that you get from improperly biased components (leading to more brake torque up front). That serious nose dive is often interpreted as an improvement in braking. But its not! its usually just the opposite.
The Following User Says Thank You to der_rainman For This Useful Post:
brakes, cons, pros
**AIM Solo Lap Timers and Go Pros** Evasive Motorsports Audio/Visual, Electronics, Infotainment, NAV 8 05-15-2015 12:32 PM
pricing for my 12 focus (switching to fr-s) jamesox Northwest 3 07-06-2012 09:29 AM
Getting Bigger phenoyz Scion FR-S / Toyota 86 GT86 General Forum 4 05-30-2012 09:22 AM
