Old 01-01-2023, 02:19 PM   #1
norcalpb
norcalpb's Avatar
Updated "JDM" underbody panels?
Sup everyone,
I see that the GR86/gen 2 BRZ come with slightly different side underbody panels in which the puck is mounted via plastic clips instead of rivets. Searching for the part # it appears these new underbody panels came on 1st gen facelift vehicles of certain years.
Can someone with a 17-20 car please take a look and see if the puck of their underbody panel looks like option #1, or option #2?
Option #1:
Option #2:
TIA,
Steve
Old 11-06-2024, 11:27 PM   #2
Luns
Drives: 2017 GT86
FWIW, my '17 86 (base) has none of these panels. But I'm considering buying the parts to add them.
From what I could tell, the transition between the two styles of cover was in 2020. The Subaru parts catalog has a section for UNDER COVER CENTER '15MY-'20MY, and one for UNDER COVER CENTER '20MY-. Both pages ultimately give the 2nd gen part numbers, with the original 1st gen part numbers having been superceded and no longer in the list. Viewing and ordering the old part numbers, the new panel is automatically substituted, without the puck.
Strangely, while the fuel tank covers have new part numbers superceding the old, the old part numbers remain available to order. Both part numbers are listed for the same 2017-2020 variants (with puzzling gaps in coverage), but 2022 lists the old part numbers (ca20,ca30) while 2023+ (also with odd gaps) give the new (ca21,ca31) part numbers.
Luns is offline   Reply With Quote
Old 11-07-2024, 09:32 AM   #3
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
2017 BRZ PP (series.yellow)
'Option 1'
Breezio is offline   Reply With Quote
Old 11-08-2024, 12:00 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
They're updated, but cross compatible (original style is 1-piece riveted, new style is 2-piece and you clip them together). I imagine they had issues with people breaking the little front plastic guard and having to order a whole undercover, rather than just replacing the guard.
Just ordered a set of revised undercovers a few months ago. Fit fine on FR-S
EndlessAzure is offline   Reply With Quote
The Following 13 Users Say Thank You to EndlessAzure For This Useful Post:
2.2Lude (11-08-2024), BatStig (01-17-2025), Compelica (01-13-2025), DocWalt (11-14-2024), Luns (11-08-2024), norcalpb (11-11-2024), Ohio Enthusiast (11-08-2024), Racecomp Engineering (11-13-2024), Spuds (11-13-2024), T-Steve (11-08-2024), Ultramaroon (11-08-2024), villainous_frx (11-22-2024)
Old 01-12-2025, 03:11 PM   #5
FrickingReallySlow
Drives: 2015 FR-S
Does it come with the necessary screws or I need to order those separately from the main part number?
FrickingReallySlow is offline   Reply With Quote
Old 01-12-2025, 05:11 PM   #6
EndlessAzure
Wheels for Brains
All of the hardware is separate. You can reuse a handful from the existing covers, but it's not enough for both sides and the extra mounting points
The Following User Says Thank You to EndlessAzure For This Useful Post:
FrickingReallySlow (01-12-2025)
Old 01-31-2026, 12:23 PM   #7
FrickingReallySlow
Drives: 2015 FR-S
Anyone know if the undercover suppose to installed "over" the panels since they share bolts on both Left and right sides? this is the undercover I'm referring to. Or are the panels suppose to be installed after the undercover?
Old 01-31-2026, 12:38 PM   #8
Ohio Enthusiast
Drives: 2018 BRZ
My 2018 BRZ has all of these (as far as I know the US got all the panels after the 2017 facelift, and maybe BRZs always had them vs. FRS).
The cover covering the transmission goes last (so it's on top of the aero panels). I think they don't share bolts, rather each have their own (but I'm not 100%, it's been a while since I took off the transmission cover (and even longer since I took off the aero panels to get to the sway bar)).
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
FrickingReallySlow (02-01-2026)
Old 01-31-2026, 09:17 PM   #9
EndlessAzure
Wheels for Brains
The undercovers are the bottom layer, if that makes sense. The transmission cover sits on-top of them.
The bolts that hold the covers have a flange and a wide shank, which is what the holes in the covers align with.
Where they double up, the covers squish a little bit, but they seat and tighten properly
You can see them in the image by OP of the very thread we are in
"duct" panel near underbody is loose and rattling Spacemane969 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-01-2020 02:12 PM
CSG's Jackson Racing "Factory Tuned" Supercharger experience, updated 12/19/2013 CSG Mike Forced Induction 264 07-11-2017 02:27 PM
FS: j2 quad tip exhaust 2.75" NEED THIS GONE "price updated" FRSex Engine, Exhaust, Bolt-Ons 23 07-28-2013 10:07 AM
WTB/Trade: Black FR-S fender "vent" panels with 86 badge JWA Exterior Parts (Aero, Lighting, Etc.) 7 09-19-2012 09:42 PM
Subaru Canada site updated with BRZ "price and equip" monevasia CANADA 4 06-07-2012 09:19 AM
